Can Unlock c139 v1.0.24 By Infinity how to unlock this moto by infinity |
Hello, How to write flash (upgrade/downgrade firmware, change language): 1. connect cable from box to device 2. run "Infinity-Box Shell" software 3. select required model 4. run required software module 5. select required model (if need) 6. go to software "Settings" page and select COM port 7. go to software "Flash" page and load required files 8. press "Write" button and follow instruction given by software How to read flash: 1. connect cable from box to device 2. run "Infinity-Box Shell" software 3. select required model 4. run required software module 5. select required model (if need) 6. go to software "Settings" page and select COM port 7. go to software "Service" page 8. press "Read flash" (or "Read full flash") button and follow instruction given by software How to unlock (remove sp-lock, provider lock etc.): 1. connect cable from box to device 2. run "Infinity-Box Shell" software 3. select required model 4. run required software module 5. select required model (if need) 6. go to software "Settings" page and select COM port 7. go to software "Service" page 8. press "SP-Unlock" button and follow instruction given by software How to reset/format ffs (reset setting to default values, repair freez/restart etc.): - at first try to make "safe format" (if this option exist) - if "safe" option is not works try to make "complete" format (if this option exist) 1. connect cable from box to device 2. run "Infinity-Box Shell" software 3. select required model 4. run required software module 5. select required model (if need) 6. go to software "Settings" page and select COM port 7. go to software "Service" page 8. select format mode "safe" or "complete" (if mode is available) 9. press "Reset" or "Format" button and follow instruction given by software |
ok i know that but this model need test or cut track like c117 because i cut track and phone still working |
Hi, if this phone still can power-on after you have cutted track this means that it's newest phone PCB type and it's need to remove CPU N1 ball. |
thanks yellowboss for helping |
method of conect #4 . unlocking phono ok. no tp necesary |
PPRROOCCEESS CONFIGURATIONS CONECTION #4 ==== log opened: [09/03/2010 10:27:26] ==== Application: C:\Archivos de programa\InfinityBox\Moto01\Moto01.exe Loading data, wait... [Infinity Box] v1.48 S/N: XXXXXXXXXXXXXXXXX Current model: C113(a),C114,C115,C116,C117,C118 Ready Current model: C139,C140 COM3 ready COM3 [VCP3] selected Action: unlock Device: C139,C140 Checking data, wait... Connect... Press and HOLD Power button... connection mode: 00 error: boot failure[04]: general communication fault. Release Power button ! Connect Fail Finished, time used: 12 sec Remove/Install battery now ! COM3 [VCP3] selected Device: C139,C140 Press and HOLD Power button... error: bad connection COM3 [VCP3] selected Action: unlock Device: C139,C140 Checking data, wait... Connect... Press and HOLD Power button... connection mode: 01 error: boot failure[07]: version mismatch, other connection settings should be used. Release Power button ! Connect Fail Finished, time used: 11 sec Remove/Install battery now ! COM3 [VCP3] selected Action: unlock Device: C139,C140 Checking data, wait... Connect... Press and HOLD Power button... connection mode: 02 error: boot failure[04]: general communication fault. Release Power button ! Connect Fail Finished, time used: 9 sec Remove/Install battery now ! MMEETTHHOODD #4 COM3 [VCP3] selected Action: unlock Device: C139,C140 Checking data, wait... Connect... Press and HOLD Power button... connection mode: 02 Release Power button ! Connect Done Boot... Boot Done Set Baud... 460800 Set Baud Done Check Flash-1... SW version: 1.0.24 HW version: _E88 LP ver: LPL_C139_LATAM_Z0W Flex ver: FFL_C139_3Q_Y0W imei otp: 010967000236073 Check Flash-1 Done Check Flash-2... reading ... file saved: C:\Archivos de programa\InfinityBox\Moto01\backup_eeprom_calibrat ion_010967000236073_20100309-102919.31E.bin imei eeprom: 010967000236073 Check Flash-2 Done Write... Write Done Finished, time used: 18 sec Remove/Install battery now ! PHONE AFTER UNLOCK IS HACKED... here solution. Current model: C139,C140 Loading file v.02... C139_1.0.06_Main.31M.bin loaded Loading file v.02... C139_1.0.06_LPL_LATAM_00F_En_Es_Pt.31P.bin loaded Loading file v.02... C139_1[1].0.06_Flex_FFL_58_10F_Tigo_708-01.31M.bin loaded COM3 [VCP5] selected "smart write" active Action: flash Write: Firmware Write: Language Pack Write: Flex Skip: Eeprom Device: C139,C140 Checking data, wait... Connect... Press and HOLD Power button... connection mode: 00 error: boot failure[04]: general communication fault. Release Power button ! Connect Fail Finished, time used: 9 sec Remove/Install battery now ! COM3 [VCP5] selected "smart write" active Action: flash Write: Firmware Write: Language Pack Write: Flex Skip: Eeprom Device: C139,C140 Checking data, wait... Connect... Press and HOLD Power button... connection mode: 00 error: boot failure[07]: version mismatch, other connection settings should be used. Release Power button ! Connect Fail Finished, time used: 21 sec Remove/Install battery now ! COM3 [VCP5] selected "smart write" active Action: flash Write: Firmware Write: Language Pack Write: Flex Skip: Eeprom Device: C139,C140 Checking data, wait... Connect... Press and HOLD Power button... connection mode: 00 error: boot failure[04]: general communication fault. Release Power button ! Connect Fail Finished, time used: 9 sec Remove/Install battery now ! COM3 [VCP5] selected "smart write" active Action: flash Write: Firmware Write: Language Pack Write: Flex Skip: Eeprom Device: C139,C140 Checking data, wait... Connect... Press and HOLD Power button... connection mode: 00 error: boot failure[07]: version mismatch, other connection settings should be used. Release Power button ! Connect Fail Finished, time used: 10 sec Remove/Install battery now ! COM3 [VCP5] selected "smart write" active Action: flash Write: Firmware Write: Language Pack Write: Flex Skip: Eeprom Device: C139,C140 Checking data, wait... Connect... Press and HOLD Power button... connection mode: 02 Release Power button ! Connect Done Boot... Boot Done Set Baud... 460800 Set Baud Done Check Flash-1... SW version: 1.0.24 HW version: _E88 LP ver: LPL_C139_LATAM_Z0W Flex ver: FFL_C139_3Q_Y0W imei otp: 010967000236073 Check Flash-1 Done Check Flash-2... reading ... file saved: C:\Archivos de programa\InfinityBox\Moto01\backup_eeprom_calibrat ion_010967000236073_20100309-104135.31E.bin imei eeprom: 010967000236073 Check Flash-2 Done Write... Writing: Firmware Writing: Language Pack Writing: Flex Write Done Finished, time used: 157 sec Remove/Install battery now ! phone ok .. and working and UNlocked |
help me Quote:
can u post these files to me |
