06-09-2015, 11:13 | #1 (permalink) |
No Life Poster Join Date: May 2001 Location: Bulgaria Age: 56
Member: 4627 Status: Offline Sonork: 57528:debeliamark Thanks Meter: 1,034 | CM2MTK strange error Here is the log from phone with 4Gb eMMC connected without battery and volume down pressed / same and with battery also /: Code: Card found: S/N 0714:0xx8 Chinese Miracle II [MTK module] v 1.21 Scatter Load Ok , BaseBand : MT6589 , Project : MTK6589 , Storage : eMMC Files found : 13 , Set to Flash : 12 Ready to Flash! Operation : Flash [ v1.21 ] ======= Flash 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 69 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6583 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0001 BB_CPU_NM : [MediaTek] MT6583|6589_S00 Processing BROM stage SecCfgVal : 0x00000000 BromVersion : 0x05 BLVersion : 0xFE Preloader Status : Not active (Erased) Processing DA stage DA Select done , sending NAND_ID : 00000000000000000000000000000000 eMMC_ID : 4D6F6465524F4D200600464EE3000000 DA Stat : v3.2 on BBID : 0x86 DRAM not initialized , configure DRAM Settings DRAM EmiReq Ok , 0x00B8 Error : DA init Failed! Error code : 0x5 LErr : EMICFG_NOT_FOUND Boot Error! Operation Failed Elapsed: 00:00:03 Reconnect Power/Cable! |
06-09-2015, 11:27 | #2 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Hello. DA sends as eMMC info "ROMMode" message , which not belongs to eMMC CID data. Something wrong with eMMC , seems. If possible - need check HW and know more about phone manipulations history. |
06-09-2015, 12:35 | #3 (permalink) |
Member: 4627 Status: Offline Sonork: 57528:debeliamark Thanks Meter: 1,034 | well - i will take out stupid 4Gb eMMC - H9TP32A8JDMC - to read it on EasyJTAG eMMC addon to see where is the problem with it ... so it's possible to write Android Parts by defined in scater addresses and lenght direct on eMMC socket wiith EasyJTAG ? |
06-09-2015, 13:01 | #4 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Better just write whole dump from same phone. If via scatter - it uses shift addres (old scat format used in 6583/89) for block 0 preloader data must be with EMMCBOOT magic block ( there is not enough just write preloader , need first 800 (or something like that) bytes from this. Can be used any from same MT6583/89) , 40000 - next block and e.t.c. ... Boot region, used in those MTK - is BOOT_1 , if not wrong and all rest data inside it. After writing all parts - if eMMC is alive ( not sure in that ) - it should power on. You can check if emmc is alive by trying write/read something from it and check crc of data. |
06-09-2015, 17:56 | #6 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Yeah, as expected - it dead. I planning add in some of next versions simple detection of bad/emmc problems. It not a 100% results, but can help well in some cases. |
06-09-2015, 18:07 | #7 (permalink) |
Member: 4627 Status: Offline Sonork: 57528:debeliamark Thanks Meter: 1,034 | In any case i saw that MTK CPU can handle eMMC like mass storage very well and is easy to put full image(s) in eMMC partitions, even avoid EasyJTAG connection, but here opposite to Samsung's eMMC this one hynix cannot be repaired ( reflash controller FW ) ... so - will get another one from some Nuvi device or from some Lenovo P780 - they have a lot of them with damaged RF IC - a so bad developed and produced phones with so big market share - cannot believe that peoples still want to buy it. |
06-09-2015, 18:20 | #8 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Need to make sure about FW for this phone ( preloader ) support new eMMC chip , due ComboMemory compatibility restrictions. As far, as know - hynix have ability to upgrade fw , but it in private yet. So - maybe, they will be repairable in future. |
