10-13-2007, 12:10 | #1 (permalink) |
No Life Poster Join Date: Aug 2002 Location: Croatia Age: 48
Member: 14602 Status: Offline Thanks Meter: 18 | c261 after unlock restart problem i try to repair it with special flex file from manual and no results...i trz to full flash phone with main,lang,flex and eeprom and same thing again....here i s log Application: C:\Program Files\InfinityBox\Moto01\Moto01.exe Loading data, wait... [Infinity Box] v1.42 S/N: 032D:010A Current model: C113(a),C114,C115,C116,C117,C118 Ready Current model: C261 COM13 selected Action: unlock Device: C261 Checking data, wait... Connect... Press and HOLD Power button... Connecting... initial boot phase complete Release Power button ! Connect Done Boot... Boot Done Set Baud... 115200 Set Baud Done Check Flash-1... SW version: 0.1.31 HW version: MOTOROLA_E58S LP ver: LP7_0131 Flex ver: FLEX_90_64_3U03 cpu id: 08B6 imei eeprom: 35860500321494 sp-locked: 21902.24007. Check Flash-1 Done Check Flash-2... reading ... file saved: backup_eeprom_calibration_35860500321494_20071012-162936.34E.bin unlock step-1 Ok unlock step-2 Ok unlock step-3 Ok unlock step-4 Ok unlock step-5 Ok error: errorcode#50: eeprom can't be erased Finished, time used: 35 sec Remove/Install battery now ! COM13 selected Action: unlock Device: C261 Checking data, wait... Connect... Press and HOLD Power button... Connecting... initial boot phase complete Release Power button ! Connect Done Boot... Boot Done Set Baud... 115200 Set Baud Done Check Flash-1... SW version: 0.1.31 HW version: MOTOROLA_E58S LP ver: LP7_0131 Flex ver: FLEX_90_64_3U03 cpu id: 08B6 operation canceled Finished, time used: 25 sec Remove/Install battery now ! COM13 selected Action: unlock Device: C261 Checking data, wait... Connect... Press and HOLD Power button... Connecting... initial boot phase complete Release Power button ! Connect Done Boot... Boot Done Set Baud... 115200 Set Baud Done Check Flash-1... SW version: 0.1.31 HW version: MOTOROLA_E58S LP ver: LP7_0131 Flex ver: FLEX_90_64_3U03 cpu id: 08B6 user confirmed unlock for non-locked phone Check Flash-1 Done Check Flash-2... reading ... file saved: backup_eeprom_calibration__20071012-163641.34E.bin unlock step-1 Ok unlock step-2 Ok unlock step-3 Ok unlock step-4 Ok error: unlock step-5.1 failed: A410 error: errorcode#10: can't find required data, eeprom damaged Finished, time used: 31 sec Remove/Install battery now ! ==== log opened: [10/12/2007 4:47:52 PM] ==== Application: C:\Program Files\InfinityBox\Moto01\Moto01.exe Loading data, wait... [Infinity Box] v1.42 S/N: 032D:010A Current model: C113(a),C114,C115,C116,C117,C118 Ready Current model: C261 ==== log opened: [10/12/2007 4:54:08 PM] ==== Application: C:\Program Files\InfinityBox\Moto01\Moto01.exe Loading data, wait... [Infinity Box] v1.42 S/N: 032D:010A Current model: C113(a),C114,C115,C116,C117,C118 Ready Current model: C261 Loading file v.01... C261_Flex_90_64_3U03_Locked_219-02_240-07.34F.bin loaded COM13 selected "smart write" active Action: flash Skip: Firmware Skip: Language Pack Write: Flex Skip: Eeprom Device: C261 Checking data, wait... Connect... Press and HOLD Power button... Connecting... initial boot phase complete Release Power button ! Connect Done Boot... Boot Done Set Baud... 115200 Set Baud Done Check Flash-1... SW version: 0.1.31 HW version: MOTOROLA_E58S LP ver: LP7_0131 Flex ver: FLEX_90_64_3U03 cpu id: 08B6 Check Flash-1 Done Check Flash-2... reading ... file saved: backup_eeprom_calibration__20071012-165641.34E.bin Check Flash-2 Done Write... Writing: Flex Write Done Finished, time used: 156 sec Remove/Install battery now ! Loading file v.01... C261_0.1.31_Main_E58S_1134468546.34M.bin loaded Loading file v.01... C261_0.1.31_LP7_Hrvatski_Serbian_Slovencina.34P.bi n loaded Loading file v.01... C261_Flex_90_62_3C01.34F.bin loaded COM13 selected "smart write" active Action: flash Write: Firmware Write: Language Pack Write: Flex Skip: Eeprom Device: C261 Checking data, wait... Connect... Press and HOLD Power button... Release Power button ! Connect Fail Failed ! Finished, time used: 9 sec Remove/Install battery now ! Loading file v.02... backup_eeprom_calibration_35860500321494_20071012-162936.34E.bin loaded COM13 selected "smart write" active Action: flash Write: Firmware Write: Language Pack Write: Flex Write: Eeprom Device: C261 Checking data, wait... Connect... Press and HOLD Power button... Connecting... initial boot phase complete Release Power button ! Connect Done Boot... Boot Done Set Baud... 115200 Set Baud Done Check Flash-1... SW version: 0.1.31 HW version: MOTOROLA_E58S LP ver: LP7_0131 Flex ver: FLEX_90_64_3U03 cpu id: 08B6 Check Flash-1 Done Check Flash-2... reading ... file saved: backup_eeprom_calibration__20071012-170631.34E.bin Check Flash-2 Done Write... Writing: Firmware Writing: Language Pack Writing: Flex Writing: Eeprom Write Done Finished, time used: 1309 sec Remove/Install battery now ! |
12-29-2007, 23:14 | #4 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, Try to charge battery with external power supply. I don't see any reason why phone can't power-on if you have restored original eeprom backup. |
12-30-2007, 01:11 | #5 (permalink) | |
No Life Poster Join Date: Apr 2006 Location: United States Age: 50
Member: 259133 Status: Offline Thanks Meter: 22 | Quote:
but now goes up and shows 0.00 minutes, i think i have to flash it with a different firmware, what do you suggest? | |
12-30-2007, 08:48 | #6 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | @lacasapc As I can understand you have flashed phone with Tracfone firmware. Is it right ? Now you must flash phone with ordinary files set (f.e. main + Lp + flex ver 0.1.32) and after flashing make "unlock" procedure again. |
Moto C261 after unlock display phone hack. | karlleeto | Infinity-Box | 2 | 08-03-2009 07:38 |
Signal prob.C261 after unlock | Abidqadeer | Motorola P2k | 2 | 02-18-2009 12:06 |
C261 after flash restart on Motorola logo | ahmad bashir | Infinity-Box | 6 | 02-02-2009 10:46 |
KG290 after unlock restarting problem | Y2ksalman | Infinity-Box | 6 | 06-16-2008 11:38 |
c261 after unlock restart problem | SGHGSM 3 | Infinity-Box | 2 | 02-01-2007 07:28 |
