03-05-2007, 09:09 | #1 (permalink) |
Junior Member Join Date: Jan 2007
Member: 427386 Status: Offline Thanks Meter: 0 | C261 Restart help COM20 selected Action: unlock Flex file must be loaded before unlock operation. Please refer to unlock instruction/manual for more details ! Do you want to continue and load Flex file now ? trying to load Flex file... Loading file v.02... C261_Flex_90_62_3C01.34F.bin Loaded Device: C261 Checking data, wait... Connect... Press and HOLD Power button... Connecting... initial boot phase complete Release Power button ! Connect Done Boot... Boot Done Set Baud... 921600 Set Baud Done Check Flash-1... SW version: 0.1.66 HW version: MOTOROLA_E58S LP ver: LP2_0166 Flex ver: FLEX_90_64_3107 cpu id: 08B6 imei eeprom: 35941600719240 required SW version: 0.1.66 Err: phone is not locked, operation terminated. Check Flash-1 Fail Finished, time used: 23 sec Remove/Install battery now ! Then I search with key " C261 restart " found several post about but i can't clear my problem. Every time supporter giving this link 1. Make “Unlock” (exactly like described in unlock instruction) if software unlock phone withouto problem: phone repaired and unlocked. if software can't unlock phone go to step 2. 2. Check log file/window after unlock process and find text like this: "sp-locked: 46000.46002". This means that phone locked to 460-00 and 460-02 network and it's need to write special Flex file (in this example correct repair Flex file is: C261_Flex_90_64_3009_Locked_460-00_460-02) into phone. After writing special Flex file: phone repaired but still locked (and currently we have no methods to unlock it). If you can't find required special Flex file in support area: find original phone locked to the same network, read flash from it, send it to [email protected] and we will prepare special Flex file to repair your phone. I read this post but i can't find any where about restart. this only about locked. Infinity supporter I need Help. |
03-05-2007, 09:55 | #2 (permalink) |
Member: 427386 Status: Offline Thanks Meter: 0 | look another COM20 selected Action: unlock Device: C261 Checking data, wait... Connect... Press and HOLD Power button... Connecting... initial boot phase complete Release Power button ! Connect Done Boot... Boot Done Set Baud... 921600 Set Baud Done Check Flash-1... SW version: 0.1.44 HW version: MOTOROLA_E58S LP ver: LPLA_0144 Flex ver: FLEX_90_62_3C01 cpu id: 08B6 required SW version: sp-locked: ÀÀÀÀÀÀÀÀÀÀ Check Flash-1 Done Check Flash-2... reading ... file saved: backup_eeprom_calibration__2007-3-5_12-49-36.34E.bin Err: non-locked or unknown eeprom, error#1 Check Flash-2 Fail Finished, time used: 75 sec Remove/Install battery now ! |
03-05-2007, 10:38 | #4 (permalink) | |
Product Supporter Join Date: Sep 2004 Location: *In the right way*
Member: 84268 Status: Offline Sonork: 100.114149 Thanks Meter: 2,569 | Quote:
03-05-2007, 13:52 | #5 (permalink) |
Member: 427386 Status: Offline Thanks Meter: 0 | YES zinoubinabil CAN YOU CHECK MY LOG AND TELL ME WHERE IS LOCKED.. ( Check log file/window after unlock process and find text like this: "sp-locked: 46000.46002". This means that phone locked to 460-00 and 460-02 network and it's need to write special Flex file (in this example correct repair Flex file is: C261_Flex_90_64_3009_Locked_460-00_460-02) into phone) |
03-05-2007, 17:36 | #7 (permalink) |
Member: 427386 Status: Offline Thanks Meter: 0 | hi now phone hacked COM20 selected Action: unlock Device: C261 Checking data, wait... Connect... Press and HOLD Power button... Connecting... initial boot phase complete Release Power button ! Connect Done Boot... Boot Done Set Baud... 921600 Set Baud Done Check Flash-1... SW version: 0.1.76 HW version: MOTOROLA_E58S LP ver: LPLA_0175 Flex ver: FLEX_90_63_5204 cpu id: 08B6 imei eeprom: 35941600719240 required SW version: 0.1.76 Err: phone is not locked, operation terminated. Check Flash-1 Fail Finished, time used: 14 sec Remove/Install battery now ! |
03-06-2007, 09:16 | #9 (permalink) |
Member: 427386 Status: Offline Thanks Meter: 0 | if you don't mind iam stopping repair my this(C261) phone. I buy infinity when i get this phone. now iam confused, because iam a new user. i don't know how flash and other procedure. well, thanks to supporter and infinity for fast support. chotadevil |
C261 Blinking at Hello Moto and Restart Help | dog_baby | Infinity-Box | 11 | 05-16-2007 13:12 |
C261 Restarts Continously | dannyogolo | Infinity-Box | 2 | 11-13-2006 16:40 |
c261 restart after wrong unlock | .::i-M Legend::. | Infinity-Box | 1 | 10-12-2006 09:27 |
i have 1 pieces motorola c261 restart problem | aurelmarius1 | Infinity-Box | 2 | 08-28-2006 14:30 |
C261 restart problem.. please help.. | dlanor0221 | Infinity-Box | 0 | 06-18-2006 10:33 |