06-10-2015, 05:12 | #9 (permalink) | |
Member: 4627 Status: Offline Sonork: 57528:debeliamark Thanks Meter: 1,034 | Quote:
Will write results when i find a good same eMMC in try to repair stupid Lenovo, hope all will have a happy end. | |
06-11-2015, 09:00 | #10 (permalink) |
Member: 4627 Status: Offline Sonork: 57528:debeliamark Thanks Meter: 1,034 | After eMMC change flashing work: Code: Card found: S/N 0714:0xx8 Chinese Miracle II [MTK module] v 1.21 Scatter Load Ok , BaseBand : MT6589 , Project : MTK6589 , Storage : eMMC Files found : 14 , Set to Flash : 13 Ready to Flash! Operation : Flash [ v1.21 ] ======= Flash 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 38 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6583 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0001 BB_CPU_NM : [MediaTek] MT6583|6589_S00 Processing BROM stage SecCfgVal : 0x00000000 BromVersion : 0x05 BLVersion : 0xFE Preloader Status : Not active (Erased) Processing DA stage DA Select done , sending NAND_ID : 00000000000000000000000000000000 eMMC_ID : 204A0190594E4958CFA116489B40CDE7 DA Stat : v3.2 on BBID : 0x86 DRAM not initialized , configure DRAM Settings DRAM EmiReq Ok , 0x00B8 DRAM Init Ok , 0x40000000 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0090 , OEM : 014A [eMMC] : FLASH_INF : HYNIX [eMMC] : FLASH_CID : 90014A2058494E594816A1CFE7CD409B [eMMC] : FLASH_LEN : 0x00000000E7000000 INT RAM : 0x00020000 EXT RAM : 0x40000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! ScatCFG : BaseBand : MT6589 , Project : MTK6589 , Storage : eMMC Setting : Flash Pre-Erase (Safe) : Enabled Setting : AFF verify : Enabled Switching to HSUSB HSUSB Init Ok BL : Check HW compatibility BL : BBID supported by BootLoader! BL : Check eMMC compatibility BL : eMMC supported by BootLoader! BL : Flash Pre-Erase Total blocks to Erase : 2 Erase : 0x0000000000600000-0x0000000000100000 Erase : 0x0000000002720000-0x000000008B11C000 Flash Pre-Erase Done, time used : 00:00:06 SecCfg Passed , 1799 BMT remark not need. Will skip Sending Preloader ... Use : preloader_s820_row.bin Preloader Sent , Init passed SecCfg Passed , 1799 PartCount : FFFFFFFF PartErr : Not initialized , will update PMT now ... Repartition Done! Processing : Flash Write Flash now : MBR Image Flash Ok Flash now : EBR1 Image Flash Ok Flash now : UBOOT Image Flash Ok Flash now : BOOTIMG Image Flash Ok Flash now : RECOVERY Image Flash Ok Flash now : SEC_RO Image Flash Ok Flash now : PRELOAD Image Flash Ok Flash now : LOGO Image Flash Ok Flash now : EBR2 Image Flash Ok Flash now : ANDROID Image Flash Ok Flash now : CACHE Image Flash Ok Flash now : USRDATA Image Flash Ok Flash now : FAT Image Flash Ok Flash Write Done, time used : 00:04:24 Processing : Verify Verify Passed : MBR Verify Passed : EBR1 Verify Passed : UBOOT Verify Passed : BOOTIMG Verify Passed : RECOVERY Verify Passed : SEC_RO Verify Error! Something went wrong! ErrCode : 0xA345 Done! Elapsed: 00:05:00 Reconnect Power/Cable! Phone stay on logo with small words in low left corner : => TOOL DL Image fail! => uboot is blocking by dl info and after half minute reboots till same screen. Forcing to enter Factory mode ( volume up + power on ) or Meta Mode ( volume down + poower on ) do not make anything ( just a sentences "Have been in ..." ) Brrrr.... Some hint? |
06-11-2015, 11:50 | #13 (permalink) | |
Super Moderator Join Date: Jul 2009 Location: .:India:.
Member: 1078689 Status: Offline Sonork: 100.1626373 Thanks Meter: 2,826 | Quote:
Already Infinity Have Solution For "Fix DL" Button In Service Tab. You Can Solve This Error By Single Click Without Flashing. http://forum.gsmhosting.com/vbb/11088143-post8.html | |
The Following User Says Thank You to MyGSM World For This Useful Post: |
