Old 08-15-2008, 19:32   #1 (permalink)
oMeR_Rasheed's Avatar
Member: 466635
Sonork: 100.1614186
Thanks Meter: 482
C701 Unlocked
HI BRO I HAVE 1 PHON C701 OK NOW I UNLOCK THIS METHOD AND THEN MY FONE IS UNLOCKED PLEASE SEE THIS AND USE THIS EXE (MModule.exe) VERSION 2.24 OK
COM14 [VCP0] selected
Device: Alcatel-OT-C701X, OT-C701A
Checking data, wait...
Action: write NOR flash
"smart write" active
"format ffs" active
write: Firmware
skip: Customization/Language Pack
skip: Customization
skip: Eeprom/ffs
Boot...
19200 fixed
Connecting, wait...
Initializing[6226:8A03:8A02]...
CPU: MT6226
chip: 0031:A8EA:A000
boot step size: 0400
Release Power button now !
Boot Done
Initialize...
flash: 01227E22302200:2BEA0000000000
flash: Amd AMD/Fujitsu std [D 0004x008000 00FEx020000 0004x008000] 32Mb
Initialize Done
Set baud...
921600
Set baud Done
Initialize bootcode...
Initialize bootcode Done
Check firmware integrity...
detect device identification#1...
detection phase #1...
detect device identification#1 finished
identification#1 structure: 2nd [enhanced] generation
security area#1 is Ok
security area#1 backup saved: C:\Program Files\InfinityBox\MModule\backup_security\id.604F5 1B1.[JRD26_06A_PCB01_GPRS_MT6226_S02.MAUI_06A_W06_52_SP 1_V17.BIN_0D326A39].rpl
New firmware detected:
- make "Read full flash" operation
- send "backup_system_log_..." file to support: [email protected]
- send flash backup file(s) to support: [email protected]
- include in your e-mail full text from phone back label (phone name etc.)
identification#1 detection finished
device-id: 604F51B1
identification#1 protocol ver: 05
ver. sw1: JRD26_06A_PCB01_GPRS_MT6226_S02.MAUI_06A_W06_52_SP 1_V17.BIN
ver. sw2: MAUI.06A.W06.52.SP1.V17, C695CDF2
ffs offset/size: 01200000/00E00000
detect device identification#2...
detect device identification#2 finished
Check firmware integrity Done
Check firmware content...
Check firmware content Done
Backup required data...
Backup required data Done
Patch required data...
Patch required data Done
Special operation...
Special operation Done
Write...
security area#1 calculation...
done
file saved: C:\Program Files\InfinityBox\MModule\system_log_604F51B1_JRD2 6_06A_PCB01_GPRS_MT6226_S02.MAUI_06A_W06_52_SP1_V1 7.BIN_0D326A39_20080815-170804.B0X.bin
Area: Firmware
Write: Firmware
security area#3 calculation...
customization: CC18GL23
done
Write: security area#3
security area#3 calculation done
security area#2 calculation...
error: security area#2 size is very small: 0000
error: can't calculate security area#2
Write Done
Finalization...
formatting...
Finalization Done
file saved: C:\Program Files\InfinityBox\MModule\system_log_604F51B1_JRD2 6_06A_PCB01_GPRS_MT6226_S02.MAUI_06A_W06_52_SP1_V1 7.BIN_0D326A39_20080815-171926.B0X.bin
Finished, time used: 720 sec
Remove/Install battery now !
File system has been modified !
It is need to press and HOLD phone "Power" button
during long time (up to 1 min) to make phone Powered-On !
OK AND PLEASE POST RESULT
B.R
SHERRY MOBILES
The Following User Says Thank You to oMeR_Rasheed For This Useful Post:
Old 08-15-2008, 20:43   #2 (permalink)
Member: 130995
Thanks Meter: 35,227
Thank you very much for test report !
Each test report with attached logs is very important for us so we can see how is Infinity-Box
software works and what is possible problems and successfully done work.
Old 08-15-2008, 23:48   #3 (permalink)
mrfixit's Avatar
Member: 60899
Thanks Meter: 792
so all u do is press "format ffs:save" to unlock?
