05-28-2007, 13:03 | #1 (permalink) |
Freak Poster Join Date: Feb 2006 Location: sri lanka
Member: 230371 Status: Offline Sonork: 100.1614924 Thanks Meter: 52 | c168 says, specific IMSI PUK.....? not ok with any option with infinity , reset, user lock ,sp unlock. thanks... |
05-29-2007, 12:53 | #3 (permalink) |
Member: 230371 Status: Offline Sonork: 100.1614924 Thanks Meter: 52 | Thank you first reply my post..... I flashed without eeprom like below, COM26 selected Device: C168 Checking data, wait... Action: Flash write "smart write" active Write: Firmware Write: Flex Write: Language Pack Skip: FFS/File system Write: Images Write: Melody Skip: Eeprom Boot... Phone should be Switched OFF ! Press Power button now ! Connecting... Boot Done Check Connection... Check Connection Done Set Baud... Set Baud Done Check Flash... SW ver: 1430-000 HW ver: TCT-9- Check Flash Done Check Parameters... Check Parameters Done Check Space... Flash: 0089:886400010001 flash: Intel 28F640W18-T T 8Mb Check Space Done Check Data... Check Data Done Erasing... erase operation not required Erasing Done Writing... Write: Firmware Flash: 0089:886400010001 flash: Intel 28F640W18-T T 8Mb Write: Flex flash: Intel 28F640W18-T T 8Mb Write: Language Pack flash: Intel 28F640W18-T T 8Mb Write: Images flash: Intel 28F640W18-T T 8Mb Write: Melody flash: Intel 28F640W18-T T 8Mb Writing Done Finished, time used: 39 sec Remove/Install battery now ! then i write eeprom area and phone now stucked....only indicate motorola logo... please help me urgent.....thanks. Last edited by jayanthabandara; 05-30-2007 at 07:00. |
05-29-2007, 17:50 | #4 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! hard to read your log. but as i can see you skip File system writing please flash all 5 parts at once and post result from folder root/ flashfiles / Motorola / C168 / 1430 / C168_Flex_1430-234_PLND3_8V17_V1 C168_Images_1430-007_T676FC_8V49_V1 C168_LP_1430-016_T677YF_8V49_V1_En_Pl C168_Main_9-1430-000_2006-May-10 C168_Melody_1430-005_T676FB_8V49_V1 |
05-30-2007, 05:52 | #5 (permalink) | |
Member: 230371 Status: Offline Sonork: 100.1614924 Thanks Meter: 52 | Quote:
Thanks for reply again..... but my result same.... I have a problem....? where can i download , ffs/file sistem..?My logs below, COM26 selected Device: C168 Checking data, wait... Action: Flash write "smart write" active Write: Firmware Write: Flex Write: Language Pack Skip: FFS/File system Write: Images Write: Melody Skip: Eeprom Boot... Phone should be Switched OFF ! Press Power button now ! Connecting... Boot Done Check Connection... Check Connection Done Set Baud... Set Baud Done Check Flash... SW ver: 1430-000 HW ver: TCT-9- Check Flash Done Check Parameters... Check Parameters Done Check Space... Flash: 0089:886400010001 flash: Intel 28F640W18-T T 8Mb Check Space Done Check Data... Check Data Done Erasing... erase operation not required Erasing Done Writing... Write: Firmware Flash: 0089:886400010001 flash: Intel 28F640W18-T T 8Mb Write: Flex flash: Intel 28F640W18-T T 8Mb Write: Language Pack flash: Intel 28F640W18-T T 8Mb Write: Images flash: Intel 28F640W18-T T 8Mb Write: Melody flash: Intel 28F640W18-T T 8Mb Writing Done Finished, time used: 39 sec Remove/Install battery now ! I hope help me again..... Thanks..... Last edited by jayanthabandara; 05-30-2007 at 07:21. | |
05-31-2007, 10:15 | #7 (permalink) | |
No Life Poster Join Date: Oct 2005 Location: pakistan
Member: 188374 Status: Offline Sonork: 1000.2 Thanks Meter: 203 | Do You Repair Imei??????? Quote:
(i repair prepare) Then Phone Show <<<specific IMEI PUK>>> i Repair imei then ,user lock, reset, sp unock, all done, Try This And Post Result. | |
05-31-2007, 11:34 | #8 (permalink) | |
Thanks for first help to me , I did your steps also give some errors... detail below, COM26 selected Device: C168 Checking data, wait... Action: Unlock (prepare) Boot... Phone should be Switched OFF ! Press Power button now ! Connecting... Boot Done Check Connection... Check Connection Done Set Baud... Set Baud Done Check Flash... SW ver: 1430-000 HW ver: TCT-9- Check Flash Done Check Parameters... error: already prepared, ready for other operations Check Parameters Fail Finished, time used: 17 sec Remove/Install battery now ! COM26 selected Model: C168 Action: read unlock codes Phone must be POWERED-ON ! Connecting, wait... Phone connected. Working... imei: 8200135474000043 error: probably phone not ready, make "Prepare" operation first ! Finished I did flash evry steps and eeprom area also. Then display stucked and motorola logo only...... Did not you think it is eeprom erea problem..? PLS, help me........ Thanks. | |
06-25-2007, 17:20 | #12 (permalink) |
Insane Poster Join Date: Aug 2003 Location: lusaka, zambia
Member: 37104 Status: Offline Thanks Meter: 8 | try and change flash files versions and it will work.i had a similar problem but i kept on changing flash files untill it worked,till now its 100% fine. |
specific imsi puk in w220 | ras | Infinity-Box | 7 | 10-06-2007 07:51 |
w220 ask 4 specific imsi puk | surajrasaq | Infinity-Box | 0 | 08-19-2007 08:42 |
w 220 specific IMSI PUK | dilip kumar j | Ultima Box Light | 0 | 07-23-2007 10:03 |
please help, w220 specific IMSI PUK : | 081372002070 | Ultima Box Light | 23 | 05-13-2007 20:14 |
C168: specific imsi puk | bamogil | Infinity-Box | 4 | 03-04-2007 15:58 |
