11-21-2006, 12:54 | #1 (permalink) |
No Life Poster Join Date: Jun 2001 Location: UAE Age: 43
Member: 5019 Status: Offline Sonork: 100.110196 Thanks Meter: 69 | C168 dead in change language I change lang. on a c168 and it went dead after that i tried firmware,lp,flex,ffs and everything, but my phone doesn't come alive again. any help? ---------------- Log opened: [11/21/2006] [2:32:33 PM] App: D:\DOWNLOADS\Infinity-Box\Moto02_v128\Moto02.exe Loading data, wait... [Infinity Box] v1.28 S/N: 0F------- Wait... Current model: C168 Done Loading file v.02... C168_LP_1190-008_T676FF_8V26_V1_En_Fr_Arabic_Farsi_Urdu.69P.bin Loaded COM1 selected Device: C168 Checking data, wait... Action: Read Eeprom Boot... Phone should be Switched OFF ! Press Power button now ! Connecting... Boot Done Check Connection... Check Connection Done Set Baud... Set Baud Done Check Flash... SW ver: 1390-000 HW ver: TCT-9- Check Flash Done Check Parameters... file saved: Backup_eeprom-01_2006-11-21_14-34-28.69E.bin file saved: Backup_eeprom-02_2006-11-21_14-35-37.69F.bin file saved: Backup_eeprom-03_2006-11-21_14-36-23.69E.bin Flash: 0020:8810FFFFFFFF Finished, time used: 175 sec Remove/Install battery now ! COM1 selected Device: C168 Checking data, wait... Action: Flash write Smart Write active Skip: Firmware Skip: Flex Write: Language Pack Skip: FFS/File system Skip: Images Skip: Melody Skip: Eeprom Boot... Phone should be Switched OFF ! Press Power button now ! Connecting... Boot Done Check Connection... Check Connection Done Set Baud... Set Baud Done Check Flash... SW ver: 1390-000 HW ver: TCT-9- Check Flash Done Check Parameters... Check Parameters Done Check Space... Flash: 0020:8810FFFFFFFF Check Space Done Check Data... Check Data Done Erasing... erase operation not required Erasing Done Writing... Write: Language Pack Flash: 0020:8810FFFFFFFF Writing Done Finished, time used: 155 sec Remove/Install battery now ! Loading file v.02... C168_Main_7-1280-000_2006-Feb-22.69M.bin Loaded Err: can't open COM1: 812500 Err: can't open COM1: 812500 Err: can't open COM1: 812500 Err: can't open COM1: 812500 Err: can't open COM1: 406250 COM3 ready COM3 selected Device: C168 Checking data, wait... Action: Flash write Smart Write active Write: Firmware Skip: Flex Write: Language Pack Skip: FFS/File system Skip: Images Skip: Melody Skip: Eeprom Boot... Phone should be Switched OFF ! Press Power button now ! Connecting... Boot Done Check Connection... Check Connection Done Set Baud... 812500 Set Baud Done Check Flash... SW ver: 1390-000 HW ver: TCT-9- Check Flash Done Check Parameters... Check Parameters Done Check Space... Flash: 0020:8810FFFFFFFF Check Space Done Check Data... Check Data Done Erasing... erase operation not required Erasing Done Writing... Write: Firmware Flash: 0020:8810FFFFFFFF Write: Language Pack Writing Done Finished, time used: 182 sec Remove/Install battery now ! Loading file v.02... Backup_eeprom-01_2006-11-21_14-34-28.69E.bin Loaded COM3 selected Device: C168 Checking data, wait... Action: Flash write Smart Write active Skip: Firmware Skip: Flex Skip: Language Pack Skip: FFS/File system Skip: Images Skip: Melody Write: Eeprom Boot... Phone should be Switched OFF ! Press Power button now ! Connecting... Boot Done Check Connection... Check Connection Done Set Baud... 812500 Set Baud Done Check Flash... SW ver: 1280-000 HW ver: TCT-7- Check Flash Done Check Parameters... Check Parameters Done Check Space... Flash: 0020:8810FFFFFFFF Check Space Done Check Data... Check Data Done Erasing... erase operation not required Erasing Done Writing... Write: Eeprom Flash: 0020:8810FFFFFFFF Writing Done Finished, time used: 25 sec Remove/Install battery now ! Loading file v.02... C168_Main_7-1280-000_2006-Feb-22.69M.bin Loaded Loading file v.02... C168_Flex_1280-007_T676FC_8V33_V1.69F.bin Loaded Loading file v.02... C168_LP_1190-008_T676FF_8V26_V1_En_Fr_Arabic_Farsi_Urdu.69P.bin Loaded Loading file v.02... C168_FileSystem_1450.69F.bin Loaded COM3 selected Device: C168 Checking data, wait... Action: Flash write Smart Write active Write: Firmware Write: