06-13-2008, 16:44 | #1 (permalink) |
Junior Member Join Date: Apr 2008
Member: 743742 Status: Offline Thanks Meter: 0 | can not reset or unlock Gtide W110 phone is locked.. COM17 [VCP4] selected Device: G-Tide-W110 Checking data, wait... Action: unlock unlock method-1 Boot... Press and HOLD Power button now (if boot does not start remove/install batery) ! loading... next part... error: can't run main loader: 8200 Finished, Remove/Install battery now ! Time used: 4 sec COM17 [VCP4] selected Device: G-Tide-W110 Checking data, wait... Action: reset Boot... Press and HOLD Power button now (if boot does not start remove/install batery) ! loading... next part... error: can't run main loader: FF Finished, Remove/Install battery now ! Time used: 5 sec |
06-17-2008, 15:09 | #3 (permalink) |
Member: 743742 Status: Offline Thanks Meter: 0 | yes sir I fully inserterted also I tried by removing cover same. today i downloaded new version V1.50 problem same! software version: 1.10 cable type: 1x18 (L18A) platform: PMB: Infineon e-gold searching adapter at COM17... adapter found, version: 2000 pins: 18, plain power cycles: 1 activation cycles: 10 power-off delay: 20 start Rx/Tx: 1/1 Loading configuration... Initializing... Press and HOLD phone Power button now ! detecting pins... e-gold (820000) result: Rx:8 Tx:4 time required: 57 sec Power On ! Last edited by surayya; 06-17-2008 at 15:14. |
08-25-2008, 12:35 | #5 (permalink) |
Freak Poster Join Date: May 2008
Member: 767451 Status: Offline Thanks Meter: 178 | Device: G-Tide-W110 Checking data, wait... Action: unlock unlock method-1 Boot... Press and HOLD Power button now (if boot does not start remove/install batery) ! loading... next part... error: can't run main loader: 8200 Finished, Remove/Install battery now ! Time used: 4 sec COM17 [VCP4] selected Device: G-Tide-W110 Checking data, wait... Action: reset Boot... Press and HOLD Power button now (if boot does not start remove/install batery) ! loading... next part... error: can't run main loader: FF Finished, Remove/Install battery now ! Time used: 5 sec ./ why get this pls help gtide w110 |
06-17-2009, 16:01 | #11 (permalink) |
Crazy Poster Join Date: Dec 2005 Location: harare
Member: 207257 Status: Offline Thanks Meter: 2 | no cable is 100% ok i have just tested one today with the same message on infinity ,and used the same cable same phone to connect with vodafone sagem software and i was able to interact software and phone on model 225 ,but didnt managed to unlock it |
How can hard reset or flash hp ipaq voice messenger | askaralikp | HTC & PDA WM( With Touchscreen) | 0 | 02-24-2010 09:57 |
can not reset box usage | sandrea | Ultima Box Light | 0 | 03-24-2009 10:51 |
can not reset TS10!! | KUBAT1 | Infinity-Box | 6 | 04-04-2008 09:37 |
Can not reset security code Nokia 6131 | Leshy | HWK | 1 | 06-13-2006 13:28 |