Old 08-16-2008, 07:52   #4 (permalink)
Member: 466635
Sonork: 100.1614186
Thanks Meter: 482
HI BRO SEE THE METHOD CARE FULLY OK AND THEN POST FIRST U MATE THE TP AND THEN U FALSH WHIT THIS FILE (C701X-2ARGFR1_XC18GL23_JRD26_06A_PCB01_GPRS_MT6226_S02.M AUI_06A_W06_52_SP1_V17_2007-10-22_simfree_En_Fr_Es_Pt_De.B0M) OK NOW SEE THIS
THIS IS TP INFO
2: Gnd
3: Phone Tx (RJ45 pin 3)
4: Phone Rx (RJ45 pin 2)
ATTCH THE TP AND THEN FLASH WHIT UNLOCKED FILE AND LAST SETUP IS SHOWING THIS LOG
FIRST U PRESS POWER BUTTON DON'T REMOV CCABLE AND AFTER PRESSING BUTTON THEN REMOVE CABLE
ALL IS OK
AND REMAMBER FIRST U THE LOG AND THEN POST
B.R
SHERRY MOBILES
Old 08-16-2008, 14:36   #5 (permalink)
mrfixit's Avatar
Member: 60899
Thanks Meter: 792
no tp needed since I got cable which attach directly, its a small box with 3 pins like they use for nokia, but thanks anyway for being clear.
Old 08-17-2008, 08:02   #6 (permalink)
Member: 466635
Sonork: 100.1614186
Thanks Meter: 482
Hi I Don't Have This Cale Ok And Then I Attch The Tp I This Log For C701x Unlocked Ok And Can U Tell Me Cable Name Please?
B.r
Sherry Mobiles
Old 08-18-2008, 02:55   #7 (permalink)
mrfixit's Avatar
Member: 60899
Thanks Meter: 792
buy from ipmart called alcatel c701 rj45 cable, here is link:
http://www.ipmart.com/main/product/A...267&prod=34113
good luck
Old 10-18-2008, 09:24   #8 (permalink)
yasermalik's Avatar
Member: 488632
Thanks Meter: 391
COM4 [VCP0] selected
write: Firmware
skip: Customization
skip: Eeprom/ffs
enhanced security fix enabled
Boot...
19200 fixed
Connecting, wait...
CPU: MT6226
chip: 0031:6369:A000
Boot Done
Initialize...
0004x008000] 32Mb
Initialize Done
Set baud...
115200
Set baud Done
security area (code #1) is Ok
security area (code #1) backup saved: C:\Program
Files\InfinityBox\MModule\backup_security\id.3C71E 96D.[JRD26
_06A_PCB01_GPRS_MT6226_S02.MAUI_06A_W06_52_SP1_V17
.BIN_DADE4545].rpl
device-id: 3C71E96D
ver. sw1:
1_V17.BIN
ver. sw2: MAUI.06A.W06.52.SP1.V17, BABA2125
sim-lock status: enabled
original imei: 35320501016087
Write...
security area (code #1) calculation...
done
Files\InfinityBox\MModule\backup_security\system_l og_3C71E96
D_JRD26_06A_PCB01_GPRS_MT6226_S02.MAUI_06A_W06_52
_SP1_V17.BIN_DADE4545_20081018-003939.B0X.bin
Area: Firmware
Write: Firmware
security area (code #3, part #2) calculation...
customization: CC19EK22
done
Write: security area (code #3, part #2)
security area (code #3, part #2) calculation done
security area (code #3, part #1) calculation...
..................counter: 01
done
Write: security area (code #3, part #1)
security area (code #3, part #1) calculation done
Write Done
Finalization...
Finalization Done
_SP1_V17.BIN_DADE4545_20081018-011636.B0X.bin
Finished, time used: 2268 sec
full flash complete after flashing formate in complete mode
Action: "format ffs"
Boot...
19200 fixed
Connecting, wait...
CPU: MT6226
Boot Done
Initialize...
0004x008000] 32Mb
Initialize Done
Set baud...
115200
Set baud Done
_06A_PCB01_GPRS_MT6226_S02.MAUI_06A_W06_52_SP1_V24
.BIN_FA4895D4].rpl
device-id: 3C71E96D
ver. sw1:
1_V24.BIN
ver. sw2: MAUI.06A.W06.52.SP1.V24, 2B6AB705
sim-lock status: disabled
Write...
Write Done
Finalization...
formatting...
Finalization Done
_SP1_V24.BIN_FA4895D4_20081018-012106.B0X.bin
Finished, time used: 231 sec
thnx infinity team
br
yasermalik
The Following 2 Users Say Thank You to yasermalik For This Useful Post:
Old 10-18-2008, 22:14   #9 (permalink)
Member: 130995
Old 10-19-2008, 06:51   #10 (permalink)
Member: 466635
Sonork: 100.1614186
Thanks Meter: 482
C707x unlocked done
HI BODY TADAY I HAVE 1 PHON ALCATEL C707X I UNLOCK THIS PHON CONECT TP AND THEN SELECT C701X OK AND THEN WRIGHT FLASH FALSH NAME HERE OK
C701A-2ACECO1_XC19GP21_JRD26_06A_PCB01_GPRS_MT6226_S02[1].MAUI_06A_W06_52_SP1_V24_2007-10-27_En_Fr_Es_Pt-BR_It_simfree.B0M
OK AND PLEASE SEE THIS LOG
COM18 [VCP0] selected
"format ffs" active
write: Firmware
skip: Customization
skip: Eeprom/ffs
Boot...
error: can't detect device
in case of initial connection problem: on/off "Boot baudrate autoselect" box.