Flex Write: Language Pack Write: FFS/File system Skip: Images Skip: Melody Skip: Eeprom Boot... Phone should be Switched OFF ! Press Power button now ! Connecting... Boot Done Check Connection... Check Connection Done Set Baud... 812500 Set Baud Done Check Flash... SW ver: 1280-000 HW ver: TCT-7- Check Flash Done Check Parameters... Check Parameters Done Check Space... Flash: 0020:8810FFFFFFFF Check Space Done Check Data... Check Data Done Erasing... erase operation not required Erasing Done Writing... Write: Firmware Flash: 0020:8810FFFFFFFF Write: Flex Write: Language Pack Write: FFS/File system Writing Done Finished, time used: 65 sec Remove/Install battery now ! Loading file v.02... C168_LP_1280-008_T676FF_8V33_V1_En_Fr_Arabic_Farsi_Urdu.69P.bin Loaded COM3 selected Device: C168 Checking data, wait... Action: Flash write Smart Write active Skip: Firmware Skip: Flex Write: Language Pack Skip: FFS/File system Skip: Images Skip: Melody Skip: Eeprom Boot... Phone should be Switched OFF ! Press Power button now ! Connecting... Boot Done Check Connection... Check Connection Done Set Baud... 812500 Set Baud Done Check Flash... SW ver: 1280-000 HW ver: TCT-7- Check Flash Done Check Parameters... Check Parameters Done Check Space... Flash: 0020:8810FFFFFFFF Check Space Done Check Data... Check Data Done Erasing... erase operation not required Erasing Done Writing... Write: Language Pack Flash: 0020:8810FFFFFFFF Writing Done Finished, time used: 70 sec Remove/Install battery now ! Loading file v.02... C168_Main_7-1280-000_2006-Feb-22.69M.bin Loaded Loading file v.02... C168_Flex_1280-007_T676FC_8V33_V1.69F.bin Loaded Loading file v.02... C168_FileSystem_1450.69F.bin Loaded COM3 selected Device: C168 Checking data, wait... Action: Flash write Smart Write active Write: Firmware Write: Flex Write: Language Pack Write: FFS/File system Skip: Images Skip: Melody Skip: Eeprom Boot... Phone should be Switched OFF ! Press Power button now ! Connecting... Boot Done Check Connection... Check Connection Done Set Baud... 812500 Set Baud Done Check Flash... SW ver: 1280-000 HW ver: TCT-7- Check Flash Done Check Parameters... Check Parameters Done Check Space... Flash: 0020:8810FFFFFFFF Check Space Done Check Data... Check Data Done Erasing... erase operation not required Erasing Done Writing... Write: Firmware Flash: 0020:8810FFFFFFFF Err: error flash command try#1 to recover erase error#43 Write: Flex Write: Language Pack Write: FFS/File system Writing Done Finished, time used: 36 sec Remove/Install battery now ! COM3 selected Device: C168 Checking data, wait... Action: Flash write Write: Firmware Write: Flex Write: Language Pack Write: FFS/File system Skip: Images Skip: Melody Skip: Eeprom Boot... Phone should be Switched OFF ! Press Power button now ! Connecting... Boot Done Check Connection... Check Connection Done Set Baud... 812500 Set Baud Done Check Flash... SW ver: 1280-000 HW ver: TCT-7- Check Flash Done Check Parameters... Check Parameters Done Check Space... Flash: 0020:8810FFFFFFFF Check Space Done Check Data... Check Data Done Erasing... erase operation not required Erasing Done Writing... Write: Firmware Flash: 0020:8810FFFFFFFF Err: error flash command try#1 to recover erase error#43 Write: Flex Write: Language Pack Write: FFS/File system Writing Done Finished, time used: 247 sec Remove/Install battery now ! |
11-21-2006, 13:20 | #2 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Just flash it with high firmware version all parts: main + lp + flex + images + melody. This problem (power on problems after downgrade/files mismatch) already was discussed time ago. |
11-21-2006, 13:34 | #3 (permalink) |
Member: 5019 Status: Offline Sonork: 100.110196 Thanks Meter: 69 | Thanks friend, i'm downloading ver 1390 main + lp + flex + images + melody cause the phone firmware before flashing was 1390 after flashing, i will give you result. |
11-21-2006, 13:56 | #4 (permalink) |
