Welcome to the GSM-Forum forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! If you have any problems with the registration process or your account login, please contact contact us. |
| Register | FAQ | Donate | Forum Rules | ★. iPhone Unlock .★ | -= JTAG BOOM =- | Search | Today's Posts | Mark Forums Read |
| | #1 (permalink) |
| No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Jul 2006 Location: Authorised of SAMSUNG & HUAWEI
Member: 310155 Status: Offline Sonork: 100.1589262 Thanks: 37
| C168 dead ! hi all. i have a motorola c168 restart phone. i flashed it with infinity. now it is dead. here is log................................. COM9 [VCP1] selected Device: Motorola C168 Checking data, wait... Action: flash write Write: Firmware Write: Flex Write: Language Pack Skip: FFS/File system Write: Images Write: Melody Skip: Eeprom Boot... Phone should be Switched OFF ! Press Power button now ! Connecting... Boot Done Check Connection... Check Connection Done Set Baud... 812500 Set Baud Done Check Flash... SW ver: HW ver: Check Flash Done Check Parameters... Check Parameters Done Check Space... Flash: 0089:886400010001 flash: Intel 28F640W18-T T 8Mb Check Space Done Check Data... Check Data Done Erasing... erase operation not required Erasing Done Writing... Write: Firmware Flash: 0089:886400010001 flash: Intel 28F640W18-T T 8Mb error: answer#00 try#1 to recover write error at 00000000 error: error checksum try#2 to recover write error at 00000000 error: error try#3 to recover write error at 00000000 error: answer#00 try#4 to recover write error at 00000000 error: answer#00 try#5 to recover write error at 00000000 error: answer#00 try#6 to recover write error at 00000000 error: answer#00 try#1 to recover write error at 00002000 error: answer#00 try#2 to recover write error at 00002000 error: answer#00 try#3 to recover write error at 00002000 error: answer#00 try#4 to recover write error at 00002000 error: answer#00 try#5 to recover write error at 00002000 error: answer#00 try#6 to recover write error at 00002000 error: answer#00 try#1 to recover write error at 00004000 error: answer#00 try#2 to recover write error at 00004000 error: answer#00 try#3 to recover write error at 00004000 error: answer#00 try#4 to recover write error at 00004000 error: answer#00 try#5 to recover write error at 00004000 error: answer#00 try#6 to recover write error at 00004000 error: answer#00 try#1 to recover write error at 00006000 error: answer#00 try#2 to recover write error at 00006000 error: answer#00 try#3 to recover write error at 00006000 error: answer#00 try#4 to recover write error at 00006000 error: answer#00 try#5 to recover write error at 00006000 error: answer#00 try#6 to recover write error at 00006000 error: answer#00 try#1 to recover write error at 00008000 error: answer#00 try#2 to recover write error at 00008000 error: answer#00 try#3 to recover write error at 00008000 error: answer#00 try#4 to recover write error at 00008000 error: answer#00 try#5 to recover write error at 00008000 error: answer#00 try#6 to recover write error at 00008000 error: answer#00 try#1 to recover write error at 0000A000 error: answer#00 try#2 to recover write error at 0000A000 error: answer#00 try#3 to recover write error at 0000A000 error: answer#00 try#4 to recover write error at 0000A000 error: answer#00 try#5 to recover write error at 0000A000 error: answer#00 try#6 to recover write error at 0000A000 error: answer#00 try#1 to recover write error at 0000C000 error: answer#00 try#2 to recover write error at 0000C000 error: answer#00 try#3 to recover write error at 0000C000 error: answer#00 try#4 to recover write error at 0000C000 error: answer#00 try#5 to recover write error at 0000C000 error: answer#00 try#6 to recover write error at 0000C000 error: answer#00 try#1 to recover write error at 0000E000 error: answer#00 try#2 to recover write error at 0000E000 error: answer#00 try#3 to recover write error at 0000E000 error: answer#00 try#4 to recover write error at 0000E000 error: answer#00 try#5 to recover write error at 0000E000 error: answer#00 try#6 to recover write error at 0000E000 Writing Fail Finished, time used: 399 sec Remove/Install battery now ! |
| | #3 (permalink) |
| thanks infinity. my phone is now alive. the phone want with sim-card "Specific IMSI PUK:" here is some code............. COM9 selected Model: Motorola C168 Action: read unlock codes Phone must be POWERED-ON ! Connecting, wait... Phone connected. Working... imei: 3519550164723449 file saved: backup_unlock_log_3519550164723449_20070923-123158.69F.bin detecting codes... net [active]: 00800101 net sub [inactive]: 10010005 sp [active]: 63146314 corp [active]: 63146314 pck [active]: 46314631 fs [active]: 345005 phone code: 3123439 Finished this code not recive the phone.................... |
| | #5 (permalink) |
| sir. i alrady did "repair unauthorized" COM9 selected Device: Motorola C168 Checking data, wait... Action: unlock (prepare) Boot... Phone should be Switched OFF ! Press Power button now ! Connecting... Boot Done Check Connection... Check Connection Done Set Baud... 812500 Set Baud Done Check Flash... SW ver: 1490-000 HW ver: TCT-9- Check Flash Done Check Parameters... file saved: backup_eeprom_calibration_20070923-162044.69E.bin file saved: backup_repair_20070923-162047.69F.bin error: already repaired Check Parameters Fail Finished, time used: 21 sec Remove/Install battery now ! can u please say that which flash file will be used for solved this problem ??? |
| | #6 (permalink) | |
| Freak Poster ![]() ![]() ![]() ![]() Join Date: Sep 2007 Location: bd
Member: 596177 Status: Offline Thanks: 20
| Quote:
i have thia problem. i cant unlock my C168 phone. please help. | |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| help c168 dead!!!!!!!!!!!!! | GSM PAVIA | Infinity-Box | 13 | 06-13-2008 17:19 |
| c168 dead | enterprises | Infinity-Box | 27 | 04-24-2007 03:02 |
| motorola C168 dead help | therocky8 | Infinity-Box | 3 | 11-29-2006 09:35 |
| C168 dead in change language | ARC | Infinity-Box | 9 | 11-23-2006 17:36 |
| c168 dead for unlock | gabriel148 | Infinity-Box | 11 | 11-11-2006 17:29 |