Boot Fail
Finished, time used: 44 sec
==== log: [10/18/2008 7:03:31 PM] ====
"format ffs" active
write: Firmware
skip: Customization
skip: Eeprom/ffs
Boot...
19200 fixed
Connecting, wait...
CPU: MT6226
chip: 0031:48B1:A000
Boot Done
Initialize...
Initialize Done
Set baud...
115200
Set baud Done
security area#1 backup saved: C:\Program Files\InfinityBox\MModule\backup_security\id.62F85 41F.[JRD26_06A_PCB01_GPRS_MT6226_S02.MAUI_06A_W06_52_SP 1_V24.BIN_CDD6B46C].rpl
device-id: 62F8541F
ver. sw1: JRD26_06A_PCB01_GPRS_MT6226_S02.MAUI_06A_W06_52_SP 1_V24.BIN
ver. sw2: MAUI.06A.W06.52.SP1.V24, 934B2932
original imei: 35497901056372
Write...
done
file saved: C:\Program Files\InfinityBox\MModule\backup_security\system_l og_62F8541F_JRD26_06A_PCB01_GPRS_MT6226_S02.MAUI_0 6A_W06_52_SP1_V24.BIN_CDD6B46C_20081018-190416.B0X.bin
Area: Firmware
Write: Firmware
customization: CC19GP21
done
..................done
Write: security area#2
security area#2 calculation done
Write Done
Finalization...
formatting...
Finalization Done
file saved: C:\Program Files\InfinityBox\MModule\backup_security\system_l og_62F8541F_JRD26_06A_PCB01_GPRS_MT6226_S02.MAUI_0 6A_W06_52_SP1_V24.BIN_CDD6B46C_20081018-193929.B0X.bin
Finished, time used: 2154 sec
AND THEN FORMATE FS
Action: reset settings
Model: Alcatel-OT-C701X, OT-C701A
19200 autodetect
CPU: MT6226
Connecting, wait...
error: can't finalize test mode
repeat operation and HOLD phone "Power" button long time !
error: operation failed !
Finished, time used: 98 sec
AND THEN RESET SETTING
19200 autodetect
CPU: MT6226
error: initialize step#3 failed
Can't initialize test mode !
Possible reasons:
1. communication fault, repeat required operation
2. eeprom/ffs serious damaged, use repair eeprom/ffs files or use other unlock/format method
Finished, time used: 40 sec
ALL IS OK TESTED BY ME
B.R
SHERRY MOBILES
Old 10-19-2008, 13:33   #11 (permalink)
Member: 130995
Old 10-20-2008, 12:48   #12 (permalink)
yasermalik's Avatar
Member: 488632
Thanks Meter: 391
ALCATEL OT-S520 PINOUT SAME AS C701X
READ MANUAL FROM SUPPORT
AND CHACK TABS AND WRITE FLASH
AFTER FLASHING FORMATE IN COMPLETE MODE
Device: Alcatel-OT-S520
write: Firmware
skip: Customization
skip: Eeprom/ffs
Boot...
19200 fixed
Connecting, wait...
Initializing[6225:8A03:8A00]...
CPU: MT6225
chip: 0001:B903:A003
Boot Done
Initialize...
flash: 01227E22442200:18E59F00000000
flash: Amd AMD/Fujitsu std [D 0004x008000 007Ex020000
0004x008000] 16Mb
Initialize Done
Set baud...
115200
Set baud Done
Files\InfinityBox\MModule\backup_security\id.08A20 C4B.[JRD25
_06B_PCB01_GPRS_MT6225_S00.MAUI_06B_W07_28_SP1_V34 .
BIN_B8A8FFD4].rpl
device-id: 08A20C4B
ver. sw1:
JRD25_06B_PCB01_GPRS_MT6225_S00.MAUI_06B_W07_28_SP
1_V34.BIN
ver. sw2: MAUI.06B.W07.28.SP1.V34, 2B005747
ffs offset/size: 00C00000/00400000
original imei: 35198902007818
Write...
done
Files\InfinityBox\MModule\backup_security\system_l og_08A20C4
B_JRD25_06B_PCB01_GPRS_MT6225_S00.MAUI_06B_W07_28_
SP1_V34.BIN_B8A8FFD4_20081020-043025.B0X.bin
Area: Firmware
Write: Firmware
customization: CD44BN00
done
done
Write Done
Finalization...
