Old 11-22-2007, 04:15   #1 (permalink)
jainmunda's Avatar
Member: 84128
Thanks Meter: 110
c92 pinout
c92 bluetooth phone pinout needed urgently the posted pinoutin this forum is not working with infinity i try to find other pinout but no success someone plz help
Old 11-22-2007, 13:52   #2 (permalink)
jainmunda's Avatar
Member: 84128
Thanks Meter: 110
nobody got the pinout for this c92 phone
Old 11-22-2007, 14:00   #3 (permalink)
.::BHATTI::.'s Avatar
Member: 203158
Sonork: 100.1592032
Thanks Meter: 358
its would be better if u would be telling about he connector type ... and exact info on phone like CECT SED etc...
Old 11-22-2007, 15:35   #4 (permalink)
jainmunda's Avatar
Member: 84128
Thanks Meter: 110
the phone name is c92 the connecter is same as samsung d800 20 pin 3 7 and 19 pin are ground.pin 13 and 12 are working only with power on phone i cant make format ffs with this pinout
and here is the log
Do you want to continue ?
COM4 [VCP0] selected
Device: Autodetect 6205-6227 NOR
Checking data, wait...
advanced flash detection active
Action: reset
Boot...
baud autodetection active
19200
Connecting, wait...
error: boot phase#1 failed
Release Power button now !
in case of initial connection problem: on/off "Boot baudrate autoselect" box.
Boot Fail
Finished, time used: 11 sec
Remove/Install battery now !
Old 11-22-2007, 17:57   #5 (permalink)
Member: 130995
Thanks Meter: 35,227
and here is the log
Action: reset
Boot...
19200
Connecting, wait...
Boot Fail
It's cable problem, wrong pinout. You must use correct cable and select correct COM port.
Due to a lot of different models with the same name but absolutely different hardware,
bottom connectors and different pinouts we recommend you to include the next info:
1. detailed description of model
2. phone CPU chip name
3. phone PCB photo (Rx/Tx/Gnd test-points may exist on phone PCB)
4. attach phone photo
5. attach phone bottom connector photo
6. include information about Gnd and Charge pins on phone bottom connector
After you have this information prepared, check the next detailed description how to get pinout for your model:
use "Cable Selector": http://forum.gsmhosting.com/vbb/showthread.php?t=398297
if not helps, please read: C:\Program Files\InfinityBox\pinout\ChineseMiracle\
if not helps, please read: http:///vbb/showpo...36&postcount=7
if not helps, please read: http:///vbb/showthread.php?t=433447
Old 01-22-2008, 16:26   #6 (permalink)
ali_imran's Avatar
Member: 481609
Sonork: 100.1659889
Thanks Meter: 367
plz locate the connector RX TX FOR C92
Old 01-22-2008, 16:27   #7 (permalink)
ali_imran's Avatar
Member: 481609
Sonork: 100.1659889
Thanks Meter: 367
its urjent plz help me infinity teem
thnx
Old 01-22-2008, 22:03   #8 (permalink)
Member: 148515
Thanks Meter: 19,534
hello ali_imran!
20 pin connector?
Run shell.exe, select model "ZTC" > "ZT199"
you will find pinout and instruction what to do with phone to get stable connection (disconnect skyworks module)
Old 01-23-2008, 07:38   #9 (permalink)
ali_imran's Avatar
Member: 481609
Sonork: 100.1659889
Thanks Meter: 367
i will select "zt199" but my mobile model is "bluetooth c92" but cant attach the phone
Old 01-23-2008, 07:46   #10 (permalink)
ali_imran's Avatar
Member: 481609
Sonork: 100.1659889
Thanks Meter: 367
plz help me infinity team no body know how to solve it and wht mean of resistance 1 k ohms and witch pin is VPP in rj 45 ?its a realy work ?
Old 01-23-2008, 09:18   #11 (permalink)
frnd_4_gsm's Avatar
Member: 279604
Sonork: 100.1582858
Thanks Meter: 198
c92 pin outs may help ur phone
12-rx
13-tx
3,7,18,19-gnd
Old 01-23-2008, 12:36   #12 (permalink)
ali_imran's Avatar
Member: 481609
Sonork: 100.1659889
Thanks Meter: 367
i know pin no 12.tx 13 rx 3,7,18,19 is ground but problem is can't detect the phone plz help infinity teem
Old 01-23-2008, 21:43   #13 (permalink)
Member: 148515
hello ali_imran!
you can add this pull_up resistor, VPP is pin 1 of RJ45.
but it must work without it also.
my advice is to change with places tx and rx wires and try to boot phone again.
Old 02-09-2008, 14:02   #14 (permalink)
Crazy Poster
Member: 123372
ALL INFO FROM ME
1. PORT FOR FLASHING AND TEST IS THE ONE
2. BOOTING PROBLEM - IS PROBLEM OF SKYWORKS MODULE.
DISASSEMBLE KEYBOARD AND DO WHAT U WANT/
COM6 [VCP5] selected
Action: reset settings
Model: Autodetect 6205-6227 NOR
19200
Initializing[6226:8A02:8A01]...
CPU: MT6226
chip: 0031FD7:7607
Connecting, wait...
Phone detected, wait...
Hardware: MT6226,E02
Date: 2005.04.12
Version: 1.0
Version: MAUI.05C.W06.16.MP.V28
Version: TELSDA26_05C_HW
detecting structure #2...
done
60 byte(s) read
imei: 35835220070124
connection Ok
building list...
done
items to clear: 205
130 of 205 items cleared
0 items remains
Finished, time used: 370 sec
ALL IS WORKING/
br from BELARUS
Old 03-01-2008, 16:17   #15 (permalink)
Member: 164806
Thanks Meter: 4
100% tested removie keyboard 8-rx 12-tx
The Following User Says Thank You to max0510 For This Useful Post:
Need Maximus C92 pinout somratjisan Chinese Models & Cloned Phones 0 04-09-2009 13:10
Need Maximus C92 pinout somratjisan Infinity-Box 0 04-09-2009 13:06
Need Maximus C92 pinout somratjisan CPF-Dongle 0 04-09-2009 13:02
Need Bluetooth C92 Pinout shailesh_chauha Chinese Cocktail 9 04-21-2008 11:36
Need Bluetooth C92 Pinout amir2202 Various 3 03-26-2008 18:43
Page generated in 0.23114 seconds with 10 queries
