03-08-2019, 18:17 | #1 (permalink) |
Freak Poster Join Date: Dec 2002 Location: Zooropa Age: 42
Member: 18832 Status: Offline Thanks Meter: 18 | Can not start CM2SPD module I use latest 1.27 version, it was working up until some weeks ago. I thought maybe it was because my support was expired, so today I renewed support, but it is still not opening. I can run CM2QLM and CM2MTK without problems. I tried reinstalling. I tried deleting whole folder before reinstalling. No fault.bin in the program folder. No USB sharing and tracing programs on my PC. Please advise how I can run the software. Thank you. |
03-08-2019, 18:39 | #2 (permalink) | |
No Life Poster Join Date: Dec 2004 Location: Uganda Age: 45
Member: 96478 Status: Offline Sonork: 100.1674604 Thanks Meter: 1,420 | Quote:
1. If you have Fault.bin inside Cm2 SPD Folder attach it here 2. Uninstall usb sharing /sniff/monitor/debug softwares (like flexihub etc.) . 3. PC is infected with virus, as a result CM2 files (exe and/or dll) become changed damaged or some strange files are in folder with CM2. Solution: Scan Pc with a trusted antivirus. 4.Delete CM2 folder completely and re-install it. | |
The Following User Says Thank You to Kirumira For This Useful Post: |
03-09-2019, 08:47 | #3 (permalink) | |
support renew has effect for newly released software only. Old modules should work. What new software was installed at your PC during last days ? any kind of antivirus or anyrhing else ? | |
04-05-2019, 09:55 | #4 (permalink) |
Member: 18832 Status: Offline Thanks Meter: 18 | I never use antivirus software, and not using any debugging software, aswell. I am out of ideas. in operation.log i see this ========================= Start ========================= 2019.04.05. / 10:59:57 ================================================== ======= Card found: S/N : 0C794D35 , v0137 Chinese Miracle II [SPD module] v 1.27 Last edited by lc5829; 04-05-2019 at 10:00. |
04-05-2019, 11:05 | #6 (permalink) |
Member: 18832 Status: Offline Thanks Meter: 18 | As you say. Just writes this log file, and gone. Not showing up in process explorer. In the meantime I managed to run it on my Win XP machine, but tried 3 more different PCs with Win 10 and Win 7, none of them works. |
04-05-2019, 11:06 | #7 (permalink) |
No Life Poster Join Date: Feb 2017 Location: Quelimane Mz Age: 26
Member: 2680008 Status: Offline Thanks Meter: 1,640 | 3. PC is infected with virus, as a result CM2 files (exe and/or dll) become changed damaged or some strange files are in folder with CM2. Solution: Scan Pc with a trusted antivirus. 4.Delete CM2 folder completely and re-install it. |
04-05-2019, 14:25 | #8 (permalink) | |
Member: 148515 Status: Offline Thanks Meter: 19,534 | Quote:
have you installed any software, updates etc. to your PC last days ? | |
04-05-2019, 15:45 | #9 (permalink) |
Member: 18832 Status: Offline Thanks Meter: 18 | Nothing special. The usual stuff I use for other boxes, I don't think I will ever find the problem software, unless we know for sure with what it is not compatible. |
04-05-2019, 16:56 | #10 (permalink) | |
Member: 541591 Status: Offline Sonork: 100.1611509 Thanks Meter: 7,361 | Quote:
If you are sure that there is no usb sharing, debug, spy, logger etc installed/running in your pc then try to scan your pc with some good Antivirus once. You can try with free version even. You can try THIS Br. Infinity-Box Team. | |
04-05-2019, 21:21 | #11 (permalink) | |
Download and run Sysinternals Process Explorer - https://docs.microsoft.com/en-us/sys...ocess-explorer Do you see in running process list any kind of sharing/trace or similar process ? | |