Finalization Done
SP1_V34.BIN_B8A8FFD4_20081020-043932.B0X.bin
Finished, time used: 588 sec
Boot...
19200 fixed
Connecting, wait...
CPU: MT6225
Boot Done
Initialize...
0004x008000] 16Mb
Initialize Done
Set baud...
115200
Set baud Done
BIN_B8A8FFD4].rpl
device-id: 08A20C4B
ver. sw1:
1_V34.BIN
Write...
Write Done
Finalization...
formatting...
Finalization Done
SP1_V34.BIN_B8A8FFD4_20081020-044121.B0X.bin
Finished, time used: 56 sec
THANX INFINITY TEAM
YASERMALIK NAKAASH MAHMOOD MALIK
QAISAR MAHMOOD DOC-UNLOCK
ZAHID MALIK XPERT UNLOCK
TAHIR MALIK XPERT UNLOCK
DOC-UNLOCK DADYAL
Old 11-19-2008, 08:54   #13 (permalink)
yasermalik's Avatar
Member: 488632
Thanks Meter: 391
again successfully unlock
alcatel ot-s520 on infinity wid simfree flashing
module v2.41
Device: Alcatel-OT-S520X, S520A
write: Firmware
skip: Customization
skip: Eeprom/ffs
Boot ...
19200 fixed
Connecting, wait...
Initializing [6225:8A03:8A00]...
CPU: MT6225
chip: 0001:1A03:A00D
boot packet size: 0400
Boot Done
Initialize ...
flash: Amd AMD/Fujitsu std [D 0004x008000 007Ex020000 0004x008000] 16Mb
Initialize Done
Set baud ...
115200
Set baud Done
Initialize bootcode ...
Check firmware integrity ...
security area (code #1) backup saved: C:\Program Files\InfinityBox\MModule\backup_security\id.34B77 5C1.[JRD25_06B_PCB01_GPRS_MT6225_S00.MAUI_06B_W07_28_SP 1_V34.BIN_B8A8FFD4].rpl
device-id: 34B775C1
ver. sw 1: JRD25_06B_PCB01_GPRS_MT6225_S00.MAUI_06B_W07_28_SP 1_V34.BIN
ver. sw 2: MAUI.06B.W07.28.SP1.V34, 2B005747
Check firmware content ...
Backup required data ...
original imei: 35198902034051
Patch required data ...
Special operation ...
Write ...
done
file saved: C:\Program Files\InfinityBox\MModule\backup_security\system_l og_34B775C1_JRD25_06B_PCB01_GPRS_MT6225_S00.MAUI_0 6B_W07_28_SP1_V34.BIN_B8A8FFD4_20081119-060510.B0X.bin
Area: Firmware
Write: Firmware
done
done
Write Done
Finalization ...
Finalization Done
file saved: C:\Program Files\InfinityBox\MModule\backup_security\system_l og_34B775C1_JRD25_06B_PCB01_GPRS_MT6225_S00.MAUI_0 6B_W07_28_SP1_V34.BIN_B8A8FFD4_20081119-061417.B0X.bin
Finished, time used: 590 sec
module v2.41
Boot ...
19200 fixed
Connecting, wait...
CPU: MT6225
Boot Done
Initialize ...
Initialize Done
Set baud ...
115200
Set baud Done
device-id: 34B775C1
Write ...
Write Done
Finalization ...
formatting...
Finalization Done
file saved: C:\Program Files\InfinityBox\MModule\backup_security\system_l og_34B775C1_JRD25_06B_PCB01_GPRS_MT6225_S00.MAUI_0 6B_W07_28_SP1_V34.BIN_B8A8FFD4_20081119-061534.B0X.bin
Finished, time used: 55 sec
thnx infinity team
br yasermalik
Old 12-21-2008, 11:48   #14 (permalink)
yasermalik's Avatar
Member: 488632
Thanks Meter: 391
WITH SOME ERROR UNLOCK DONE S520 THNX INFINITY TEAM GOOD WORK
module v2.54
write: Firmware
skip: Customization
skip: Eeprom/ffs
Boot ...
19200 fixed
Connecting, wait...
CPU: MT6225
chip: 0001:AA03:A009
Boot Done
Initialize ...
Initialize Done
Set baud ...
