Old 04-18-2009, 06:01   #1 (permalink)
Member: 733449
Sonork: 100.334100
Thanks Meter: 292
LG B2050 successfully formatted by infinity
LG B2050 successfully formatted by infinity.
Here is log
COM5 [VCP0] selected
module v1.38
Device: LG-B2050
Checking data, wait...
Action: reset
Boot ...
Connecting, wait...
Release Power button now !
flash: 2088C5FFFFFFFF:2088C500000000
flash: ST M30L0R7000B0, M36L0R7040B0 B 16Mb
Boot Done
Set baud ...
921600
Set baud Done
Check flash ...
current eeprom imei: 358956005916995
file saved: C:\Program Files\InfinityBox\LGA\eeprom_358956005916995_LG-B2050_20090418-105425.B1E.bin
version: L-kGB2050
reading L-kGB2050_eeprom-ffs_358956005916995...
file saved: C:\Program Files\InfinityBox\LGA\L-kGB2050_eeprom-ffs_358956005916995_LG-B2050_20090418-105556.B1E.bin
Check flash Done
Check space ...
Check space Done
Check parameters ...
Check parameters Done
Erase ...
Erase Done
Write ...
Write Done
Finished, time used: 139 sec
Remove/Install battery now
The Following 2 Users Say Thank You to somratjisan For This Useful Post:
Old 04-18-2009, 09:58   #2 (permalink)
Member: 130995
Thanks Meter: 35,227
Here is log
module v1.38
Device: LG-B2050
Action: reset
Boot ...
Connecting, wait...
Boot Done
Set baud ...
921600
Set baud Done
Check flash ...
version: L-kGB2050
Check flash Done
Check space ...
Check space Done
Erase ...
Erase Done
Write ...
Write Done
Thank you very much for test report !
Each test report with attached logs is very important for us
so we can see how is Infinity-Box software works, what is phone hardware configuration (f.e. flash chip type)
and what is possible problems (so we will be able to fix it) and successfully done work.
Old 02-23-2011, 13:17   #3 (permalink)
Member: 1487476
Sonork: 1644834;ali
Thanks Meter: 3
lg 2050 ime 00000000000000000000000
vodafone 125 & LG KP100 success unlock by infinity raffy_84 Infinity-Box 5 10-20-2008 15:17
LG B2050 Successfully Unlock ..::Angel::.. Infinity-Box 1 08-15-2008 15:54
Simoco Sm-999 Successfully Format By Infinity debmobile Infinity-Box 1 06-21-2008 09:21
Tv Y390 3gsm Successfully Formatted With Infinity amit_varietymob Infinity-Box 1 02-14-2008 23:26
china Cect-T689 successfully formated in infinity .::AZEEM::. Infinity-Box 2 02-07-2008 10:16
Page generated in 0.15878 seconds with 9 queries
