02-05-2008, 17:32 | #1 (permalink) |
Freak Poster Join Date: Nov 2007
Member: 626582 Status: Offline Thanks Meter: 15 | Calling on INFINITY TEAM, plz help! I tried to click the Read Full Flash tab and here is the logs. But there's a question popped on the screen which I am not really sure what to answer so I click NO. Please help. Thank you so much! COM19 [VCP0] selected Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection active Action: read NOR flash Boot... Press and HOLD Power button now ! baud autodetection active 19200 Connecting, wait... Initializing[6226:8A02:8A01]... chip: 0031:7456:E456 high speed disabled boot step size: 0002 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... flash: 01227E22202200:29EA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb detecting chip #01 in region #00... flash: 01227E22202200:29EA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb number of flash chip/regions detected: 02/01 Initialize Done Set baud... 115200 Set baud Done Identification... device parameters autodetection in progress.. detecting chip #00 in region #00... flash: 01227E22202200:29EA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb detecting chip #01 in region #00... flash: 01227E22202200:29EA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb it's time to stop: 290000EA18F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [enhanced] generation security area#1 Ok security area backup saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\i d.85899A1C.[N618_PCB01_GPRS_MT6227_S01.1.BIN_BD6C27EF].rpl identification#1 detection finished device-id: 85899A1C identification#1 protocol ver: 04 ver. sw1: N618_PCB01_GPRS_MT6227_S01.1.BIN ver. sw2: N618.1 ffs offset/size: 00E00000/00200000 detect device identification#2... detection phase #1... . warning: optional information not found detect device identification#2 finished detecting eeprom/ffs area in 1 chip(s)... standard eeprom/ffs offset detected: 00E00000 flash: 01227E22202200:29EA0000000000 checking area[00000000]: 00000000-00FFFFFF... eeprom/ffs found near: 00FC0000 Detected eeprom/ffs address is non-standard: 00FC0000 Posible reasons: 1. eeprom is Ok but address is non-standard 2. eeprom damaged and can't be detected 3. eeprom is Ok but detected incorrectly (f.e. unknown eeprom structure) If you are not sure that detected address is correct: 1. press "NO" (and select standard address or terminate current operation) 2. make flash backup for emergency case 3. repeat required operation Are you sure that detected eeprom address is correct ? Do you want to use standard eeprom address: 00E00000 ? If you are not sure that standard address is correct: 1. press "NO" and terminate current operation 2. make flash backup for emergency case 3. repeat required operation operation terminated by user error: critical error#1 during ffs size detection error: can't detect eeprom/ffs address/size reading [flash[N618_PCB01_GPRS_MT6227_S01.1.BIN]]... file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_flash[N618_PCB01_GPRS_MT6227_S01.1.BIN]_20080202-113041.B0M.bin file saved: backup_system_log_85899A1C_N618_PCB01_GPRS_MT6227_ S01.1.BIN_BD6C27EF_20080202-113049.B0X.bin Finished, time used: 189 sec Remove/Install battery now ! |
infinity team plz help | jassgill25 | Infinity-Box | 5 | 12-14-2007 11:55 |
infinity team plz help | ajmer | Infinity-Box | 2 | 10-14-2007 15:08 |
c140 cant unlock in infinity team plz help me | ramesh_931 | Infinity-Box | 7 | 07-20-2007 17:47 |
Infinity team plz help me to flash for nokia E60 | .::Munazzam::. | Infinity-Box | 7 | 06-27-2007 19:53 |
hi infinity team plz help ... | unlock_solution | Infinity-Box | 0 | 04-08-2007 20:01 |
