Cannot Flash S288 Please assist i can not flash my S288. It gives this error: COM50 selected Checking data, wait... Phone should be Switched OFF ! Connect... Press Power button now ! Connect Ok Boot... Boot Ok Read info... FLASH: 20A0 Read info Ok Set baud... 115200 Set baud Ok Check flash... Check flash Ok Check space... Check space Ok Write... Write: Firmware Error: ERASE[FE]: 00000000 Write fail Finished Remove/Install battery now ! Time used: 15 sec Infinity,what do you think is wrong? |
Hi, What is phone condition now and what is this phone history ? Also, try to flash phone at 38400 baud. |
Before,it was coming on but then go off as you try to make a call. Let me try flashing at 38400 and post result. |
Try deffrent flash files this happen to me many time but keep on trying it will work mybe the team will tell you more |
In this case it can be phone hardware problem. Open phone and check it, maybe it's water damage. |