Member: 5019 Status: Offline Sonork: 100.110196 Thanks Meter: 69 | i flashed it with ver. 1390 no result , phone still dead any other idea? COM3 selected Device: C168 Checking data, wait... Action: Flash write Write: Firmware Write: Flex Write: Language Pack Skip: FFS/File system Write: Images Write: Melody Skip: Eeprom Boot... Phone should be Switched OFF ! Press Power button now ! Connecting... Boot Done Check Connection... Check Connection Done Set Baud... Set Baud Done Check Flash... SW ver: 1280-000 HW ver: TCT-7- Check Flash Done Check Parameters... Check Parameters Done Check Space... Flash: 0020:8810FFFFFFFF Check Space Done Check Data... Check Data Done Erasing... erase operation not required Erasing Done Writing... Write: Firmware Flash: 0020:8810FFFFFFFF Err: error flash command try#1 to recover erase error#43 Write: Flex Write: Language Pack Write: Images Write: Melody Writing Done Finished, time used: 815 sec Remove/Install battery now ! |
11-21-2006, 14:05 | #5 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | How about to try to flash with other files ? charge battery. be sure that you selected correct files set and also press and hold phone power button long time to power-on phone after flashing. |
11-21-2006, 20:06 | #7 (permalink) |
Member: 5019 Status: Offline Sonork: 100.110196 Thanks Meter: 69 | WARNING!!! You have exceeded daily download limits of 25 files.Please dont use any download accelator software as it will tamper with you limits. Please try again tommorrow. |
11-22-2006, 09:39 | #8 (permalink) |
No Life Poster Join Date: Jan 2005 Location: IN YOUR HEART
Member: 109163 Status: Offline Thanks Meter: 75 | Please check hardware. becz I flashed several pieces with diff version. also C168i supported Device: C168 Checking data, wait... Action: Flash write Smart Write active Write: Firmware Write: Flex Write: Language Pack Skip: FFS/File system Write: Images Write: Melody Skip: Eeprom Boot... Phone should be Switched OFF ! Press Power button now ! Connecting... Boot Done Check Connection... Check Connection Done Set Baud... 812500 Set Baud Done Check Flash... SW ver: 1020-000 HW ver: TTI-1- Check Flash Done Check Parameters... Check Parameters Done Check Space... Flash: 0089:886400010001 Check Space Done Check Data... Check Data Done Erasing... erase operation not required Erasing Done Writing... Write: Firmware Flash: 0089:886400010001 Write: Flex Write: Language Pack Write: Images Write: Melody Writing Done Finished, time used: 362 sec Remove/Install battery now ! |
11-22-2006, 17:20 | #9 (permalink) |
No Life Poster Join Date: Nov 2005 Location: .:GSM WORLD:.
Member: 203158 Status: Offline Sonork: 100.1592032 Thanks Meter: 358 | Flashed OK C168 C168_Main_9-1480-000_2006-Jun-30.69M C168_LP_1480-001_T676ER_8V17_V1_En_Cn.69P C168_Flex_1480-001_T676ER_8V18_V1.69F C168_FileSystem_1450.69F C168_Melody_1480-001_T676ER_8V18_V1.69G i Flashed with these Files to revive my phone ... and phone flashed ok .. |
11-23-2006, 18:36 | #10 (permalink) | |
Freak Poster Join Date: Sep 2004
Member: 81657 Status: Offline Thanks Meter: 0 | Quote:
COM1 selected Device: C168 Checking data, wait... Action: Flash write Smart Write active Write: Firmware Write: Flex Write: Language Pack Write: FFS/File system Skip: Images Write: Melody Skip: Eeprom Boot... Phone should be Switched OFF ! Press Power button now ! Connecting... Boot Done Check Connection... Check Connection Done Set Baud... Set Baud Done Check Flash... SW ver: 1390-000 HW ver: TCT-7- Check Flash Done Check Parameters... Check Parameters Done Check Space... Flash: 0089:886400010001 Check Space Done Check Data... Check Data Done Erasing... erase operation not required Erasing Done Writing... Write: Firmware Flash: 0089:886400010001 Write: Flex Write: Language Pack Write: FFS/File system Write: Melody Writing Done Finished, time used: 775 sec Remove/Install battery now ! B.R. | |
got problem in change language in c630 | afrar | Multi-box LITE | 1 | 03-07-2008 13:48 |
N70 Dead after changed language | mccm | MT-BOX | 4 | 07-07-2006 05:58 |
x300 dead after changing language | zata222 | Redbox | 10 | 04-04-2006 17:41 |
be4 dead after changing language . | makona | Alcatel & TCL Old Models | 5 | 11-16-2001 12:58 |
