Old 12-19-2017, 13:39   #1 (permalink)
Member: 411034
Thanks Meter: 26
can anyone help me for oppo a71 cph1717
some body help i want to format pattern lock a71 cph1717 with cm2 but it give error
Card found : S/N : 0CF1AA70 , v0136
Scatter Load Ok , BaseBand : MT6755 , Project : oppo6750_170815 , Storage : EMMC
Files found : 15 , Set to Flash : 14
Created by Infinity-Box (c) Chinese Miracle II (c) 2016
Device Brand : OPPO
Device Model : CPH1717
Device CPU : MT6755
Device IntName : CPH1717
Device Version : 7.1.1
Device Compile : 8/14/2017 3:17:42 PM
Device Project : CPH1717EX_11_A.02_170815
Device ExtInfo : CPH1717
Ready to Flash!
Device Brand : OPPO
Device CPU : MT6755
Ready to Flash!
Operation : Format FileSystem [ v1.58 ]
Wait for phone...
Phone found! [ 7 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6755
BB_CPU_NME : [MediaTek] Helio[P10]|MT6755_S00
BB_CPU_EXT : 0xCB00 , 0x8A00 , 0x0000
Processing BROM stage
Settings for BROM configured!
SecCfgVal : 0x00000000
BromVer : 0x0005
BLVersion : 0x00FE
PreLoader : NOT Active [ Erased ]
Processing DA stage
Sending and initialize DA ...
DAgent configured successfully
Connection agent : BROM
DRAM configured from ScatFW!
Link with DAgent established
eMMC FlashIC initialized
[eMMC] : FLASH_INF : [SAMSUNG] , BMB6E
[eMMC] : FLASH_CID : 150100474536424D42030076C8ED7447
[eMMC] : FLASH_LEN : 0x00000003A3E00000
[eMMC] : FLASH_UCP : 14910 MiB [eMMC 16 GiB]
DEV RID : 0x74A79E62805C525EF49B3EF98B9F3821
INT RAM : 0x00000000
EXT RAM : 0x80000000 [2 GiB]
[NAND] : FLASH : NOT INSTALLED
[UFSM] : FLASH : NOT INSTALLED
[HSUSB] : MODE : FULL-SPEED
Boot Ok!
USBDL : Error init HSUSB!!!
Operation Failed
Elapsed: 00:00:27
Reconnect Power/Cable!
Old 12-19-2017, 19:59   #2 (permalink)
khanzada606's Avatar
Member: 2455344
Sonork: Ask me
Thanks Meter: 420
you need special driver
Old 12-20-2017, 05:11   #3 (permalink)
Member: 411034
Thanks Meter: 26
so please give me link of special driver
Old 12-20-2017, 07:57   #4 (permalink)
gracy_elec's Avatar
Member: 118520
Thanks Meter: 3,551
hello,@iftikhar_338 i have send pm you special driver link chk and post result if any problem i will chk or give me ammy admin
good luck
The Following User Says Thank You to gracy_elec For This Useful Post:
Old 12-20-2017, 09:58   #5 (permalink)
Member: 411034
Thanks Meter: 26
yess its done by special driver thanks
Old 12-20-2017, 13:52   #6 (permalink)
gracy_elec's Avatar
Member: 118520
Thanks Meter: 3,551
at last your problem sloved so you r happy
good luck
Old 12-20-2017, 14:07   #7 (permalink)
Member: 457143
Thanks Meter: 11
please give driver link
Old 12-20-2017, 14:24   #8 (permalink)
gracy_elec's Avatar
Member: 118520
Thanks Meter: 3,551
HELLO,@dildar baniya WHAT PROBLEM IN YOUR PHONE AND WHAT YOU WANT TO DO WITH YOU PHONE
GOOD LUCK
Old 12-20-2017, 15:02   #9 (permalink)
Member: 457143
Thanks Meter: 11
phone have pattern lock
The Following User Says Thank You to dildar baniya For This Useful Post:
Old 07-03-2018, 08:19   #10 (permalink)
Member: 681954
Sonork: 100.1582852
Thanks Meter: 46
good luck
Hello , i need special driver for oppo a71 plz
Old 07-03-2018, 08:21   #11 (permalink)
Member: 681954
Sonork: 100.1582852
Thanks Meter: 46
Infinity-Box Chinese Miracle MediaTek Service Module [ MTK ] v2.00 r4
Operation : Identify [ v2.00 r4 ]
1. Make sure device is powered off. Power off, if need. Wait 20 seconds after
2. Insert USB cable in phone
Waiting for device connection ...
PTFN : MediaTek USB Port (COM3)
MODE : BOOTROM
PORT : 3
Waiting BOOT ack ...
BROM : Skip ACK verify
BROM : Init BROM
BROM init passed!
CHIP : MT6755 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0001
TYPE : MODERN RAPHAEL
BROM : SecLevel : 0x00000000
BROM : SecMode : PLAIN [+PRL]
BROM : BOOTROM
MODE : 0_base : BASE_v1712 | Manual : Disabled
AGENT : Look for suitable BootChain in DA ...
