Old 10-04-2006, 12:57   #1 (permalink)
Member: 61861
C261 Blinking at start-up (When the phone is power ON)
Things I have been done…
1) As per normal I do the selection file below and flash, after flash the phone always blinking at startup mode HELLOMOTO????
2) Then I try another solution with selected of the Flex file C261_Flex_90_64_3P02_Locked_260-01[1].34F to my phone but still cannot solve the problem, Please help about this? It is possible to make.
3) Here i attach with some application program pictures with file i do selection, hopefully will help your understanding more.
Loading data wait...
S/N: XXXX:XXXX
Standard firmware detected
Current model: C113,C115,C116,C117,C118
Ready
Current model: C261
COM8 ready
Loading file [version 02]...
C261_0.1.66_Main_E58S.34M.bin Loaded
Loading file [version 01]...
C261_Flex_90_62_3C01.34F.bin Loaded
C261_0.1.66_LPA1_En_Malaysia_Cn.34P.bin Loaded
COM8 selected
Action: Flash
Write: Firmware
Write: Flex
Write: Language Pack
Skip: Eeprom
"Smart Write" active
Device: C261
Checking data, wait...
Connect...
Press and HOLD Power button...
Connecting...
initial boot phase complete
Release Power button !
Connect Done
Boot...
Boot Done
Set Baud...
921600
Set Baud Done
Check Flash-1...
SW ver: 0.1.66
HW ver: MOTOROLA_E58S
LP ver: LPA1_0166
Flex ver: FLEX_90_62_3C01
cpu id: 08B6
imei: 35860500448873
sp-locked: 26001.
Check Flash-1 Done
Check Flash-2...
Check Flash-2 Done
Write...
Writing: Firmware
Writing: Flex
Writing: Language Pack
Write Done
Finished
Remove/Install battery now !
Time used: 437 sec
Old 10-04-2006, 13:03   #2 (permalink)
InfinitySupport's Avatar
Member: 130995
Hello,
Solution about "restart" problem repair described here:
C257, C261, V175, V176, V177 Information, Unlock, Repair
To repair your phone:
write only one file in phone: C261_Flex_90_64_3P02_Locked_260-01
Old 10-05-2006, 05:59   #3 (permalink)
Member: 61861
Flash with C261_Flex_90_64_3P02_Locked_260-01 stil cannot
Hello, Mr infinitySupport the result after flash still the same, any solution?
Attach with some pictures
Old 10-05-2006, 06:20   #4 (permalink)
Member: 130995
Please, no need to make screenshots because its useles and simple copy/paste of log text is much more useful.
try to flash firmware v0.1.66 and flex 260-01 again.
if after flash with 260-01 flex + firmware your phone still restart I think you have a reason to check phone hardware.
Old 10-06-2006, 06:04   #5 (permalink)
Member: 61861
subsidy Password Request???
Hello, Mr InfinitySupport sorry to put a lot of pictures from that to trouble U.
What u mention is flash back to the version u metion, the phone is life back but that request subsidy password. I do unlock process but fail to do that, here i attach the log detail for U reference. Thank U.
COM8 selected
Action: Unlock
Device: C261
Connect...
Connecting...
Connect Done
Boot...
Boot Done
Set Baud...
921600
Set Baud Done
Check Flash-1...
SW ver: 0.1.66
LP ver: LPA1_0166
Flex ver: FLEX_90_64_3P02
cpu id: 08B6
sp-locked: 26001.
Check Flash-1 Done
Check Flash-2...
In progress...
file saved: Backup_eeprom-1_35860500448873_2006-10-6_12-56-45.34E.bin
Err: this unit can't be unlocked
Check Flash-2 Fail
Finished
Time used: 37 sec
Old 10-06-2006, 06:26   #6 (permalink)
Member: 130995
....45.34E.bin
Check Flash-2 Fail
Finished
Time used: 37 sec
Hello,
Please, check this:
A867 blink at start-up after flash. sonu` Z3X-Team Products 8 01-26-2010 10:22
bb 8100 pearl Red Cross on the battery at start up mohit_kripalu01 BlackBerry (RIM) 4 10-29-2009 14:20
K-700i Hang on Start up when we select the Language........ MUNEEB_AKHTAR_RAZA Cruiser Suite 31 09-15-2008 20:36
Nokia 5200 is rebooting at start-up debiany Nokia Base Band 5 ( BB-5 ) 6 09-13-2008 03:41
Samsung A300: stupid tone when the phone starts up sgha300 VLSI, Conexant, Skyworks and Old Models 0 02-22-2002 07:26
Page generated in 0.62723 seconds with 11 queries
