Can i use pad with infinity?an error i have pinfinder for infinity-now purchased PAD also-tried in chineese miracle-an error as below detected-details as below Ready... Rx pin: 10 Tx pin: 12 Power: OFF Ready... Detecting pinout: please push and HOLD power button! (Push box button to Abort) Processing, please wait...OK Rx - 10 Tx - 12 then i minimise this window and open infinity chineese miracle-in settings select PAD COM36-TRIED FROMAT FFS-BUT AN ERROR AS BELOW. EEROR COM36 NOT AVAILABLE. why this error? help me thank u |
Try to change to COM port of PAD Finder, lower than 36. I think it should be less than 10 and best should be COM2 COM3 or COM4. Try and post result. BEST OF LUCK yawarniazi |
whatever com it may be its ok...press unibox mode in padfinder soft for you to use it with infinity.. |
Good advice, I realy appreciate this. Best Regards! yawarniazi |
yes-its the correct answer thank u |
