Old 03-12-2016, 12:16   #1 (permalink)
Member: 1001635
Thanks Meter: 63
Can infinity team help me in this case...
Can infinity team help me in this case........
Gionee P4 hangs on logo
Old 03-12-2016, 12:58   #2 (permalink)
vishnudatt's Avatar
Member: 1306196
Sonork: 100.1654602 (08104048625)
Thanks Meter: 592
Arrow
go to -Operation : HW Test [ v1.43 ]
Old 03-13-2016, 16:45   #3 (permalink)
Member: 1001635
Thanks Meter: 63
Wait for phone...
Phone found! [ 8 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6582
BB_CPU_NME : [MediaTek] MT6582_S00
Processing BROM stage
Settings for BROM configured!
SecCfgVal : 0x00000000
BromVer : 0x00FF
BLVersion : 0x0001
BootLdrSS : NORMAL with SPRELOADER
Processing DA stage
DA Select done, will use MTK_AllInOne_DA_v5.1552.01.01
Sending and initialize DA ...
Running DA ver.4.2 on BBID : 0x87
NAND Flash : NOT INSTALLED
eMMC Flash : 1501004B3758564D420129B8CED93185
Initialize Memory ...
eMMC FlashIC initialized
[eMMC] : FLASH_INF : [SAMSUNG] , BMVX7
[eMMC] : FLASH_CID : 1501004B3758564D420129B8CED93185
[eMMC] : FLASH_LEN : 0x00000001D2000000
[eMMC] : FLASH_UCP : 7456 MiB [eMMC 8 GiB]
DEV RID : 79CB3288C6CCE1E1C11F78FA0A0A91F8
INT RAM : 0x00020000
EXT RAM : 0x40000000
BOOT TYPE : EMMC_FLASH_BOOT
SOC VERIFY : C1
Boot Ok!
[Processing] FlashMemory Read-Write test
[eMMC] : [SAMSUNG] , BMVX7 , 0x1D2000000 , 7456 MiB
[eMMC] : CID : 1501004B3758564D420129B8CED93185
[eMMC] : MODE : SQ-WR
[FAILED : READONLY] : eMMC state seems as READ-ONLY !!!!
Operation Failed
Elapsed: 00:00:41
Reconnect Power/Cable!
Plz help..................
Old 03-13-2016, 16:54   #4 (permalink)
JayDi's Avatar
Member: 462970
Thanks Meter: 14,696
Answer in log :
It mean eMMC is DAMAGED.
Change required.
The Following User Says Thank You to JayDi For This Useful Post:
Old 03-13-2016, 19:10   #5 (permalink)
johnmadzeka1's Avatar
Member: 2377686
Sonork: 100.1668474
Thanks Meter: 188
Talking
Originally Posted by JayDi View Post
Answer in log :
Change required.
This is very good now we can test to see if its software or HW problem
Old 03-13-2016, 19:26   #6 (permalink)
Crazy Poster
Member: 2536280
Thanks Meter: 21
For Samsung Emmc U can Repair
Need A Emmc Tool
Now Remove Emmc
Remove The Write Protection With Emmc Tool
Now Solder it again but solution is 4 temporary better change Emmc
Old 03-13-2016, 19:29   #7 (permalink)
JayDi's Avatar
Member: 462970
It can live week. Can few hours.
Sure, if resolder emmc/program it/solder back - it is 5 minute work with good skills - it not a problem.
Old 03-14-2016, 11:07   #8 (permalink)
Member: 1001635
Thanks Meter: 63
It has Mtk6582 cpu and samsung kmk7x000vm-b314 emmc.
Where is the emmc pin out??????????(I use atf box)
[IMG][/IMG]
Page generated in 0.24818 seconds with 7 queries
