Old 06-06-2007, 11:13   #1 (permalink)
Cheater -Don't Deal with him-
chiragp's Avatar
Member: 106367
Sonork: 100.1577436
Thanks Meter: 2,452
Question c168 no net and restart
made full flash and allso send auto save file to support mail
after enter sim no network and phone auto restart
waiting need help
thanks
Old 06-06-2007, 12:01   #2 (permalink)
InfinitySupport's Avatar
Member: 130995
Thanks Meter: 34,397
Hello,
Did you tried to make 112 call w/o sim ?
Did you tried to check phonehardware, f.e. RF part ?
Old 06-06-2007, 12:05   #3 (permalink)
chiragp's Avatar
Member: 106367
Sonork: 100.1577436
Thanks Meter: 2,452
@infinity
phone is neat and clean no repair from inside checked and i repeat it restart on every 2 or 3 second
so can not make call 112
without sim it works no restart
waiting
Old 06-06-2007, 12:11   #4 (permalink)
Member: 130995
Hello,
Of course, all phones that come for service/repair from customers always "clean".
Could you, please, explain, what was the problem that customer described you ?
also, I repeat important question: Did you tried to make 112 call without sim ?
Old 06-06-2007, 13:22   #5 (permalink)
chiragp's Avatar
Member: 106367
Sonork: 100.1577436
Thanks Meter: 2,452
@infinity
yup i made 112 but call failed
phone came to me after enter sim unathorised phone and i have made options described in faq
phone is ok but no network and restart and also send file backup on given mail id support
Old 06-06-2007, 13:47   #6 (permalink)
Member: 130995
@chiragp
it's no need to send any backup to me.
flash phone with high firmware version, use different repair eeprom files, make "repair unauthorized", make reset
Old 06-06-2007, 18:49   #7 (permalink)
chiragp's Avatar
Member: 106367
Sonork: 100.1577436
Thanks Meter: 2,452
@infinity
what is this error while writing diff eep but same
Write: Eeprom
Boot...
Press Power button now !
Connecting...
Boot Done
Check Connection...
Check Connection Done
Set Baud...
Set Baud Done
Check Flash...
SW ver: 1120-000
HW ver: TCT-5-
Check Flash Done
Check Parameters...
Check Parameters Done
Check Space...
Flash: 0089:886400010001
flash: Intel 28F640W18-T T 8Mb
Check Space Done
Check Data...
Check Data Done
Erasing...
erase operation not required
Erasing Done
Writing...
Write: Eeprom
Err: error verify
try#1 to recover write error at 00780000
Err: flash end
try#2 to recover write error at 00780000
Err: answer#00
try#3 to recover write error at 00780000
Old 06-07-2007, 07:02   #8 (permalink)
chiragp's Avatar
Member: 106367
Sonork: 100.1577436
Thanks Meter: 2,452
@infinity
still waiting to complete the phone with every single eep from support ,i got the described error
and flashing complete in 2 min full flash [main+lp+flx+image +melody]
Old 06-07-2007, 12:32   #9 (permalink)
Member: 130995
Originally Posted by chiragp View Post
@infinity
Flashing complete in 2 min because you use "smart write" function enabled, in this case softare only verify flash chip content instead of write.
Flashing error: charge battery, try to repeat process several times.
Probably you have a reason to flash phone with other flash files set.
Old 06-07-2007, 13:47   #10 (permalink)
chiragp's Avatar
Member: 106367
Sonork: 100.1577436
Thanks Meter: 2,452
@infinity
thanks for ur reply
solved the falshing 2 min prob ,but the eep prob is same getting error
tried all repair eep from support
waiting
Old 06-07-2007, 15:16   #11 (permalink)
Member: 130995
Do you mean that flash write ok but eeprom can't be written ?
If so, probably it's need to check phone hw, f.e. rehot flash chip.
Old 10-06-2007, 09:57   #12 (permalink)
msmobile's Avatar
Member: 253882
Sonork: 100.1585698
Thanks Meter: 238
c168
i also have c168 hang proble phone was ok after flashing phone no network i can call 112 but no network..............
Old 10-10-2007, 10:19   #13 (permalink)
Member: 381241
Thanks Meter: 13
Today receive phone with Unauthorized phone . Repair Unauthorized phone OK. But phone restart and no network. Try to write Eprom and main firmware but not help. So try to write Full flash with higher version(Main+Flex+LP+images+melody) Now phone working fine.
Old 10-11-2007, 09:13   #14 (permalink)
Member: 8843
Thanks Meter: 117
if no network check the supported frequency of phone
u will see that c168 its 850/1900 Mhz and most networks use 900/1800 Mhz hence u have no network...
( ...only solution would be to convert it...like some other samsungs like x497....NOT SURE if solution is available for this one..search)
hope this partially helps
Old 10-11-2007, 14:55   #15 (permalink)
Member: 130995
Try to use latest software to repair "unauthorized". Download http://www.infinity-box.com/download...odule_1.04.rar
Flash main, flex, lang, melody, images, eeprom and then use "Repair" button
1202 and 1661 No service and Restart YAYAH SALMAN Nokia Hardware & Hardware Repair 6 11-23-2009 21:19
Nokia 6270 no network and restart problem haider Nokia Hardware & Hardware Repair 1 07-12-2006 17:25
NEC 338 No calls and restarting tical FuriousGold 3 07-05-2006 17:09
9210 no signal and restart after flash 936mw Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 0 09-22-2005 08:59
E330 No network and restarting tawanda SYSOL Platform 2 07-13-2005 08:58
Page generated in 0.39686 seconds with 8 queries
