11-17-2008, 13:59 | #1 (permalink) |
Freak Poster Join Date: Feb 2007 Location: Pakistan (Layyah) Punjab Age: 37
Member: 453862 Status: Offline Thanks Meter: 53 | can i flash urdu or arabic in zong a136 can i flash urdu or arabic language in zong mobile if yes then plz upload that file if any body have debrand flash file of zte a136 plz upload here bcos when we flash it with zte 225 ringtoons are changed and new ones are not good plz plz anybody solve this problem |
11-17-2008, 16:29 | #2 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, It will be good if somebody can read full flash from the same good working phone and send full flash backup to [email protected] so we will be able to prepare and upload good working files in support area for all users. |
11-17-2008, 17:13 | #3 (permalink) |
No Life Poster Join Date: Oct 2005 Location: Islamabad--Pakistan
Member: 194128 Status: Offline Thanks Meter: 303 | Just download these files from ZTE-A136 folder from Support ZTE-A136_lp_CMPAK-P108A2B07-En-PK01_g3dBV2.0_Apr-24-2008.B1P ZTE-A136_main_CMPAK-P108A2B07-En-PK01_g3dBV2.0_Apr-24-2008.B1M In place of eeprom and FFS files use ZTE-225 files as mentioned in sticky thread. All remaining process is same as mentioned before in the sticky thread. Tested by me 100% worked. BEST OF LUCK! yawarniazi |
11-17-2008, 20:54 | #5 (permalink) |
Member: 194128 Status: Offline Thanks Meter: 303 | Unfortunately it happened only on 1 phone. Other one gets locked again after flashing original ZONG firmware. But I am sure, I have one phone in my hand which I unlocked this way. Now here is a question to @InfinitySupport: I have one phone unlocked with ZONG firmware inside (all done with Infinity). The phone is that one on which I tried first time and got success and in result my thread become sticky. I think it happed due to the reason I made many experiments on this phone. So now tell me should I send you the flashfiles of this unlocked phone?? Hopefully in this way can unlock the phone by flashing with Original Zong firmware. Waiting for a reply. Best Regards! yawarniazi |
11-17-2008, 23:43 | #6 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, if your firmware is the same as in message #3 it is no need to send backup files to us, but if firmware version is other please, send files to [email protected] |
11-18-2008, 05:40 | #7 (permalink) |
Member: 453862 Status: Offline Thanks Meter: 53 | i have done THANKS INFINITY TEAM I DOWNLOAD THESE FILE ZTE-225_LP_VDF-P108A2B06-ArFr-EG04_g3dBV2.0_May-29-2007_Ar_Fr.B1P ZTE-225_Main_VDF-P108A2B06-ArFr-EG04_g3dBV2.0_May-29-2007.B1M FROM SUPPORT AND FLASHED SUCCESSFULY WITH ARABIC LANGUAGE AND UNLOCK 100% OK I HAVE TRIED IN 3 PIECES LOGS ARE HERE ==== log opened: [11/17/2008 5:05:59 AM] ==== Application: C:\Program Files\InfinityBox\Pana01\Pana01.exe Loading data, wait... [Infinity Box] v1.52 S/N: 427F:0111 Wait... Current model: Avvio-103A Ready Current model: ZTE-225, Vodafone-225 Loading file v.02... ZTE-225_Main_VDF-P108A2B06-ArFr-EG04_g3dBV2.0_May-29-2007.B1M.bin loaded Loading file v.02... ZTE-225_LP_VDF-P108A2B06-ArFr-EG04_g3dBV2.0_May-29-2007_Ar_Fr.B1P.bin loaded Loading file v.02... ZTE-225_repair_ffs_01.B1F.bin loaded Loading file v.02... ZTE-225_repair_eeprom_complete_01.B1E.bin loaded ==== log: [11/17/2008 5:06:50 AM] ==== COM7 [VCP0] selected Device: ZTE-225, Vodafone-225 Checking data, wait... Action: flash write Boot... Press and HOLD Power button now (if boot does not start remove/install batery) ! loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud... 921600 Set Baud Done Connecting... flash: 00EC:257E Connecting Done Check hardware... Check hardware Done Check parameters... Check parameters Done backup critical area... reading [eeprom-sta]... file saved: C:\Documents and Settings\Administrator\Desktop\Zong\ZTE-225, Vodafone-225_eeprom-sta_20081117-050705.B1E.bin loading data... data loaded reading [eeprom-sec]... file saved: C:\Documents and Settings\Administrator\Desktop\Zong\ZTE-225, Vodafone-225_eeprom-sec_20081117-050709.B1E.bin reading [eeprom-complete]... file saved: C:\Documents and Settings\Administrator\Desktop\Zong\ZTE-225, Vodafone-225_eeprom-complete_20081117-050713.B1E.bin backup critical area Done Check memory... Check memory Done Write... Erasing: Firmware Writing: Firmware Erasing: Language Pack Writing: Language Pack Erasing: FFS-2/File system Writing: FFS-2/File system Erasing: Eeprom Writing: Eeprom Write Done Finished, Remove/Install battery now ! Time used: 128 sec ==== log: [11/17/2008 5:09:34 AM] ==== COM7 [VCP0] selected Device: ZTE-225, Vodafone-225 Checking data, wait... Action: unlock unlock method-1 Boot... Press and HOLD Power button now (if boot does not start remove/install batery) ! loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud... 921600 Set Baud Done Connecting... flash: 00EC:257E Connecting Done Check hardware... Check hardware Done Check parameters... Check parameters Done backup critical area... reading [eeprom-sta]... file saved: C:\Program Files\InfinityBox\Pana01\ZTE-225, Vodafone-225_eeprom-sta_20081117-050948.B1E.bin loading data... data loaded reading [eeprom-sec]... file saved: C:\Program Files\InfinityBox\Pana01\ZTE-225, Vodafone-225_eeprom-sec_20081117-050949.B1E.bin reading [eeprom-complete]... file saved: C:\Program Files\InfinityBox\Pana01\ZTE-225, Vodafone-225_eeprom-complete_20081117-050951.B1E.bin reading additional data... done backup critical area Done Check memory... current status: 0 Check memory Done Write... Erasing: lock-area Writing: lock-area Write Done Finished, Remove/Install battery now ! Time used: 20 sec Unlock instruction: 1. Power-On phone 2. Enter code: 12345678 |
The Following User Says Thank You to Tahir Riaz For This Useful Post: |
11-18-2008, 14:52 | #8 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | @Tahir Riaz Thank you very much for test report ! Each test report with attached logs is very important for us so we can see how is Infinity-Box software works and what is possible problems and successfully done work. |
11-21-2008, 13:49 | #9 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, Please, try to use this new Pana01 v1.56 software: http://www.infinity-box.com/download...na01_v1.56.rar We are waiting for your results. |
huawei t161l language urdu or arabic | drjaved_akhter | Infinity-Box | 1 | 05-01-2009 08:19 |
G800 Urdu Or Arabic Language File Need... | multicom_fsdpk | NSPRO | 4 | 05-07-2008 18:37 |
V8 Urdu Or Arabic File Need.... | multicom_fsdpk | Smart-Clip | 1 | 04-23-2008 15:21 |
@ Lead. Can we Flash U8120 with Arabic files ? | rjsoo7 | Cruiser Suite | 3 | 07-08-2005 15:05 |
Can i flash 9210 or 9210i with cheap flasher or i should use any orther? | mmoda | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 04-18-2003 17:21 |
