Old 05-30-2008, 13:30   #1 (permalink)
Member: 223120
Thanks Meter: 131
"Camera module is not ready" solution: additional discussion
i think for this problem it have some codes for each model like sigmatel codes.........................
The Following 2 Users Say Thank You to sundar83 For This Useful Post:
Old 05-30-2008, 13:41   #2 (permalink)
Member: 223120
Thanks Meter: 131
i have more than 3 sets like this complaint one is the sigmatell tat one solved by using the codes given in our forum the other 2 n958g and ztc zt999 that codes r not support this problem happened after flashing for hanging problem it was occur bfore tat it works fine...................................
Old 05-30-2008, 14:19   #3 (permalink)
Member: 223120
Thanks Meter: 131
am too never face due to battery low for this problem some mobile solved thru codes some mobiles solved thru connector re touchup........................................... ..........
Old 05-30-2008, 14:25   #4 (permalink)
Member: 130995
Thanks Meter: 35,227
Dear Friends,
Here is messages that was moved from "Camera module is not ready" solution thread due to some reasons.
In current thread we can discuss about the problem and post any ideas and rumors that you have heard but not tested yet or tested not well.
Original discussion is here: http:///vbb/showthread.php?t=544808
The Following 2 Users Say Thank You to InfinitySupport For This Useful Post:
Old 05-30-2008, 15:34   #5 (permalink)
Cheater -Don't Deal with him-
mobilecraker's Avatar
Member: 142219
Sonork: 100.107814,
Thanks Meter: 368
@infinty support
i hav cect 599 in same fault.full formate,full battery charge,but sttill same(even resold camera components)
n still in hands
br
mobilecraker
Old 05-30-2008, 15:40   #6 (permalink)
.:CARLO:.'s Avatar
Member: 126086
Sonork: 100.113901
Thanks Meter: 232
some tools have option in there soft camera fix..i hope you will have it to..thanks..
br
Old 05-30-2008, 16:20   #7 (permalink)
Member: 130995
@mobilecraker
@.:CARLO:.
Please, read first message in current thread. What we talk about here ?
Old 05-30-2008, 17:52   #8 (permalink)
Member: 337837
Thanks Meter: 538
Today I Had Format 1 Chinese Mobil After Formatting Whenever I Open Camera It Shows "camera Module Not Ready" I Have Original Charger I Will Test Then Post Result Here
Old 05-30-2008, 18:04   #9 (permalink)
charletan's Avatar
Member: 102467
Thanks Meter: 24
hi pro open the phone clear the conneteur camera in the bcp and post result
Old 05-30-2008, 18:24   #10 (permalink)
::. zine .::'s Avatar
Member: 161061
Thanks Meter: 568
no friend he said that after format it will be like this
Old 05-30-2008, 18:30   #11 (permalink)
Member: 337837
Thanks Meter: 538
mate but its not hardware problem i face this many time after formatting with infinity
Old 05-31-2008, 12:50   #12 (permalink)
charletan's Avatar
Member: 102467
Thanks Meter: 24
restore eprom backup it be ok test and post result
Old 05-31-2008, 12:58   #13 (permalink)
Member: 233950
Sonork: 1650875
Thanks Meter: 6
after restore its same
Old 06-01-2008, 06:07   #14 (permalink)
Member: 50772
Sonork: 100.1590990
Thanks Meter: 318
sundar try this one
Dial *### Go to Factory Settings
now click on select type sensor at last
choose gekewei and press ok. confirm it ( press ok twice )
now youn are ready to use camera
Old 06-01-2008, 08:16   #15 (permalink)
Member: 130995
If you restore back original eeprom backup and "poblem still same" this means that "format ffs" operation is not a reason of your problem !
"Camera module is not ready" solution InfinitySupport Infinity-Box 112 02-04-2014 23:30
itel it600 Camera module is not ready mahesh123 Infinity-Box 1 01-07-2009 19:17
N958 Having Camera Module Is Not Ready kumar_pvj Infinity-Box 2 07-15-2008 09:25
vk module is not working denisirias Multi-Box 2 11-26-2007 21:45
Page generated in 0.21351 seconds with 9 queries
