c168 no net and restart made full flash and allso send auto save file to support mail after enter sim no network and phone auto restart waiting need help thanks |
Hello, Did you tried to make 112 call w/o sim ? Did you tried to check phonehardware, f.e. RF part ? |
@infinity phone is neat and clean no repair from inside checked and i repeat it restart on every 2 or 3 second so can not make call 112 without sim it works no restart waiting |
Hello, Of course, all phones that come for service/repair from customers always "clean". Could you, please, explain, what was the problem that customer described you ? also, I repeat important question: Did you tried to make 112 call without sim ? |
@infinity yup i made 112 but call failed phone came to me after enter sim unathorised phone and i have made options described in faq phone is ok but no network and restart and also send file backup on given mail id support |
@chiragp it's no need to send any backup to me. flash phone with high firmware version, use different repair eeprom files, make "repair unauthorized", make reset |
@infinity what is this error while writing diff eep but same Code: Write: Eeprom |
@infinity still waiting to complete the phone with every single eep from support ,i got the described error and flashing complete in 2 min full flash [main+lp+flx+image +melody] |
Flashing error: charge battery, try to repeat process several times. Probably you have a reason to flash phone with other flash files set. |
@infinity thanks for ur reply solved the falshing 2 min prob ,but the eep prob is same getting error tried all repair eep from support waiting |
Do you mean that flash write ok but eeprom can't be written ? If so, probably it's need to check phone hw, f.e. rehot flash chip. |
c168 i also have c168 hang proble phone was ok after flashing phone no network i can call 112 but no network.............. |
Today receive phone with Unauthorized phone . Repair Unauthorized phone OK. But phone restart and no network. Try to write Eprom and main firmware but not help. So try to write Full flash with higher version(Main+Flex+LP+images+melody) Now phone working fine. :):):) |
if no network check the supported frequency of phone u will see that c168 its 850/1900 Mhz and most networks use 900/1800 Mhz hence u have no network... ( ...only solution would be to convert it...like some other samsungs like x497....NOT SURE if solution is available for this one..search) hope this partially helps :) |
Try to use latest software to repair "unauthorized". Download http://www.infinity-box.com/download...odule_1.04.rar Flash main, flex, lang, melody, images, eeprom and then use "Repair" button |
