Old 03-27-2008, 20:03   #1 (permalink)
cdma-india's Avatar
Member: 98139
Thanks Meter: 126
can pinfinder work as uni cables?
TO infinity team i want to know just that can pinfinder can work as unicables?
today i got spice d88 dsm-cdma handset with security code enable , but i dont have cable so i tried with autopinfinder by manual seting rx tx 7 8 resp but spice software not able to detect the handset i tried all cpu available in list also swaping rx tx also all possible way but no result
plz make next update as unicables so no need to store maximum cables , also save time to make cables
thanks for good support
Old 03-27-2008, 20:57   #2 (permalink)
Member: 148515
Thanks Meter: 19,534
hello!
you can use pinfinder as interface with any phone.
very important that even if you not use "find it" function and set pins manualy- still phone must be powered from box (not from battery)
in your case i think you set wrong pins.
2 row connectors have special pinout
open user manual and check your specific connector pinout at the bottom of document.
Old 03-27-2008, 20:58   #3 (permalink)
Member: 148515
also one row connectors pins can be counted from 2 sides
can be also mistake in your case
Old 03-27-2008, 21:09   #4 (permalink)
cdma-india's Avatar
Member: 98139
Thanks Meter: 126
yes phone is powering on with adaptor also i am tried like this 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 ,
18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1
7 8 as rx tx and reverse way
12 11 as rx tx and reverse way
but no succsess
thanks for quick replay
ps: way there is no gnd option like rx tx
Old 03-28-2008, 01:35   #5 (permalink)
Member: 148515
hello!
GND is taken via battery negative terminal
to get communication you must run program, push "detect adapter"
select cable L18 then set tx/rx pins 7/8 and push "power"
from now must RED led must be On all the time
this means box is delivering power to phone.
try to boot it as TX=7, RX=8 & TX=8, RX=7
and also TX=11, RX=12 & TX=12, RX=11
Old 03-28-2008, 06:42   #6 (permalink)
cdma-india's Avatar
Member: 98139
Thanks Meter: 126
yes allredy done same process as u told but no succsess , all china set with mtk detects well ,but i dont know way i am fail with this model by the way thanks i will make new cable for spice d88
Old 03-28-2008, 11:13   #7 (permalink)
Member: 130995
Thanks Meter: 35,227
Hello,
D88 has MT62xx CPU, so you can try to autodetect pinout for this phone too.
If pinout can't be detected it may be that phone connector is damaged.
Old 03-28-2008, 11:40   #8 (permalink)
cdma-india's Avatar
Member: 98139
Thanks Meter: 126
finaly i done thanks
Old 03-28-2008, 11:58   #9 (permalink)
Member: 148515
hello!
what was mistake? not presented POWER on phone terminals?
Old 03-28-2008, 16:32   #10 (permalink)
Member: 682988
Thanks Meter: 45
can we find pinout for dead phones?
Old 03-28-2008, 18:20   #11 (permalink)
Member: 130995
Yes, you can find pinout without problems for models with good hardware but damaged software.
Old 03-28-2008, 19:40   #12 (permalink)
cdma-india's Avatar
Member: 98139
Thanks Meter: 126
hello!
i dont know what was realy happend ysterday, i repeted all steps as u explain and all is well , one point i am waching red light should glow during procedure ,
thanks infinity team, u r number one for best support
Old 04-07-2008, 21:15   #13 (permalink)
gsmsikar's Avatar
Member: 28004
Sonork: 100.1601142
Thanks Meter: 770
this is very good news that infinity pinfinder can also work as universal cable ..
thanks infinity team...
Old 04-07-2008, 21:23   #14 (permalink)
Member: 148515
hello!
it can work as universal cable for other models- this is one thing.
another thing that it can use not only original cables, but it can work with all others which have RJ45 connector.
for example- you can use UFS cables
Old 04-09-2008, 05:44   #15 (permalink)
gsmsikar's Avatar
Member: 28004
Sonork: 100.1601142
Thanks Meter: 770
hello!
thanks ir
how to use a UFS cable with Infinity ?
BB5TP cables, can we use this as Fbus cable for all model?? xileen2k Universalbox 3 12-02-2008 03:39
polar box as uni box afrar PolarBox 3 1 09-24-2008 10:22
How Can I Use My Uni Cables With Pinfinder sabby_singh Infinity-Box 3 02-21-2008 15:18
Can I use ust-pro2 cables as data cable for upload ringtones? malacatonche UST Pro II 0 07-06-2006 04:46
Multibox as uni-box Windziarz Multi-Box 22 07-12-2005 11:44
Page generated in 0.20921 seconds with 10 queries
