Old 05-18-2009, 11:19   #1 (permalink)
Member: 1024036
Thanks Meter: 14
can anyone teach me how to flash chinese miracle by infinity
I would like to learn how to flash chinese miracle by using infinity. please give me guidance. but i don't have pin finder, just infinity box, is it possible to use infinity without pin finder? help me please.........
Old 05-18-2009, 12:08   #2 (permalink)
biochemistali's Avatar
Member: 190344
Thanks Meter: 280
yes u can format and flash the phone with out having a pinfinder.
for this purpose u need to sold rx and tx wire to ur phone board/ jack and also to the rj45 cable using the knowledge of rx and tx of infinity box.
when we use cable that comes with infinity box, they are also based on the principle of known rx, tx and gnd.
u need to have some expertize with multimeter.
read the topics regarding this some where here and there posted.
The Following 2 Users Say Thank You to biochemistali For This Useful Post:
Old 05-18-2009, 13:02   #3 (permalink)
freeman2001's Avatar
Member: 206476
Thanks Meter: 459
this link Can give U gold source
http://forum.gsmhosting.com/vbb/search.php
wbr
The Following 2 Users Say Thank You to freeman2001 For This Useful Post:
Old 05-18-2009, 17:44   #4 (permalink)
deepakgarg's Avatar
Member: 220603
Thanks Meter: 1,164
if u have infinity box than just check this location in your pc for complete manuals c:\Program Files\InfinityBox\Documentation
The Following 2 Users Say Thank You to deepakgarg For This Useful Post:
Old 05-18-2009, 19:56   #5 (permalink)
Member: 130995
Thanks Meter: 35,227
How to write flash (upgrade/downgrade firmware, change language):
1. connect cable from box to device
2. run "Infinity-Box Shell" software
3. select required model
4. run required software module
5. select required model (if need)
6. go to software "Settings" page and select COM port
7. go to software "Flash" page and load required files
8. press "Write" button and follow instruction given by software
How to read flash:
7. go to software "Service" page
8. press "Read flash" (or "Read full flash") button and follow instruction given by software
How to unlock (remove sp-lock, provider lock etc.):
8. press "SP-Unlock" button and follow instruction given by software
How to reset/format ffs (reset setting to default values, repair freez/restart etc.):
- at first try to make "safe format" (if this option exist)
- if "safe" option is not works try to make "complete" format (if this option exist)
8. select format mode "safe" or "complete" (if mode is available)
9. press "Reset" or "Format" button and follow instruction given by software
The Following 2 Users Say Thank You to InfinitySupport For This Useful Post:
Old 05-18-2009, 20:06   #6 (permalink)
Member: 56619
Thanks Meter: 62
I admire at infinity support.They listen every customer who even doesn't make a search for their problem ,till the end. And everytime they repeat solution. They try to give best support and help to their users.They are not superior and have great patience.
Thanks a lot indeed.
Old 05-19-2009, 03:01   #7 (permalink)
Member: 1024036
Thanks Meter: 14
thanks for all, it is really what i need. would you please tell me about the universal rj45 cable, which pin belongs to gnd, tx, and rx? pin 2 as tx, pin 3 as rx and pin 7/8 as ground, is it right? i've got a little bit confused because my freind told me something diiferent. do i need to sold only tx, rx abd gnd? and during flashing, is it with battery or not?
Old 05-19-2009, 04:12   #8 (permalink)
Member: 142949
Thanks Meter: 71
vcc rx,tx is 2,8v
tx all time (when enter power) is open (see light blink at box)
The Following User Says Thank You to nguyenhuu For This Useful Post:
Old 05-19-2009, 20:44   #9 (permalink)
Member: 148515
Thanks Meter: 19,534
hello!
2/3 is tx/rx, GND- pin 8
you need to use this 3 wires, battery must be attached
Old 05-20-2009, 15:47   #10 (permalink)
Member: 1024036
Thanks Meter: 14
thanks alot, I'll try
Can anyone teach me how to reflow PCB Crazy_ratata Sony Ericsson Hardware Repair 1 07-18-2007 11:35
can anyone teah me how to flash N70 slipknot4ever Nokia Digital Core Technology 4 ( DCT-4 ) 3 07-20-2006 22:17
can anyone teah me how to flash N70 slipknot4ever Nokia Digital Core Technology 4 ( DCT-4 ) 2 07-15-2006 22:49
Who can teach me how to flash? bbbbbb Nokia Digital Core Technology 4 ( DCT-4 ) 4 07-27-2004 12:19
Can anyone tell me how to flash blacks1967 Samsung Flashers, Software, Firmware. 2 08-25-2003 19:53
Page generated in 0.23498 seconds with 10 queries