115200
Set baud Done
Files\InfinityBox\MModule\backup_security\id.A0DD5 DB4.[JRD25_06B_PCB01_GPRS_MT6225_S0
0.MAUI_06B_W07_28_SP1_V34.BIN_B8A8FFD4].rpl
device-id: A0DD5DB4
warning: wrong cs at 0x00BF6000, retry...
error: unexpected data:
3B3B3B3B3B3B3B3B3B3B3B3B3BC73B3B3B3B3B3B3B3B3BC3DB 3BC3CB3B3B3BBB3B3B3B3
B5B3B3B3BBB3B3B3B3B3BBF7B3B3B3A3B3B3B3B3BBB3B3B3B3 B3B3B3B3B3B3BC53B3B3B3
B3B3B3B3B3B3B3B3B3B3B3B3B3B3B3B3B3B3B3B3B3B3B3B3B3 B3B3B3B3B3B3B3B3BC4BB
read error recovered
original imei: 35198902008424
Write ...
done
Files\InfinityBox\MModule\backup_security\system_l og_A0DD5DB4_JRD25_06B_PCB01_GPRS_M
T6225_S00.MAUI_06B_W07_28_SP1_V34.BIN_B8A8FFD4_200 81221-023030.B0X.bin
Area: Firmware
Write: Firmware
error: wrong answer: 3B
error: flash write error: 0083C000:00002000
error: flash write error: 00842000:00002000
error: wrong answer: 19
error: flash write error: 0084E000:00002000
customization: CD44BM01
done
security area (code #3, part #1) detecting size...
security area (code #3, part #1) detecting parameters...
security area (code #3, part #1) encoding...
done
Write Done
Finalization ...
Finalization Done
T6225_S00.MAUI_06B_W07_28_SP1_V34.BIN_B8A8FFD4_200 81221-023958.B0X.bin
Finished, time used: 882 sec
module v2.54
Boot ...
19200 fixed
Connecting, wait...
CPU: MT6225
Boot Done
Initialize ...
Initialize Done
Set baud ...
115200
Set baud Done
device-id: A0DD5DB4
Write ...
Write Done
Finalization ...
formatting...
Finalization Done
T6225_S00.MAUI_06B_W07_28_SP1_V34.BIN_B8A8FFD4_200 81221-024124.B0X.bin
Finished, time used: 53 sec
YASERMALIK
Old 12-25-2008, 07:07   #15 (permalink)
yasermalik's Avatar
Member: 488632
Thanks Meter: 391
BEST UNLOCKING TOOL INFINITY BOX UNLOCK DONE OT-S520X
module v2.54
write: Firmware
skip: Customization
skip: Eeprom/ffs
Boot ...
19200 fixed
Connecting, wait...
CPU: MT6225
chip: 0001:0103:A00E
Boot Done
Initialize ...
Initialize Done
Set baud ...
115200
Set baud Done
Files\InfinityBox\MModule\backup_security\id.D434B 4A6.[JRD25_06B_PCB01_GPRS_MT6225_S0
device-id: D434B4A6
original imei: 35198902026953
Write ...
done
Files\InfinityBox\MModule\backup_security\system_l og_D434B4A6_JRD25_06B_PCB01_GPRS_M
T6225_S00.MAUI_06B_W07_28_SP1_V34.BIN_B8A8FFD4_200 81224-213618.B0X.bin
Area: Firmware
Write: Firmware
done
done
Write Done
Finalization ...
Finalization Done
T6225_S00.MAUI_06B_W07_28_SP1_V34.BIN_B8A8FFD4_200 81224-214534.B0X.bin
Finished, time used: 595 sec
module v2.54
Model: Alcatel-OT-S520X, S520A
19200 autodetect
CPU: MT6225
Connecting, wait...
Phone detected, wait...
Hardware: MT6225,E03
Date: 2006.06.14
Version: 1.0
Version: MAUI.06B.W07.28.SP1.V34
Version: JRD25_06B_HW
44 byte(s) read
connection Ok
building list...
done
items to clear: 208
warning: wrong packet cs
items cleared: 208 of 208
building list...
done
items remains: 0
Finished, time used: 26 sec
THNX INFINTY TEAM
C701 unlock succes gsm54 Easy-Unlocker 12 02-19-2008 06:27
C701 Unlock Code Calculation Ready GM-OTUF Alcatel O.T.U.F 4 02-09-2008 21:19
alcatel ot c701 unlock ? alunecosu_hd Easy-Unlocker 5 01-23-2008 17:59
Alcatel C701 unlock/flash solution Nippo Multi-Box 1 12-13-2007 09:42
Page generated in 0.42298 seconds with 10 queries
