Old 10-11-2006, 15:19   #1 (permalink)
InfinitySupport's Avatar
Member: 130995
Thanks Meter: 34,453
C257, C261, V175-V177 Unlock, Repair
Respected Infinity-Box users,
Due to huge amount of double posts in old subj related threads and total users ignorance of any advice to read old threads, here we collect most important information about C257, C261, V175, V176, V177 unlocking and repair.
Old threads located here:
C257, C261, V175, V176, V177 Information, Unlock, Repair
c261 problem
UPDATE 22 May 2006: C257, C261, V175, V176, V177, C115i sp-unlock
Most important manuals attached, please, read it before ask. If you don't see attached files or can't download it: login in forum before download.
More manuals available in www.infinity-box.com support area.
Known problems: as you know, currently not possible to unlock some C257, C261, V175, V176, V177.
If during unlock process you see in software log window error messages like:
"Err: this hardware not supported yet"
"Err: this unit can't be unlocked"
this means that currently we have no methods to unlock this phone.
Please, no need to send to us backup files from phones that can't be unlocked. Backup from sp-locked phone can't help us to unlock it.
Please, don't ask us privately to unlock phones that can't be unlocked. We will ignore all this kind of questions.
Unlock result (success or failure) depends on the next things:
.not depends on phone Firmware version
.not depends on phone Language Pack version
.not depends on phone Flex version
.not depends on network operator that phone is locked
.depends on your luck only
If you can't find required special Flex file in support area:
find original phone locked to the same network, read flash from it, send it to [email protected] and we will prepare special Flex file to repair your phone.
DON'T send me any flash backup from damaged phone !
If your phone can't Power-On (dead) or can't connect with software (dead):
1. Please, check battery voltage or check battery on other phone.
2. If battery Ok (and you know for sure that battery Ok): flash phone with Firmware + Flex + LP
3. If phone still can't Power On (dead): check phone hardware
4. If phone in "restart" condition: make repair procedure according to attached manual (also available in http://www.infinity-box.com support area)
TracFone customized phones: instruction attached.
For people who don't like to read manuals but want to see phones alive:
. Never flash sp-locked phones with any Flex files !
. It's no need to write any flex file in phone before unlock !
. Read unlock manual carefully and follow it exactly step-by-step !
Old 10-17-2006, 19:19   #2 (permalink)
Siemens man's Avatar
Member: 3925
Thanks Meter: 21
hi infinity
new version c261, not unlocked phones(Known problems: as you know, currently not possible to unlock some C257, C261, V175, V176, V177.
it's possible use c261track phone unlock solution????? tell me
thanks a lot
Old 10-17-2006, 19:28   #3 (permalink)
zinoubinabil's Avatar
Member: 84268
Sonork: 100.114149
Thanks Meter: 2,568
no track exist yet to unlock these phones ununlockable
if we have solution we will annonced here
Old 10-18-2006, 08:54   #4 (permalink)
freedomizer's Avatar
Member: 123931
Minor problem:
I have a restarting / moto-blinking phone. I tried to perform the revival ceremony, but got stuck with:
sp-locked: ‰4dbØ&`)Ô’Øĝ¹VGY]øù—é
so Obviusly there is no correct Flex file to flash it with. I flashed it with an Orange customized flex, but still blinking.
what is to be done?
Old 10-18-2006, 09:13   #5 (permalink)
Member: 130995
Originally Posted by freedomizer View Post
Minor problem:
sp-locked: 4db&`)ԒĝVGY]
what is to be done?
Hi,
Security area serious damaged and I'm not sure that it will be possible to repair this phone.
What to do: make eeprom backup and send to [email protected]
I'll check it and let you know about repair possibility. But I can't promise anything.
Old 10-18-2006, 15:02   #6 (permalink)
Crazy Poster
Member: 174780
Motorola C261 And V177 Problem
HELLO
Please I need to unlock the MOTO C177 new version OPERATOR SWISS COM and C261 restart problem same operator
Please help me to solvever this problme
Thanks
Old 10-18-2006, 16:44   #7 (permalink)
Member: 130995
Originally Posted by gsmobile1 View Post
HELLO
Thanks
Day by day we can see here people who don't want to read first message in this thread but want to write only.
Dear Friend,
Please, don't be so lazy and please read first message in this thread.
Old 10-24-2006, 10:56   #8 (permalink)
Member: 96950
Thanks Meter: 3
can't connect to C261
hi i am using infinity and have read the posts, but i get as far as press and hold power, and thats it, for some reason i cant connect, can do other phones through infinity, using a T191 cable, is this wrong, or is it a special cable?
thanks
jason
Old 10-24-2006, 11:13   #9 (permalink)
Member: 123931
thanks
jason
try pana x60 cable that came with infinity, i had problems with a t191 cable -- only connected at times.
Old 10-24-2006, 11:20   #10 (permalink)
Member: 130995
thanks
jason
Sorry, I did not understand the problem. Could you please give me more info:
text from log window
phone software version (#02#)
Old 10-24-2006, 11:37   #11 (permalink)
Member: 96950
Thanks Meter: 3
Software is:
001A0132
609233079251
WHO:sw_cm
Time:
Thu Dec 15 19:30:55 2005
SW Ver: 0.1.32
Version info:
Code.90.01
Boot.90.05
FMGR.90.39
Flex_90_64_4H08
Langpack:LP1_0132
Chip Ver X
thanks
jason
Old 10-24-2006, 11:47   #12 (permalink)
Member: 96950
Thanks Meter: 3
Software is:
001A0132
609233079251
WHO:sw_cm
Time:
SW Ver: 0.1.32
Version info:
Code.90.01
Boot.90.05
FMGR.90.39
Flex_90_64_4H08
Langpack:LP1_0132
Chip Ver X
thanks
jason
COM1 selected
Action: Unlock
Flex file must be loaded before operation, trying to load Flex file...
Loading file [version 01]...
C261_Flex_90_62_3C01.34F.bin Loaded
Device: C261
Checking data, wait...
Connect...
Press and HOLD Power button...
Old 10-24-2006, 11:58   #13 (permalink)
Member: 130995
It's ordinary phone firmware version, no any surprices.
Double check COM port selection and your cable. maybe cable hardware fault.
Old 10-24-2006, 12:03   #14 (permalink)
Member: 96950
Thanks Meter: 3
Use the same port, com one for VK yesterday, worked fine, tried T191 RJ45 and X60 cable, does the infinity box need to be set differently?
thanks
jason
Old 10-24-2006, 12:27   #15 (permalink)
Member: 61810
Sonork: 100.1605340
Thanks Meter: 136
thanks this a great guide..
* IMPORTANT * C257, C261, V175-V177 Unlock, Repair InfinitySupport Infinity-Box 20 07-07-2008 21:32
* IMPORTANT * C257, C261, V175-V177 Unlock, Repair InfinitySupport Infinity-Box 86 03-13-2007 12:01
* IMPORTANT * C257, C261, V175-V177 Unlock, Repair InfinitySupport Infinity-Box 72 01-10-2007 16:42
..:: FREE ADDON: Motorola Compal Tool v1.0 - C257, C261, V175-V177 ::.. zulea Motorola P2K (USB-Smart) 75 08-30-2006 15:50
..:: FREE ADDON: Motorola Compal Tool v1.0 - C257, C261, V175-V177 ::.. zulea SonyEricsson (USB-Smart) 21 08-16-2006 13:13
Page generated in 0.47827 seconds with 9 queries
