07-02-2008, 15:34 | #1 (permalink) |
Freak Poster Join Date: Oct 2006
Member: 366557 Status: Offline Thanks Meter: 12 | that cable used with Vitel TSM 2 Thank you |
07-02-2008, 23:09 | #3 (permalink) |
Member: 366557 Status: Offline Thanks Meter: 12 | I need to connect a tsm2 to infinity, and that cable is not used since they do not encounter the pinout. I have never used the module TSM ningulado but I have seen the unlock button, why wonder about the flashes of support. thanks |
12-21-2008, 09:17 | #4 (permalink) |
Freak Poster Join Date: Aug 2006 Location: tampa
Member: 333872 Status: Offline Thanks Meter: 32 | i kant unlock tsm2..... please help TSM2_Main_Maui_Prod2.6.3_V.3.0-Ni.54M.bin Loaded COM1 selected Device: TSM2 Checking data, wait... Action: Flash write Write: Firmware Skip: Flex/Customization Skip: Resource pack Skip: FFS/File system Boot... Press and HOLD Power button now ! Connecting, wait... Release Power button now ! Boot Done Set baud... 115200 Set baud Done Check Flash... Flash ID1: 001F00C2 Check Flash Done Check space... In progress [eeprom-2]... File saved: Backup_eeprom-2_2008-12-21_2-57-28.54E.bin Check space Done Write... Area: Firmware Erase: Firmware Write: Firmware Err: write stage 08 Write Fail Finished Remove/Install battery now ! Time used: 53 sec |
n95 8g cable that is used with spiderman? | livinz | SpiderMan | 1 | 10-08-2008 02:29 |
not support vitel tsm 2 | alsaber | Multi-Box | 1 | 08-29-2006 10:07 |
What cable use with phillips 760??? | elizag | Multi-Box | 5 | 06-08-2006 18:44 |
pf master cable use with slaver box | sanjeewa57 | powerflasher | 2 | 09-19-2005 14:47 |
please help me with vitel tsm 4 code | ghiulao | Phone Unlocking Codes & Maps | 2 | 11-21-2003 15:28 |
