03-29-2009, 17:22 | #1 (permalink) |
No Life Poster Join Date: Sep 2006
Member: 343326 Status: Offline Thanks Meter: 1,463 | Can i recover this china phone I got dead china set. I try to clean the complete board in Elma. After that phone take info from Chinies Miracle V.79 I try to read detailed info but it show this....... Code: COM15 [VCP1] selected module v2.79 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled Action: read/check detailed information Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A03:8A00]... CPU: MT6225 high speed boot On chip: 0001:0B03:0003 status: FF boot packet size: 0400 Release Power button now ! Boot Done Initialize ... detecting chip #00 in region #00... flash: EC257E25082501:FFFFFF00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #01 in region #00... flash: EC257E25082501:FFFFFF00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #02 in region #00... flash: EC257E25082501:FFFFFF00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #03 in region #00... flash: EC257E25082501:FFFFFF00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb number of flash chip/regions detected: 04/01 Initialize Done Set baud ... 460800 Set baud Done Initialize bootcode ... Initialize bootcode Done Check firmware integrity ... device parameters autodetection in progress... detecting chip #00 in region #00... flash: EC257E25082501:FFFFFF00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb Warning: probably flash chip is empty, erased, incorrectly flashed or damaged ! What to do: 1. go to software "Settings" page 2. set "Advanced chip detection method" box UN-CHECKED ! 3. make flash write operation If still no luck: send mail to support ([email protected]) with detailed description of problem, attach the next files in your e-mail: 1. C:\Program Files\InfinityBox\ChineseMiracle\operation.log 2. C:\Program Files\InfinityBox\ChineseMiracle\cfi_xxxx_xxxx.bin detecting chip #01 in region #00... flash: EC257E25082501:FFFFFF00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb it's time to stop: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device identification#1... detection phase #1... . detection phase #2... ................................................................................................................................................................................................................................................................ warning: identification#1 information not found, possible reasons: .old firmware type w/o identification#1 data .damaged firmware .damaged hardware if phone works fine just ignore this warning detect device identification#1 finished detect device identification#2... detection phase #1... . detect device identification#2 finished detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset assigned: 00E00000 flash: EC257E25082501:FFFFFF00000000 checking area [00000000]: 00000000-00FFFFFF... Can't detect ffs/eeprom area Do you want to use standard ffs/eeprom address: 00E00000 ? If you are not sure that standard address is correct: 1. press "NO" and terminate current operation 2. make flash backup for emergency case 3. repeat required operation standard ffs/eeprom address selected by user detecting ffs/eeprom size... ffs/eeprom size: 00200000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:00E00000-00FFFFFF detecting ffs/eeprom structure pass 1... ...................... detect standard fat location pass #1... .................................................. detect standard fat offset pass #1... detect standard fat data... fat layout detection complete ffs/eeprom detected ok: element #1 detecting ffs/eeprom structure pass 2... ...................... detect standard fat location pass #1... .................................................. detect standard fat offset pass #1... detect standard fat data... fat layout detection complete ffs/eeprom detected ok element #2 Check firmware integrity Done Check firmware content ... Check firmware content Done Backup required data ... Finished, time used: 157 sec Remove/Install battery now ! |
can i recover this v3i error with ph sig err:35.02 | aikonmani | Smart-Clip | 2 | 03-17-2009 15:14 |
problem with this china phone | alfox | Infinity-Box | 4 | 09-14-2008 22:06 |
problem with this china phone V9+i | alfox | Infinity-Box | 3 | 09-13-2008 06:26 |
"Help Me" to flash this china phone | piratekhan2 | Chinese Models & Cloned Phones | 1 | 07-04-2008 06:08 |
pls, any help for this china phone | ballybaka | Phone Unlocking Codes & Maps | 1 | 12-19-2007 09:19 |
