10-21-2015, 13:40 | #1 (permalink) |
No Life Poster Join Date: Apr 2006 Location: INDIA Age: 38
Member: 269044 Status: Offline Sonork: 100.1590584 Thanks Meter: 3,949 | Can lg e445 be support on cm2:- I TRIED TO CONNECT WITH CM2 BUT NO SUCCEEDED WBR sahil2000ind |
10-21-2015, 15:02 | #4 (permalink) |
No Life Poster Join Date: Oct 2007 Location: In My Limit
Member: 610502 Status: Offline Sonork: 100.1618428 Thanks Meter: 161 | Respected Jaydi Thanks.. I Have a Suggestion for the team, Respected Team have you noticed that many people (Software Professionals) in the world is coming/Attracting towards Infinity Team due to your Hard work and Devotion. So Please if possible try to read the User's Need and Fulfill them i know its a very tough job but you have to do it for the sake of Your Name and Tool also. If you will ignore my suggestion then may be one day you will better realize what i have said. As much work done by CM2K as much its sale will be increased..... A well wisher of Infinity Team. Sheraz..... |
The Following User Says Thank You to BISMILLAH MOBILES For This Useful Post: |
10-21-2015, 15:32 | #5 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Sometimes I need sleep, eat, make something other, instead of work. As you can see - we fullfill requests. Most of requested CPU's/features is already done. |
The Following 10 Users Say Thank You to JayDi For This Useful Post: |
10-21-2015, 16:43 | #6 (permalink) | |
No Life Poster Join Date: Sep 2006 Location: ---> Hope
Member: 355782 Status: Offline Thanks Meter: 1,265 | and as I know most of users decide to buy tool after reading support and features and not for support request purpose (but user can ask fix bug for already supported phone). Quote:
we should understand they cant do multiple things at the same time. Tool can sense a phone within a second but you dont know how many minutes consumed for this 1 second. | |
The Following User Says Thank You to Nasir Mobiles For This Useful Post: |
12-15-2015, 17:24 | #8 (permalink) |
Super Moderator Join Date: Jul 2009 Location: .:India:.
Member: 1078689 Status: Offline Sonork: 100.1626373 Thanks Meter: 2,826 | Dear Friends, It's just For Test, Nothing Else Please. Operation : Check / Read Info [ v1.39 ] Code: 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 13 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6575 BB_CPU_HW : CB00 BB_CPU_SW : 8A00 BB_CPU_SB : E201 BB_CPU_NM : [MediaTek] MT6575|MT6577_S00 Processing BROM stage i2c Init : 00000000 SpeedSet : 0000 VChrgSet : 0x28 , BatStat : 0x02 WD Disable stat : 0x0000 BLVersion : 0xFE SecCfgVal : 0x00000000 BromVersion : 0x05 BLVersion : 0xFE Preloader Status : Not active (Erased) Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v5.1540.01.01 DA Stat : v3.2 on BBID : 0x84 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0090 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , d1G4 [eMMC] : FLASH_CID : 90014A4834473164048601A3B281315B [eMMC] : FLASH_EXT : 0x00200000 , 0x00200000 , 0x00200000 [eMMC] : FLASH_LEN : 0x00000000E7000000 [eMMC] : FLASH_UCP : 3696 MiB INT RAM : 0x00020000 EXT RAM : 0x00000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! [AP] : Initial info read Ok! Brand : lge ProdName : vee4ds_open_esa ProdModel : LG-E445 Device : vee4ds AndroidVer: 4.1.2 MTKxCPU : MT6575 MTKxPRJ : ALPS.JB.TC1.SP.V13 MODEM : BaseBand : MT6575_S01_11AMDW1222_TC1_SP_W13_12 Done! Elapsed: 00:00:08 Reconnect Power/Cable! Operation : Read Flash [ v1.39 ] Code: 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 13 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6575 BB_CPU_HW : CB00 BB_CPU_SW : 8A00 BB_CPU_SB : E201 BB_CPU_NM : [MediaTek] MT6575|MT6577_S00 Processing BROM stage i2c Init : 00000000 SpeedSet : 0000 VChrgSet : 0x28 , BatStat : 0x02 WD Disable stat : 0x0000 BLVersion : 0xFE SecCfgVal : 0x00000000 BromVersion : 0x05 BLVersion : 0xFE Preloader Status : Not active (Erased) Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v5.1540.01.01 DA Stat : v3.2 on BBID : 0x84 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0090 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , d1G4 [eMMC] : FLASH_CID : 90014A4834473164048601A3B281315B [eMMC] : FLASH_EXT : 0x00200000 , 0x00200000 , 0x00200000 [eMMC] : FLASH_LEN : 0x00000000E7000000 [eMMC] : FLASH_UCP : 3696 MiB INT RAM : 0x00020000 EXT RAM : 0x00000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Reading Flash Conent now ... USBDL : Init HSUSB Ok! Read Ok , collect info Brand : lge ProdName : vee4ds_open_esa ProdModel : LG-E445 Device : vee4ds AndroidVer: 4.1.2 MTKxCPU : MT6575 MTKxPRJ : ALPS.JB.TC1.SP.V13 Saved to : D:\InfinityBox\CM2MTK\Flash\MT6575__LGE__LG-E445__vee4ds_open_esa__vee4ds__ALPS.JB.TC1.SP.V13__Android_4.1.2__20140118_110741.ispff Done! Elapsed: 00:29:30 Reconnect Power/Cable! |
12-15-2015, 17:51 | #9 (permalink) | |
No Life Poster Join Date: Dec 2013 Location: ecuador
Member: 2078045 Status: Offline Thanks Meter: 151 | firmware file requered Quote:
bro requered firmware file upload | |
