Old 03-10-2010, 11:58   #1 (permalink)
Member: 591084
Thanks Meter: 31
Can Unlock c139 v1.0.24 By Infinity
how to unlock this moto by infinity
Old 03-10-2010, 12:55   #2 (permalink)
Member: 1043909
Thanks Meter: 51,301
Hello,
How to write flash (upgrade/downgrade firmware, change language):
1. connect cable from box to device
2. run "Infinity-Box Shell" software
3. select required model
4. run required software module
5. select required model (if need)
6. go to software "Settings" page and select COM port
7. go to software "Flash" page and load required files
8. press "Write" button and follow instruction given by software
How to read flash:
7. go to software "Service" page
8. press "Read flash" (or "Read full flash") button and follow instruction given by software
How to unlock (remove sp-lock, provider lock etc.):
8. press "SP-Unlock" button and follow instruction given by software
How to reset/format ffs (reset setting to default values, repair freez/restart etc.):
- at first try to make "safe format" (if this option exist)
- if "safe" option is not works try to make "complete" format (if this option exist)
8. select format mode "safe" or "complete" (if mode is available)
9. press "Reset" or "Format" button and follow instruction given by software
The Following User Says Thank You to YellowBoss For This Useful Post:
Old 03-10-2010, 13:05   #3 (permalink)
Member: 591084
Thanks Meter: 31
ok i know that but this model need test or cut track like c117
because i cut track and phone still working
Old 03-10-2010, 14:24   #4 (permalink)
Member: 1043909
Hi,
if this phone still can power-on after you have cutted track this means that it's newest phone PCB type and it's need to remove CPU N1 ball.
Old 03-10-2010, 14:42   #5 (permalink)
avtarkaint's Avatar
Member: 452162
Sonork: 100.1592470
Thanks Meter: 423
thanks yellowboss for helping
Old 03-10-2010, 16:01   #6 (permalink)
Member: 715429
Thanks Meter: 258
method of conect #4 . unlocking phono ok. no tp necesary
Old 03-10-2010, 16:24   #7 (permalink)
Member: 715429
Thanks Meter: 258
PPRROOCCEESS
CONFIGURATIONS
CONECTION #4
==== log opened: [09/03/2010 10:27:26] ====
Application: C:\Archivos de programa\InfinityBox\Moto01\Moto01.exe
Loading data, wait...
[Infinity Box] v1.48
S/N: XXXXXXXXXXXXXXXXX
Current model: C113(a),C114,C115,C116,C117,C118
Ready
Current model: C139,C140
COM3 ready
COM3 [VCP3] selected
Action: unlock
Device: C139,C140
Checking data, wait...
Connect...
Press and HOLD Power button...
connection mode: 00
error: boot failure[04]: general communication fault.
Release Power button !
Connect Fail
Finished, time used: 12 sec
Remove/Install battery now !
Device: C139,C140
error: bad connection
Action: unlock
Device: C139,C140
Connect...
connection mode: 01
error: boot failure[07]: version mismatch, other connection settings should be used.
Connect Fail
Finished, time used: 11 sec
Action: unlock
Device: C139,C140
Connect...
connection mode: 02
Connect Fail
Finished, time used: 9 sec
MMEETTHHOODD #4
Action: unlock
Device: C139,C140
Connect...
connection mode: 02
Connect Done
Boot...
Boot Done
Set Baud...
460800
Set Baud Done
Check Flash-1...
SW version: 1.0.24
HW version: _E88
LP ver: LPL_C139_LATAM_Z0W
Flex ver: FFL_C139_3Q_Y0W
imei otp: 010967000236073
Check Flash-1 Done
Check Flash-2...
reading ...
file saved: C:\Archivos de programa\InfinityBox\Moto01\backup_eeprom_calibrat ion_010967000236073_20100309-102919.31E.bin
imei eeprom: 010967000236073
Check Flash-2 Done
Write...
Write Done
Finished, time used: 18 sec
PHONE AFTER UNLOCK IS HACKED... here solution.
Loading file v.02...
