05-30-2008, 13:21 | #1 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | "Camera module is not ready" solution As I can see during last days we have big discussion about "Camera module is not ready" problem. Many threads was started byt in fact it was not many real answer for many questions. Let's post here REAL TESTED solutions for this problem. Here is an instruction for this problem that was found and tested personally by me: --------------------------------------- If you have original charger: 1. Power-Off phone 2. Connect charger to phone 3. Connect charger to 220/110V 4. Charge phone during 30-40 minutes 5. Power-On phone and use it If you don't have original charger: 1. Remove batetry from phone 2. Use external power supply and charge battery 3. Power-On phone and use it --------------------------------------- Hope we will see here more useful information. Please, write in this thread only really tested solutions and your own experiens, no need to post here rumors or something like "I heard that one man have tested and probably...". Please, post here phone model name and the method that you have used to fix the problem. Thank you for understanding. p.s. offtopic messages or messages with "maybe", "probably" etc. ideas will be moved here http:///vbb/showthread.php?t=544829 , I'll be strong and in this thread I'll leave only really useful messages. Last edited by InfinitySupport; 05-30-2008 at 16:19. |
The Following 74 Users Say Thank You to InfinitySupport For This Useful Post: |
05-30-2008, 13:57 | #2 (permalink) |
No Life Poster Join Date: Jul 2004 Location: Cuttack,India Age: 54
Member: 71721 Status: Offline Sonork: 100.106320 Thanks Meter: 139 | phone received (cect t520)Camera_module_not_ready after fully battery charge same problem solved-after full format ---- i forget the model but once i repaired with refit camera jack ,2 times with full format never face problem due to low battery,because every time i recharge battery fully with external charger before any work |
The Following 8 Users Say Thank You to TURNING POINT For This Useful Post: |
05-30-2008, 17:43 | #4 (permalink) |
Freak Poster Join Date: Jan 2005 Age: 55
Member: 102467 Status: Offline Thanks Meter: 24 | i have solved this probleme many time tested and work 100/100 1- change the batery ( cause of the probleme volt ok amper not ok) 2-change the camera( cause bad connection in the bcp) 3-cpu or flash ic ( heat the ic one by one) 90% of this probleme it's hardward |
The Following 4 Users Say Thank You to charletan For This Useful Post: |
06-01-2008, 08:45 | #5 (permalink) |
No Life Poster Join Date: Nov 2005 Location: .:GSM WORLD:.
Member: 203158 Status: Offline Sonork: 100.1592032 Thanks Meter: 358 | yes there are different ways to solve this problem .. can be software or camera ..or battery .. so but mostly it looks to be the battery... |
The Following 4 Users Say Thank You to .::BHATTI::. For This Useful Post: |
06-01-2008, 12:23 | #6 (permalink) |
No Life Poster Join Date: Aug 2005 Location: Ena Neray Na Ho Dildar Ve Age: 37
Member: 171512 Status: Offline Thanks Meter: 1,034 | Sigmatel s3 camera module not ready,Hot solution Sigmatel s3 becomes Camera module not ready after formating, this seems like hardware problem, but some easy steps to recover, I did with three phones. press * # # # now u r on factory mode section now click on "select type sensor" choose gekewei and press ok. now u r ready to use camera. 100% working solution. If not working then u have to examine hardware |
The Following 56 Users Say Thank You to ehsas_ghum For This Useful Post: |
06-01-2008, 12:57 | #7 (permalink) | |
No Life Poster Join Date: Sep 2006
Member: 343326 Status: Offline Thanks Meter: 1,463 | Quote:
Yes dear it is working solution for this model for me. I repair of 2 same model using this trick. Thankx a lot for sharing. | |
The Following 17 Users Say Thank You to amol_sm For This Useful Post: |
06-01-2008, 22:02 | #8 (permalink) |
No Life Poster Join Date: Jan 2006 Location: Mirpur-1, Dhaka,Bangladesh
Member: 222009 Status: Offline Sonork: 100.1576751 Thanks Meter: 435 | I Have Repaired MaXimum Sets By Cleaning The Camera Connector Or ChanginG The Camera ... But I Have Not Succeeded By Formatting Or Even With Flash ... |
The Following 2 Users Say Thank You to sharmin For This Useful Post: |
06-02-2008, 00:41 | #9 (permalink) |
Freak Poster Join Date: Jun 2003
Member: 31326 Status: Offline Thanks Meter: 5 | I have recived more than 10 devices with this defect specially in " Cect c1000 & C1000+ " It was all hardware problems and most of it solved by cleaning camera socket or replacing camera module. |
06-02-2008, 13:24 | #10 (permalink) |
No Life Poster Join Date: Jun 2005 Location: Kamalia, Pakistan. Age: 38
Member: 151871 Status: Offline Thanks Meter: 71,421 | yes thats True that only 1% or may be 3% mobile have software problem due to Camera not ready but mostly its hardware in chinese mobile they made Very low Quality phone as i seen camera's Strip and Connector is the problem some time they not connected properly just need to push or need to clean , many time i do for this problem and yes i repair only one mobile with format ffs Br Faisal_Computer |
The Following User Says Thank You to Faisal_Computer For This Useful Post: |
06-04-2008, 09:03 | #13 (permalink) |
No Life Poster Join Date: Oct 2007 Location: india
Member: 621455 Status: Offline Sonork: key4unlock Thanks Meter: 118 | S2 & S3 hi dear i used deifferent method to repair Camera module not Ready. its strange 2 hear dat. i take one working S3 phone n takes backup of its flash n write in the same phone S3 which have problem Camera modul not ready n after flash i got it back with working Cam problem is solved after dat i used the ssame file for S2 also. this files is working with S2 n S3 ... flash[GINWAVE25_06B_PCB01_GPRS_MT6225_S00.FXD-S3_FOREIGN_MR106_004_5S-MC-C01-RF3198_V1_0_013_080306.BIN]_20080531-133727.B0M |
The Following 7 Users Say Thank You to ikkks For This Useful Post: |
"Camera module is not ready" solution: additional discussion | sundar83 | Infinity-Box | 23 | 09-29-2010 08:55 |
itel it600 Camera module is not ready | mahesh123 | Infinity-Box | 1 | 01-07-2009 19:17 |
N958 Having Camera Module Is Not Ready | kumar_pvj | Infinity-Box | 2 | 07-15-2008 09:25 |
vk module is not working | denisirias | Multi-Box | 2 | 11-26-2007 21:45 |
