Old 11-12-2005, 11:58   #1 (permalink)
Member: 163019
Thanks Meter: 9
Cannot Flash S288
Please assist i can not flash my S288.
It gives this error:
COM50 selected
Checking data, wait...
Connect...
Press Power button now !
Connect Ok
Boot...
Boot Ok
Read info...
FLASH: 20A0
Read info Ok
Set baud...
115200
Set baud Ok
Check flash...
Check flash Ok
Check space...
Check space Ok
Write...
Write: Firmware
Error: ERASE[FE]: 00000000
Write fail
Finished
Remove/Install battery now !
Time used: 15 sec
Infinity,what do you think is wrong?
Old 11-14-2005, 04:16   #2 (permalink)
InfinitySupport's Avatar
Member: 130995
Thanks Meter: 34,290
Hi,
What is phone condition now and what is this phone history ?
Also, try to flash phone at 38400 baud.
Old 11-14-2005, 06:34   #3 (permalink)
Member: 163019
Thanks Meter: 9
Originally Posted by InfinitySupport
Hi,
Right now the phones does not power on totally.
Before,it was coming on but then go off as you try to make a call.
Let me try flashing at 38400 and post result.
Old 11-14-2005, 07:21   #4 (permalink)
Mansoor's Avatar
Member: 45561
Thanks Meter: 59
Try deffrent flash files this happen to me many time but keep on trying it will work mybe the team will tell you more
Old 11-14-2005, 12:34   #5 (permalink)
Member: 130995
Hi,
In this case it can be phone hardware problem. Open phone and check it, maybe it's water damage.
2330c cannot unlock, cannot flash. hugmax MXKEY Nokia Flasher and Unlocker (by Alim Hape) 9 10-23-2009 01:11
KG225 cannot connect - cannot flash? Kasper VygisToolbox 2 08-07-2007 20:39
Cannot flash myx-5m with sagmaster "wrong flash image" sandokaan ARM9 BASED M62 / M62+ 0 04-03-2005 20:38
I Cannot Flash S300 With Opti Flash I Need Full Instraction Step BY Step Mahmudul Trident/AGERE Platform 9 09-22-2003 22:29
Page generated in 0.31102 seconds with 8 queries
