05-29-2007, 07:31 | #1 (permalink) |
No Life Poster Join Date: Sep 2005 Age: 59
Member: 185776 Status: Offline Thanks Meter: 73 | C140 strange problem Action: unlock Device: C140 Phone must be powered-On Connecting... device found: C140AKGA3 phone connected, working... software version: C140AKGA3 hardware revision: XXXXXXXX hardware id: ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ imei: 0000000000000001 working... operaton finished Ok Finished, time used: 27 sec Remove/Install battery now Action: unlock Device: C140 Phone must be powered-On Connecting... device found: C140BNGA1 phone connected, working... software version: C140BNGA1 hardware revision: XXXXXXXX hardware id: ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ imei: 0000000000000001 working... operaton finished Ok Finished, time used: 27 sec Remove/Install battery now ! |
05-29-2007, 08:34 | #3 (permalink) | |
Product Supporter Join Date: Sep 2004 Location: *In the right way*
Member: 84268 Status: Offline Sonork: 100.114149 Thanks Meter: 2,569 | Quote:
your imei was changed; & our tool can't repair imei for this model yet | |
05-30-2007, 05:48 | #6 (permalink) |
Member: 185776 Status: Offline Thanks Meter: 73 | yes,i flashed with ust pro and rebuild imei,no result.here is log of UST PRO eading data from box... Activating test mode... Test mode activated OK! IMEI data not found, possible corrupted EEPROM! Write FULL FLASH to phone and try again... Security bypass failed! Elapsed Time (00:06) |
05-30-2007, 08:10 | #7 (permalink) | |
08-16-2009, 13:38 | #9 (permalink) |
No Life Poster Join Date: Jul 2005 Location: Mobile solution at Pak_Lahore Age: 46
Member: 158032 Status: Offline Thanks Meter: 331 | check this link man http://forum.gsmhosting.com/vbb/atta...9&d=1250425960 |
n95 (rm-159) strang problem | Tayyab_raja777 | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 2 | 04-21-2010 09:01 |
I8510 strang problem | naslejavan | QUALCOMM Models (3G) | 4 | 03-30-2010 09:32 |
n95 (rm-159) strang problem | Tayyab_raja777 | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 1 | 03-29-2010 14:45 |
strange c139.strange problem | vodafone_banha | Infinity-Box | 13 | 10-15-2007 17:17 |
Samsung C100 Strange Strange Problem | sonu_nigam | Samsung Hardware Repair | 0 | 09-16-2005 10:12 |
