08-17-2008, 21:43 | #1 (permalink) |
Freak Poster Join Date: Jul 2006 Location: sprinfield usa. Age: 36
Member: 309769 Status: Offline Thanks Meter: 50 | !can" Imei Repair Chinese Iphone But 5 Of 7 Ok !!!!help 7 CHINESE IPHONE I REPAIR IMEI OK IN 5 BUT I "VE 2 PCS THAT CANT DO IT LOOK THIS SAY WHEN I CHANGE IMEI OK Action: imei Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched ON ! Connecting, wait... Phone detected, wait... Hardware version: MT6226, E02 Hardware version: MTK6226_06a_HW Software version: MAUI.06A.W06.40.F1" Software date: 2005.04.12 Barcode: MT012345678901234567 imei: 355256060035480 imei write method: mode-1 new imei: 350338355378647 imei verified Ok Finished, time used: 5 sec Power off phone now ! BUT IN OTHER 2 SAY Action: imei Model: Autodetect 6228, 6230 NAND Checking data, wait... Phone should be Switched ON ! Connecting, wait... Phone detected, wait... Hardware version: MT6226, E02 Hardware version: MTK6226_06a_HW Software version: MAUI.06A.W06.40.F1" Software date: 2005.04.12 Barcode: MT012345678901234567 imei: 135790246811220 imei write method: mode-1 imei write channel: imei #1 for dual sim/mono-CPU new imei: 350448011234561 imei verification failed Operation failed ! Finished, time used: 4 sec Power off phone now ! OR Action: imei Model: Autodetect 6228, 6230 NAND Checking data, wait... Phone should be Switched ON ! Connecting, wait... Phone detected, wait... Hardware version: MT6226, E02 Hardware version: MTK6226_06a_HW Software version: MAUI.06A.W06.40.F1" Software date: 2005.04.12 Barcode: MT012345678901234567 imei: 135790246811220 imei write method: mode-1 imei write channel: imei #1 for dual sim/mono-CPU new imei: 350448011234561 imei verification failed Operation failed ! Finished, time used: 4 sec Power off phone now ! WHAT CAN I DO ??? |
08-24-2008, 00:45 | #9 (permalink) | |
Member: 309769 Status: Offline Thanks Meter: 50 | Quote:
MODE-3 COM290 [USBSER000] selected Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled Action: "repair imei" imei write method: mode-3 imei write channel: imei #1 for dual sim/mono-CPU new imei: 350448011234561 Boot... Press and HOLD Power button now ! 19200 fixed Connecting, wait... error: boot phase#1 failed Release Power button now ! in case of initial connection problem: on/off "Boot baudrate autoselect" box. Boot Fail Finished, time used: 2 sec Remove/Install battery now ! | |
08-24-2008, 02:03 | #10 (permalink) |
Member: 309769 Status: Offline Thanks Meter: 50 | AND WITH THE FBUS CABLE SERIAL METOD 3 COM3 [VCP4] selected Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled Action: "repair imei" imei write method: mode-3 imei write channel: imei #1 for dual sim/mono-CPU new imei: 350338354693731 Boot... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing[6226:8A02:8A01]... CPU: MT6226 high speed boot disabled chip: 0031:52C1:F8E2 high speed disabled boot step size: 0002 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... flash: 01227E22202200:2AEA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb detecting chip #01 in region #00... flash: 01227E22202200:2AEA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb number of flash chip/regions detected: 02/01 Initialize Done Set baud... slowest Set baud Done Initialize bootcode... Initialize bootcode Done Check firmware integrity... device parameters autodetection in progress.. detecting chip #00 in region #00... flash: 01227E22202200:2AEA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb detecting chip #01 in region #00... flash: 01227E22202200:2AEA0000000000 error: no any expected answer: wrong answer after chip cfi request flash: 01227E22202200:2AEA0000000000 flash: Amd PL127J D 16Mb it's time to stop: 2A0000EA18F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [enhanced] generation security area#1 is Ok security area#1 backup saved: C:\Archivos de programa\InfinityBox\ChineseMiracle\backup_securit y\id.B1F0F36E.