04-08-2010, 21:30 | #2 (permalink) |
Freak Poster Join Date: Mar 2008 Location: somali
Member: 717872 Status: Offline Sonork: 100.1589423 Thanks Meter: 22 | yes u can unlock it COM7 selected module v1.39 Device: LG-KP170 (under test) Checking data, wait... advanced flash detection enabled Action: unlock unlock method: enhanced Boot ... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting, wait... Release Power button now ! flash: 01227E223C2200:FEEA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 007Ex040000 0004x010000] 32Mb id: 00005283 Boot Done Set baud ... 460800 Set baud Done Check flash ... current eeprom imei: 350300000000001 file saved: J:\Program Files\InfinityBox\LGA\eeprom_350305260000001_LG-KP170 (under test)_20091217-121221.B1E.bin .................................................. .............. Check flash Done Check space ... current eeprom imei: 350300000000001 Check space Done Check parameters ... Check parameters Done Erase ... Erase Done Write ... write: lock area-1 Write Done Finished, time used: 98 sec Remove/Install battery now ! |
The Following User Says Thank You to baooshe2 For This Useful Post: |
04-09-2010, 15:43 | #7 (permalink) |
Member: 717872 Status: Offline Sonork: 100.1589423 Thanks Meter: 22 | look bro i unlock more then 30 kp170 ==== log: [3/24/2010 6:03:47 PM] ==== COM39 [VCP0] selected module v1.39 Device: LG-KP170 (under test) Checking data, wait... advanced flash detection enabled Action: reset Boot ... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting, wait... Release Power button now ! flash: 01227E223C2200:FEEA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 007Ex040000 0004x010000] 32Mb id: 00005283 Boot Done Set baud ... 921600 Set baud Done Check flash ... current eeprom imei: 350305260000001 file saved: D:\program files\InfinityBox\LGA\eeprom_350305260000001_LG-KP170 (under test)_20100324-180403.B1E.bin .................................................. .............. reading _eeprom-ffs_350305260000001... file saved: D:\program files\InfinityBox\LGA\_eeprom-ffs_350305260000001_LG-KP170 (under test)_20100324-180831.B1E.bin Check flash Done Check space ... Check space Done Check parameters ... Check parameters Done Erase ... Erase Done Write ... Write Done Finished, time used: 334 sec Remove/Install battery now ! |
04-09-2010, 15:43 | #8 (permalink) |
Member: 717872 Status: Offline Sonork: 100.1589423 Thanks Meter: 22 | ==== log opened: [3/20/2010 12:25:01 PM] ==== Application: D:\Program Files\InfinityBox\LGA\LgA.exe Loading data, wait... [Infinity Box] v1.39 S/N: 5DFF:0116 Wait... Device: LG-KP170 (under test) Done WARNING ! Settings will be cleared, user data erased ! Make eeprom backup before this operation ! Continue ? Testing COM39 at 115200... ==== log: [3/20/2010 12:25:32 PM] ==== COM39 [VCP0] selected module v1.39 Device: LG-KP170 (under test) Checking data, wait... advanced flash detection enabled Action: reset Boot ... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting, wait... Release Power button now ! flash: 01227E223C2200:FEEA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 007Ex040000 0004x010000] 32Mb id: 00005283 Boot Done Set baud ... 115200 Set baud Done Check flash ... current eeprom imei: 350305260000001 file saved: D:\Documents and Settings\admin1\Desktop\eeprom_350305260000001_LG-KP170 (under test)_20100320-122602.B1E.bin .................................................. .............. reading _eeprom-ffs_350305260000001... file saved: D:\program files\InfinityBox\LGA\_eeprom-ffs_350305260000001_LG-KP170 (under test)_20100320-124316.B1E.bin Check flash Done Check space ... Check space Done Check parameters ... Check parameters Done Erase ... Erase Done Write ... Write Done Finished, time used: 1360 sec Remove/Install battery now ! |
can i unlock kp 170 with ult plz help | asif_ae | ULT PRO | 3 | 06-26-2009 16:44 |
any body know when the add micro-box unlock kp-170 | MOBIL CLINIC | Basic Micro-Box Software Support (SAMSUNG, HUAWEI, etc...) | 5 | 06-21-2009 00:32 |
can i unlock kp 170 with multi box plz help | asif_ae | Multi-Box | 1 | 04-13-2009 07:35 |
how to unlock kp 170? | ikram tabassum1 | Infinity-Box | 4 | 03-13-2009 10:16 |
I HWK flash WD2 as long as it is on the phone in tips months. | XIAOLIMIN | HWK | 4 | 03-17-2008 03:51 |
