Old 03-14-2016, 10:40   #1 (permalink)
cellcare sams's Avatar
Member: 1537063
Thanks Meter: 74
htc desire 616 dual flash failed
Operation : Flash [ v1.43 ]
======= Flash
Wait for phone...
Phone found! [ 43 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6592
BB_CPU_NME : [MediaTek] MT6592_S00
Processing BROM stage
Settings for BROM configured!
SecCfgVal : 0x00000000
BromVer : 0x00FF
BLVersion : 0x0001
BootLdrSS : NORMAL with SPRELOADER
Processing DA stage
DA Select done, will use MTK_AllInOne_DA_v5.1552.01.01
Sending and initialize DA ...
Running DA ver.4.2 on BBID : 0x8A
NAND Flash : NOT INSTALLED
eMMC Flash : 90014A4834473164048600A362EF41AF
Initialize Memory ...
eMMC FlashIC initialized
[eMMC] : FLASH_VEN : 0x90 , OEM : 014A
[eMMC] : FLASH_INF : [HYNIX] , d1G4
[eMMC] : FLASH_CID : 90014A4834473164048600A362EF41AF
[eMMC] : FLASH_BRT : 0x00200000 , 0x00200000 , 0x00200000
[eMMC] : FLASH_LEN : 0x00000000E7000000
[eMMC] : FLASH_UCP : 3696 MiB [eMMC 4 GiB]
DEV RID : D34A7C8B5763D8883D62FFD4527EF4B5
INT RAM : 0x00020000
EXT RAM : 0x40000000
BOOT TYPE : EMMC_FLASH_BOOT
SOC VERIFY : C1
Boot Ok!
ScatCFG : BaseBand : MT6592 , Project : wt98518 , Storage : EMMC
Setting : Flash Pre-Erase : Off ( Write Flash Only )
Setting : AFF verify : Enabled
Setting : HW verify : Enabled
BL : Check HW compatibility
BL : Check eMMC compatibility
BL : BatteryLevel : 3728 mV
BL : BatteryLevel Ok
SecCfg Passed , 1799
BMT remark not need. Will skip
Sending Preloader ...
Use : preloader_wt98518.bin
Preloader Sent , Init passed
PartCount : FFFFFFFF
PartErr : Not initialized , will update PMT now ...
Repartition Failed! Break! Something wrong with HW or BL (FirmWare)
Operation Failed
Elapsed: 00:00:22
Reconnect Power/Cable!
how to solve
Old 03-14-2016, 16:56   #2 (permalink)
JayDi's Avatar
Member: 462970
Thanks Meter: 20,352
Try for start erase phone fully then reflash.
If no luck - in 99% cases it is BAD eMMC IC. Need change.
Page generated in 0.19004 seconds with 9 queries
