06-11-2015, 06:10 | #1 (permalink) |
No Life Poster Join Date: Mar 2010 Location: Dubai
Member: 1259046 Status: Offline Sonork: 100.1608453 Thanks Meter: 1,229 | Calme S24 MTK6572 Factory File Phone found! [ 10 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6572 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6572_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending NAND_ID : 00000000000000000000000000000000 eMMC_ID : 7901004D4D4330344745087E1EC19105 DA Stat : v4.2 on BBID : 0x88 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0079 , OEM : 0100 [eMMC] : FLASH_INF : G40CM [eMMC] : FLASH_CID : 7901004D4D4330344745087E1EC19105 [eMMC] : FLASH_LEN : 0x00000000E6800000 INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Reading Flash Conent now ... Brand : S24 ProdName : hct72_cwet_kk ProdModel : S24 Device : hct72_cwet_kk AndroidVer: 4.4.2 MTKxCPU : MT6572 MTKxPRJ : S24_20141211 [Read Ok] : preloader_hct72_cwet_kk.bin [Read Ok] : MBR [Read Ok] : EBR1 [Read Ok] : lk.bin [Read Ok] : boot.img [Read Ok] : recovery.img [Read Ok] : secro.img [Read Ok] : logo.bin [Read Ok] : system.img [Read Ok] : cache.img [Read Ok] : userdata.img [Read Ok] : fat.img [ScatCFG] : MT6572 / V1.1.1 / hct72_cwet_kk / EMMC FW Size : 847 MiB Scatter saved to : C:\InfinityBox\CM2MTK\Flash\MT6572__S24__S24__hct7 2_cwet_kk__4.4.2__S24_20141211\ All done! Done! Elapsed: 00:04:27 Reconnect Power/Cable! |
The Following User Says Thank You to im3022 For This Useful Post: |
07-26-2017, 17:23 | #4 (permalink) |
No Life Poster Join Date: Mar 2011 Location: PAKISTAN
Member: 1537135 Status: Offline Thanks Meter: 1,021 | NEED FLASH FILE Calme mobile s24 Tested firmware Operation : Check / Read Info [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 15 ] Sync... Inital Boot Ok! BB_CPU_PID : 6572 BB_CPU_NME : [MediaTek] MT6572_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x88 NAND Flash : NOT INSTALLED eMMC Flash : 90014A4834473261110147F01978A32B Initialize Memory ... DRAM configured from IDB! DRAM initialize passed! DRAM size : 0x20000000 DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x90 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , a2G4 [eMMC] : FLASH_CID : 90014A4834473261110147F01978A32B [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000000E9000000 [eMMC] : FLASH_UCP : 3728 MiB [eMMC 4 GiB] DEV RID : 0xB9E2EB77E85B3C767B0A1220207AFC3C INT RAM : 0x00020000 EXT RAM : 0x20000000 [512 MiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! [AP] : Initial info read Ok! Brand : SPARK ProdName : S24 ProdModel : SPARK S24 Device : S24 AndroidVer: 4.4.2 MTKxCPU : MT6572 MTKxPRJ : ALPS.KK1.MP7.V1 MODEM : BaseBand : MT6572_S00_MOLY_WR8_W1315_MD_WG_MP_V43_1_wg_n EXTRA : LCD [0] : fussen_f2_72m_hx8379c_wvga_dsi_hlt LCD [1] : fussen_f2_72m_otm8019a_wvga_dsi_boe_hx LCD [2] : fussen_f2_72m_fl10801_wvga_dsi_fx LCD [3] : fussen_f2_72m_sh1282g_wvga_dsi_ljj LCD [4] : fussen_f2_72m_ili9806e_wvga_dsi_km LCD [5] : fussen_f2v_72m_jd9161_wvga_dsi_tyf LCD Res : 800x480 TOUCH [0] : msg2233 TOUCH [1] : ft5436i CAM [0] : gc2155_yuv CAM [1] : gc2145_yuv CAM [2] : sp2519_yuv CAM [3] : gc0329_yuv CAM [4] : sp0a19_yuv MODEM : fars72_w_kk_hspa LOCALE : en_US ar_EG fa_IR fr_FR ur_PK hdpi Done! Elapsed: 00:00:19 Reconnect Power/Cable!: |