C139_1.0.06_Main.31M.bin loaded
C139_1.0.06_LPL_LATAM_00F_En_Es_Pt.31P.bin loaded
C139_1[1].0.06_Flex_FFL_58_10F_Tigo_708-01.31M.bin loaded
COM3 [VCP5] selected
"smart write" active
Action: flash
Write: Firmware
Write: Language Pack
Write: Flex
Skip: Eeprom
Device: C139,C140
Connect...
connection mode: 00
Connect Fail
Action: flash
Write: Firmware
Write: Flex
Skip: Eeprom
Device: C139,C140
Connect...
connection mode: 00
Connect Fail
Finished, time used: 21 sec
Action: flash
Write: Firmware
Write: Flex
Skip: Eeprom
Device: C139,C140
Connect...
connection mode: 00
Connect Fail
Action: flash
Write: Firmware
Write: Flex
Skip: Eeprom
Device: C139,C140
Connect...
connection mode: 00
Connect Fail
Finished, time used: 10 sec
Action: flash
Write: Firmware
Write: Flex
Skip: Eeprom
Device: C139,C140
Connect...
connection mode: 02
Connect Done
Boot...
Boot Done
Set Baud...
460800
Set Baud Done
Check Flash-1...
SW version: 1.0.24
HW version: _E88
Check Flash-1 Done
Check Flash-2...
reading ...
file saved: C:\Archivos de programa\InfinityBox\Moto01\backup_eeprom_calibrat ion_010967000236073_20100309-104135.31E.bin
Check Flash-2 Done
Write...
Writing: Firmware
Writing: Language Pack
Writing: Flex
Write Done
Finished, time used: 157 sec
phone ok .. and working and UNlocked
Old 03-11-2010, 10:44   #8 (permalink)
anurag_arora's Avatar
Member: 712290
Thanks Meter: 62
help me
Originally Posted by residentdenuevo View Post
PPRROOCCEESS
CONFIGURATIONS
CONECTION #4
Ready
COM3 ready
Action: unlock
Device: C139,C140
Connect...
connection mode: 00
Connect Fail
Device: C139,C140
Action: unlock
Device: C139,C140
Connect...
connection mode: 01
Connect Fail
Action: unlock
Device: C139,C140
Connect...
connection mode: 02
Connect Fail
MMEETTHHOODD #4
Action: unlock
Device: C139,C140
Connect...
connection mode: 02
Connect Done
Boot...
Boot Done
Set Baud...
460800
Set Baud Done
Check Flash-1...
SW version: 1.0.24
HW version: _E88
Check Flash-1 Done
Check Flash-2...
reading ...
Check Flash-2 Done
Write...
Write Done
Action: flash
Write: Firmware
Write: Flex
Skip: Eeprom
Device: C139,C140
Connect...
connection mode: 00
Connect Fail
Action: flash
Write: Firmware
Write: Flex
Skip: Eeprom
Device: C139,C140
Connect...
connection mode: 00
Connect Fail
Action: flash
Write: Firmware
Write: Flex
Skip: Eeprom
Device: C139,C140
Connect...
connection mode: 00
Connect Fail
Action: flash
Write: Firmware
Write: Flex
Skip: Eeprom
Device: C139,C140
Connect...
connection mode: 00
Connect Fail
Action: flash
Write: Firmware
Write: Flex
Skip: Eeprom
Device: C139,C140
Connect...
connection mode: 02
Connect Done
Boot...
Boot Done
Set Baud...
460800
Set Baud Done
Check Flash-1...
SW version: 1.0.24
HW version: _E88
Check Flash-1 Done
Check Flash-2...
reading ...
Check Flash-2 Done
Write...
Writing: Firmware
Writing: Flex
Write Done
can u post these files to me
unlock c139 airtel set unlockinr with infinity rbisystems Motorola ODM 1 09-15-2007 10:29
Cingular's C139 v1.9.24 NEW type jepetu Smart-Clip 7 08-20-2007 07:26
can mss box2 can unlock c139 v 8.8.17 ???? Muneer Ahmed MSS Box II 4 07-04-2007 11:08
>> Enter My Unlock Code v1.0 eng by BouRRi_GSM << BouRRi_GSM Universal GSM Software 28 04-30-2007 08:51
can i unlock C139 v1.3.29 in infinity? shafeek Infinity-Box 7 11-24-2006 18:35
Page generated in 0.37648 seconds with 8 queries
