12-01-2007, 17:30 | #1 (permalink) |
No Life Poster Join Date: Mar 2006 Location: india
Member: 239168 Status: Offline Thanks Meter: 104 | C168 ""unauthoridsed Phone""-tried Repair And Flash -no Scope FIRST I DID REPAIR. LOGS AS BELOW COM2 [Serial0] selected Device: Motorola C168 "advanced chip detection" active Action: repair Checking data, wait... Boot... Phone should be Switched OFF ! Press Power button now ! loading... Boot Done Check connection... Check connection Done Set baud... Set baud Done Check flash... flash: 89886400010001:89886400000000 flash: Intel Intel std [def 007Fx010000 0008x002000] 8Mb version sw: 1490-000 version sw: TCT-9- Check flash Done Check parameters... reading Motorola C168_eeprom_calibration-1... file saved: backup_Motorola C168_eeprom_calibration-1_20071201-075817.69E.bin Check parameters Done Check data... Check data Done Writing... ......data prepared Ok flash: 89886400010001:89886400000000 Write: eeprom Writing Done Finished, time used: 19 sec Remove/Install battery now ! STILL IN ""UNAUTHORISED PHONE"" SO I FLASHED USING FILES IN 1490 DIRECTORY IN SUPPORT-STILL NO SCOPE-LOGS AS BELOW COM2 [Serial0] selected Device: Motorola C168 "advanced chip detection" active Action: flash write "smart write" active Write: Firmware Write: Flex Write: Language Pack Skip: FFS/File system Write: Images Write: Melody Skip: Eeprom Checking data, wait... Boot... Phone should be Switched OFF ! Press Power button now ! loading... Boot Done Check connection... Check connection Done Set baud... Set baud Done Check flash... flash: 89886400010001:89886400000000 flash: Intel Intel std [def 007Fx010000 0008x002000] 8Mb version sw: 1490-000 version sw: TCT-9- Check flash Done Check parameters... reading Motorola C168_eeprom_calibration-1... file saved: backup_Motorola C168_eeprom_calibration-1_20071201-081500.69E.bin Check parameters Done Check data... Check data Done Writing... Area: Firmware flash: 89886400010001:89886400000000 Write: Firmware Area: Flex flash: 89886400010001:89886400000000 Write: Flex Area: Language Pack flash: 89886400010001:89886400000000 Write: Language Pack Area: Images flash: 89886400010001:89886400000000 Write: Images Area: Melody flash: 89886400010001:89886400000000 Write: Melody Writing Done Finished, time used: 52 sec Remove/Install battery now ! STILL IN ""UNAUTHORISED PHONE"" I SAW SOME REPAIR EEPROMS IN SUPPORT-BUT DID NOT TRY--WHAT I DO AS A NEXT STEP? THANK U |
N95 "nokia Blinking"-erased Using Unirapido File-then Flashed-no Scope-help Me | zone2 | MT-BOX | 18 | 12-16-2007 19:20 |
E335 When Power On Turn Off Immediatley-flashed-no Scope | zonetrichur | UST Pro II | 8 | 01-18-2007 13:47 |
1112 "contact Service "-flashed -no Scope | zonetrichur | MT-BOX | 6 | 01-01-2007 11:39 |
