03-19-2010, 09:23 | #1 (permalink) |
No Life Poster Join Date: Feb 2005
Member: 113097 Status: Offline Thanks Meter: 365 | can't unlock LG-KP170 module v1.39 Device: LG-KP170 (under test) Checking data, wait... advanced flash detection enabled Action: unlock unlock method: standard Boot ... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting, wait... Release Power button now ! flash: 01227E223C2200:FEEA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 007Ex040000 0004x010000] 32Mb id: 00005283 Boot Done Set baud ... 115200 Set baud Done Check flash ... current eeprom imei: 3503************ file saved: C:\Program Files\InfinityBox\LGA\eeprom_350305260000001_LG-KP170 (under test)_20100319-134241.B1E.bin .................................................. .............. Check flash Done Check space ... current eeprom imei: 3503***********1 warning: Probably wrong model selected or unknown eeprom structure, Are you sure you want to continue ? .................................................. .............. finalization done Check space Done Check parameters ... Check parameters Done Erase ... Erase Done Write ... write: lock area-1 Write Done Finished, time used: 71 sec Remove/Install battery now ! |
how to unlock lg kp170 with infinity??? | shmily | Infinity-Box | 6 | 08-23-2009 08:51 |
is there any way that we can use usb cable n unlock lg kp170 with hwk | patelfaizu | LG | 1 | 08-21-2009 04:46 |
how to unlock lg kp170 with hwk? | ikram tabassum1 | HWK | 1 | 03-29-2009 20:59 |
can i unlock lg kp170 with easy unlocker plz help? | asif_ae | Easy-Unlocker | 1 | 02-23-2009 14:14 |
can i unlock lg kp170 with infinity box plz help? | asif_ae | Infinity-Box | 5 | 02-20-2009 10:52 |
