08-21-2007, 17:20 | #1 (permalink) |
No Life Poster Join Date: Nov 2005 Location: Port Harcourt Nigeria Age: 51
Member: 197720 Status: Offline Thanks Meter: 24 | c261 unlock problem |
08-21-2007, 20:01 | #4 (permalink) |
Member: 197720 Status: Offline Thanks Meter: 24 | where do i get the backup i have looked for it to restore i cant find the folder please advise where i can get it i have fullflashed no good result still the same |
08-22-2007, 09:28 | #8 (permalink) |
Member: 197720 Status: Offline Thanks Meter: 24 | i have full flashed still the same problem is like the IMEI has be corrupted see the flashing log COM7 [VCP2] selected "smart write" active Action: flash Write: Firmware Write: Language Pack Write: Flex Skip: Eeprom Device: C261 Checking data, wait... Connect... Press and HOLD Power button... Connecting... initial boot phase complete Release Power button ! Connect Done Boot... Boot Done Set Baud... 230400 Set Baud Done Check Flash-1... SW version: 0.1.66 HW version: MOTOROLA_E58S LP ver: LP13_0166 Flex ver: FLEX_90_64_4102 cpu id: 08B6 required SW version: 0.1.66 Check Flash-1 Done Check Flash-2... reading ... file saved: backup_eeprom_calibration__20070822-010933.34E.bin Check Flash-2 Done Write... Writing: Firmware Writing: Language Pack Writing: Flex Write Done Finished, time used: 29452 sec Remove/Install battery now ! |
08-22-2007, 09:44 | #9 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | It's not a hard to repeat instruction for you: 1. find in Moto01 folder eeprom file for your phone (it exist for sure due to was automatically created during first unlock try) 2. write eeprom backup in your phone 3. make unlock I hope it's enough clear explanation, anyway, if you will have any problems just ask your questions and we can repeat our advices. p.s. if you can't find eeprom file in folder with software this means that your initial problem description was not honest and you must explain problem exactly and explaine what tool you tried to use and what operations you tried to make. |
08-22-2007, 10:19 | #10 (permalink) |
Member: 197720 Status: Offline Thanks Meter: 24 | i have restored the eeprom but the phone still blinking i have been using infinity for the past eight months i have never experienced this kind of problem before please bear with me if am asking too much question |
08-22-2007, 18:19 | #13 (permalink) |
Freak Poster Join Date: Oct 2003 Location: PL Age: 37
Member: 40756 Status: Offline Thanks Meter: 1,224 | With Infnity You may easy repair phone too, but you must write the backup which is created when phone is unlocked not any backup from Moto01 folder You may find the name of backup in log file InfinitySupport say you what you must do in previous posts but you don't read carefull and rewrite full flash (why?). |
08-22-2007, 21:56 | #15 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | @sonetek it's not possible that phone did not returned to it's original state after restore eeprom backup. If you write in phone eeprom backup but phone not in it's original state this means that you did not write eeprom or you write not original eeprom. Each eeprom backup file created during unlock contain in file name imei and date/time when it was created so you can easily find required eeprom file. |
c261 unlock problem | kau | Infinity-Box | 1 | 01-24-2007 16:04 |
c261 unlock problem | irfaN_vu | Multi-Box | 3 | 12-27-2006 09:41 |
c261 unlock probleme | KARIM GSM-ZONE | Infinity-Box | 0 | 11-23-2006 23:02 |
C261 unlock problem | Jaypc | Motorola ODM | 0 | 10-15-2006 15:07 |
C261 Unlock Problem | Nasmi | Infinity-Box | 2 | 09-06-2006 22:40 |
