Old 11-09-2015, 22:37   #1 (permalink)
Moderator
Member: 1139057
Sonork: 100.109924
Thanks Meter: 4,428
C2M RTK v1.0 bug or tablet not supported ?
Hi I try read info, read flash and read pattern lock but got error this tab is not supported or is bug in C2M sw ?
Chinese Miracle II [RKT Module] v 1.0
Connect device to PC!
Hold 'VolUp'+'VolDown' or 'VolUp', insert USB cable, press 'PowerOn'!
Found active FlashInterface , connecting ...
Detected : RK2929
Read Info Ok!
Operation : ReadInfo [ v1.0 ]
======= Flash Info :
Channel : 0x00
FlashType : ADD794DA74
FlashSize : 0x0000000100000000
FlashCaps : 2097152/8192/33/24/2
======= Device Info :
CPU : RK29XX
Android : v4.0.4
Project : 20121008.102504
Brand : Android
Device : rk29sdk
Model : Full AOSP on Rk29sdk
Read Info Ok!
Elapsed: 00:00:05
Try read flash:
Operation : Read Flash [ v1.0 ]
Collect InitData ...
Reading now ...
Reading : PARAMS
Reading : MISC
Reading : KERNEL
Reading failed! Send report to support with all logs!
Elapsed: 00:00:07
On try read pattern lock sofware C2M hang and not can do anything more then restart sw.
I waiting for any answer.
To enter tab in flash mode need press hardware home button on pcb from lcd side and connect usb cable. Simple and work 100%.
I need see patern lock without reset tablet. Will be possible soon ?
Old 11-09-2015, 22:49   #2 (permalink)
Moderator
Member: 1139057
Sonork: 100.109924
Thanks Meter: 4,428
Oooo I forget write my tab is Goclever Tab R75
When try read pattern lock after some time without any move in sw got this error:
http://s23.postimg.org/f6u3ou3nv/error_cm2_rkt_v1_0.png
Old 11-09-2015, 23:38   #3 (permalink)
JayDi's Avatar
Member: 462970
Thanks Meter: 20,352
Autoconnection fail at some reason. Try reset power, re-connect and do need operation after connect exactly. Not wait , read info and etc.
Old 11-10-2015, 10:14   #4 (permalink)
Moderator
Member: 1139057
Sonork: 100.109924
Thanks Meter: 4,428
I try this too and not work too, I try on 2 computers(win 10 32bit with intel cpu and win xp with amd cpu) always same.
I try about 20 times in random combination.
Tablet is working just got pattern lock.
If remote access by temview or something can help solve this np can give you access without problem.
Old 11-10-2015, 11:45   #5 (permalink)
mbiborna's Avatar
Member: 770503
Thanks Meter: 1,215
http://forum.gsmhosting.com/vbb/f296...arted-1999759/
Detected : RK2929 maybe it's Not supported.
Old 11-10-2015, 17:01   #6 (permalink)
JayDi's Avatar
Member: 462970
Thay normally should be supported. I re-make RKT engine, hope finish on this week.
The Following 3 Users Say Thank You to JayDi For This Useful Post:
Page generated in 0.16771 seconds with 8 queries
