06-22-2009, 16:49 | #2 (permalink) |
No Life Poster Join Date: Feb 2007 Location: Where the cash @... Age: 38
Member: 450871 Status: Offline Sonork: 100.1592197 Thanks Meter: 121 | You got the pin outs in your software. All you need is follow instructions given by software. Or read user manual. |
06-22-2009, 20:50 | #4 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | How to write flash (upgrade/downgrade firmware, change language): 1. connect cable from box to device 2. run "Infinity-Box Shell" software 3. select required model 4. run required software module 5. select required model (if need) 6. go to software "Settings" page and select COM port 7. go to software "Flash" page and load required files 8. press "Write" button and follow instruction given by software How to read flash: 1. connect cable from box to device 2. run "Infinity-Box Shell" software 3. select required model 4. run required software module 5. select required model (if need) 6. go to software "Settings" page and select COM port 7. go to software "Service" page 8. press "Read flash" (or "Read full flash") button and follow instruction given by software How to unlock (remove sp-lock, provider lock etc.): 1. connect cable from box to device 2. run "Infinity-Box Shell" software 3. select required model 4. run required software module 5. select required model (if need) 6. go to software "Settings" page and select COM port 7. go to software "Service" page 8. press "SP-Unlock" button and follow instruction given by software How to reset/format ffs (reset setting to default values, repair freez/restart etc.): - at first try to make "safe format" (if this option exist) - if "safe" option is not works try to make "complete" format (if this option exist) 1. connect cable from box to device 2. run "Infinity-Box Shell" software 3. select required model 4. run required software module 5. select required model (if need) 6. go to software "Settings" page and select COM port 7. go to software "Service" page 8. select format mode "safe" or "complete" (if mode is available) 9. press "Reset" or "Format" button and follow instruction given by software |
06-22-2009, 21:13 | #6 (permalink) | |
Here is an instruction how to get cable/pinout information: 1. be sure that you have downloaded and installed latest Infinity-Box Pinouts update 2. run Infinity-Box Shell 3. select required model 4. see detailed information about cable/pinout (Rx/Tx/Gnd pins and other information) Here is an example of information given by Infinity-Box Shell: Here is information how to build your own cable: http:///vbb/showthread.php?t=342807 | |
06-26-2009, 17:56 | #9 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, Here is an instruction how to get cable/pinout information: 1. be sure that you have downloaded and installed latest Infinity-Box Pinouts update 2. run Infinity-Box Shell 3. select required model 4. see detailed information about cable/pinout (Rx/Tx/Gnd pins and other information) Here is an example of information given by Infinity-Box Shell: Here is information how to build your own cable: http:///vbb/showthread.php?t=342807 |
Unlock ZTE X760 100% MasterBox | LuisinhoCell | Mastertools | 5 | 01-01-2010 09:36 |
In which box we can unlock zte x760 it look same like orange vigas | rajan nishchal | Basic Micro-Box Software Support (SAMSUNG, HUAWEI, etc...) | 2 | 06-18-2009 16:11 |
unlock zte x760 possible? | sasan14 | FuriousGold | 3 | 06-10-2009 07:22 |
Problem unlocking ZTE X760 | jerrel_s | Infinity-Box | 1 | 05-26-2009 14:44 |
Is unlockable ZTE X760?? | wildjoker | FuriousGold | 2 | 05-13-2009 22:40 |
