06-16-2008, 07:34 | #1 (permalink) |
No Life Poster Join Date: Sep 2007
Member: 599037 Status: Offline Thanks Meter: 103 | cable problem for zte a39.. but i hav not the cable for that.. it uses the 5 pin moto jexk. the software shows that it needs the zte 7310 cable but i dont hav that.. i tried using the at106 c2500 cable but it didnbt weorked for that fone.. pzl share the pinouts for that fone... thanx in advance.. |
06-16-2008, 07:42 | #2 (permalink) |
No Life Poster Join Date: May 2008 Location: COME & MADE GREEN WORLD
Member: 771937 Status: Offline Sonork: 100.1605717 Thanks Meter: 1,052 | PLESE READ THIS CAREFULLY:- C:\Program Files\InfinityBox\pinout &YOU WILL GET THIS SET PINOUT. IF I RIGHT ANS CLICK THANKS BOTTOM. |
06-16-2008, 08:18 | #3 (permalink) | |
Please, run Infinity-Box Shell, select required model and you will see detailed information about cable/pinout. if you unable to do so (as many people by unknown reason) here is information for you keyboard top _____ /12345\ _______ 1: Gnd 3: phone Rx (RJ45 pin-2) 4: phone Tx (RJ45 pin-3) in case of connection problems add two 10k resistors: 1. from RJ-45 pin-1 to RJ-45 pin-2 2. from RJ-45 pin-1 to RJ-45 pin-3 | |
06-16-2008, 09:08 | #4 (permalink) |
Member: 599037 Status: Offline Thanks Meter: 103 | pinout found in the infinity pinout folder but the shell didnt showed it....plz fix this error team.........and plz tell me that on what band the fone works.. coz after unlok the fone shows no service... what shud i do,..... |
pinout for zte a39 [SOLVED] | player69fullgsm | PolarBox 3 | 4 | 10-13-2010 11:50 |
Cable Compatible For ZTE 7310 For ET Box / Infinity Box / Vygis Box / Blue Box | IPMART | ipmart WebShop | 0 | 05-15-2009 11:40 |
i-Pmart BX Series RJ45 Extension Additional Cable Compatible For ZTE A35 / 225 For Po | IPMART | ipmart WebShop | 0 | 03-27-2009 03:50 |
i-Pmart BX Series RJ45 Extension Additional Cable Compatible For ZTE 2010 For Polar B | IPMART | ipmart WebShop | 0 | 03-27-2009 03:50 |
30/09/08 : ET-BoX v1.74 Released - Added Support for ZTE A39 | nonu_don | ET-BoX | 7 | 10-01-2008 20:42 |