AGENT : MTK_AllInOne_DA.bin
AGENT : Found MT6755
AGENT : MTK_DOWNLOAD_AGENT
BROM : Sending 1st DA ...
BROM : DA sent
BROM :Transfer control to DA ...
DA : AGENT started!
DA : SYNC
DA : MODE : BROM
DA : EXT_RAM NOT initialized!
EMI : DEV : INFINITY
EMI : SRC : INFINITY-BOX_INTERNAL_EMIDB_v0
EMI : CNT : 0009
EMI : Init EMI from INTERNAL DB
DA : SETUP EMI PARAMS FAILED!
ERROR : ABORT
Error : Fail to init protocol!
Internal EMI : Select other EMI number! External Preloader - make sure it correct for connected device!
Old 07-03-2018, 12:12   #12 (permalink)
shazzmob's Avatar
Member: 2327602
Sonork: 100.1620953
Thanks Meter: 276
Link below oppo a71 cph1717 driver
https://mega.nz/#!0ldgHIAC!yk0xTXVUh...iXb6MLz_iq3EM4
Old 07-03-2018, 13:19   #13 (permalink)
kamal_singla's Avatar
Member: 2211790
Thanks Meter: 5,118
MODE : BOOTROM
PORT : 3
BROM : Init BROM
BROM init passed!
BROM : BOOTROM
BROM : DA sent
DA : AGENT started!
DA : SYNC
DA : MODE : BROM
EMI : CNT : 0009
ERROR : ABORT
not driver problem select preloader.bin from factory file or change emi differetnt setting from first page and repeat
Old 07-03-2018, 14:18   #14 (permalink)
shazzmob's Avatar
Member: 2327602
Sonork: 100.1620953
Thanks Meter: 276
BRO THIS IS 100 % DRIVER PROBLEM COZ I FACED THIS PROB FEW DAYS AGO HERE IS LOG BEFORE INSTALL DRIVER
PTFN : MTK USB Port (COM13)
MODE : BOOTROM
PORT : 13
BROM : Init BROM
BROM init passed!
BROM : BOOTROM
MODE : Oppo : A71 | Manual : Disabled
BROM : DA sent
DA : AGENT started!
DA : SYNC
DA : MODE : BROM
EMI : CNT : 0009
ERROR : ABORT
AFTER INSTALL DRIVER EVERY THING IS IS ALRIGHT
PTFN : Preloader And Gadget Serial (COM84)
MODE : PRELOADER PORT
PORT : 84
PRELOADER : ACK confirmed!
BROM : Init BROM
BROM init passed!
BROM : PRELOADER PORT
BROM : DA sent
DA : AGENT started!
DA : SYNC
DA : MODE : PRELOADER
DA : EXT_RAM initialized!
DA : BOOT to 2nd DA ...
DA : 2ND stage confirmed!
DA : SYNC with DA passed!
DA : Receiving HW info
SRAM: 0x00040000 [ 256.00 KB ]
DRAM: 0xC0000000 [ 3.00 GB ]
EMMC: 150100474536424D42033758D00B94FF
EMMC: VEN : SAMSUNG | OEM : 01 | DEV : GE6BMB
EMMC:
BOOT1 : 0x00400000 [ 4.00 MB ]
BOOT2 : 0x00400000 [ 4.00 MB ]
RPMB : 0x00400000 [ 4.00 MB ]
USER : 0x3A3E00000 [ 14.56 GB ]
CHIP : MT6750 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0000 , EVOL : 0x0000
RNID : C39D6614DA1C13EE5AD77DC97429A10C
DA : USB : HIGH-SPEED
Boot done!
Patch Level : N4F26M
Ver. CodeName : REL
Ver. Release : 7.1.1
Sec. Patch : 2017-11-05
Build Time : 1510736974
Product Manfct : OPPO
Board Platform : mt6750
Product Model : CPH1717
Product Brand : OPPO
Product Name : CPH1717
Product Device : CPH1717
Product Board : full_oppo6750_17351
Product Info : oppo6750_17351
SW Version : A.10
SW OTA Version : CPH1717EX_11.A.10_0100_201711151643
Display ID : CPH1717EX_11_A.10_171115
Kernel Info : 3.18.35-G201711151643
Old 07-04-2018, 05:59   #15 (permalink)
Member: 681954
Sonork: 100.1582852
Thanks Meter: 46
MODE : BOOTROM
PORT : 13
BROM : Init BROM
BROM init passed!
BROM : BOOTROM
BROM : DA sent
DA : AGENT started!
DA : SYNC
DA : MODE : BROM
EMI : CNT : 0009
ERROR : ABORT
PORT : 84
BROM : Init BROM
BROM init passed!
BROM : DA sent
DA : AGENT started!
DA : SYNC
EMMC:
Boot done!
Ver. CodeName : REL
SW Version : A.10
plz link for good driver bro.
Page generated in 0.24923 seconds with 8 queries
