12-31-2006, 08:04 | #1 (permalink) |
No Life Poster Join Date: Mar 2006 Location: india
Member: 239168 Status: Offline Thanks Meter: 104 | C261 V0.1.66 "unlock Code"-tried-can Not I TRIED TO UNLOCK IN MOTO 01 V1.27-ERROR MESSAGE AS BELOW COM2 selected Device: C261 Device must be POWERED-ON ! Connecting, wait... Err: Phone not powered or bad connection THAT MEANS DID NOT CONNECT.I CHANGED CONNECTION IN SETTINGS FROM DEFAULT TO SECUREV CERTIFICATE 1 AND 2 -NO SCOPE-ERROR MESSAGE AS ABOVE ITS NOT CABLE PROBLEM-WHILE TRY TO UNLOCK SP LOCK GOT AS BELOW-AND I ALREADY BACK UP MEMORY USING SAME CABLE COM2 selected Action: Unlock Device: C261 Checking data, wait... Connect... Press and HOLD Power button... Connecting... initial boot phase complete Release Power button ! Connect Done Boot... Boot Done Set Baud... 115200 Set Baud Done Check Flash-1... SW version: 0.1.66 HW version: MOTOROLA_E58S LP ver: LP11_0166 Flex ver: FLEX_90_64_3906 cpu id: 08B6 imei: 35941600343168 Err: phone is not locked, operation terminated. Check Flash-1 Fail Finished, time used: 26 sec Remove/Install battery now ! THANK U |
upd. 1.7 fixed . now i can not "sign application" | thehelmut | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 3 | 03-23-2010 21:54 |
C118 "unlock code" its very difficult to reads | Y2ksalman | Infinity-Box | 3 | 03-22-2007 10:37 |
c261 0.1.66 ? | taariqmajid | Infinity-Box | 1 | 03-04-2007 16:45 |
L6i Tried-can Not-i Think Higher Version? | zonetrichur | Multi-Box | 5 | 01-09-2007 12:15 |
Motorola C261 v0.1.32 canīt unlock | pepik | Multi-Box | 3 | 11-16-2006 07:12 |