[MTK6226_06A_PCB01_GPRS_MT6226_S01.MAUI_06A_W06_40_ F1.BIN_B874FD0F].rpl ==================== New firmware detected: MTK6226_06A_PCB01_GPRS_MT6226_S01.MAUI_06A_W06_40_ F1.BIN - make "Read full flash" operation - send "backup_system_log_..." file to support: [email protected] - send flash backup file(s) to support: [email protected] - include in your e-mail full text from phone back label (phone name etc.) ==================== identification#1 detection finished device-id: B1F0F36E identification#1 protocol ver: 05 ver. sw1: MTK6226_06A_PCB01_GPRS_MT6226_S01.MAUI_06A_W06_40_ F1.BIN ver. sw2: MAUI.06A.W06.40.F1, F0028B47 ffs offset/size: 00E00000/00200000 detect device identification#2... detection phase #1... . warning: optional information is not found, if phone works well just ignore this warning detect device identification#2 finished detecting eeprom/ffs area in 1 chip(s)... standard eeprom/ffs offset detected: 00E00000 flash: 01227E22202200:2AEA0000000000 checking area[00000000]: 00000000-00FFFFFF... eeprom/ffs found near: 00E00000 detecting eeprom/ffs size... eeprom/ffs size: 00200000 ffs chip: 00 eeprom/ffs area: 00000000:00E00000-00FFFFFF Check firmware integrity Done Check firmware content... Check firmware content Done Backup required data... reading: eeprom[MTK6226_06A_PCB01_GPRS_MT6226_S01.MAUI_06A_W06_40_ F1.BIN]... file saved: C:\Archivos de programa\InfinityBox\ChineseMiracle\eeprom[MTK6226_06A_PCB01_GPRS_MT6226_S01.MAUI_06A_W06_40_ F1.BIN]_20080823-195815.B0E.bin flash: 01227E22202200:2AEA0000000000 Backup required data Done Patch required data... imei is not detected ! What to do: 1. Power-On phone 2. wait 20-30 sec 3. Power-Off by "Power" button, don't remove battery ! 4. Repeat "repair imei" procedure again If imei can't be detected: 1. make "complete" ffs format 2. Power-On phone 3. wait 20-30 sec 4. Power-Off by "Power" button, don't remove battery ! 5. Repeat "repair imei" procedure again If imei can't be detected: read flash and send to support: [email protected] Patch required data Fail file saved: C:\Archivos de programa\InfinityBox\ChineseMiracle\system_log_B1F 0F36E_MTK6226_06A_PCB01_GPRS_MT6226_S01.MAUI_06A_W 06_40_F1.BIN_B874FD0F_20080823-200131.B0X.bin Finished, time used: 1466 sec Remove/Install battery now ! |
08-24-2008, 21:56 | #11 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! have you followed advice give by program & mr. ezzis ? complete format, power On phone, wait 20-30sec, power off mobile and repeat IMEI-3 procedure? |
12-21-2008, 10:29 | #12 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | @whitt1234 Your offtopic message was deleted. Here is Infinity-Box support forum but not discussion about anything else. Just for your information: Infinity-Box is The Most Powerful software to repair Chinese models. |
IMEI Repair for Iphone 2G with 2.2 working !! | cooleyes | iPhone 2 / iPhone 3G / iPhone 3GS | 55 | 01-25-2010 17:42 |
im need frimwear for repair chinese iphone 3g | delchoni | Infinity-Box | 16 | 11-03-2009 20:35 |
Nokia 6103 dead after imei repair, done with latest update of UB !!! | DJiCE | Universalbox | 3 | 07-25-2008 02:21 |
P2K Ultimate Box, Unlocking, IMEI Repair, Chinese flash repair and more! | VictorGSM | Main Sales Section | 0 | 07-31-2002 04:36 |
