07-09-2010, 16:48 | #1 (permalink) |
No Life Poster Join Date: Dec 2002 Location: Brazil
Member: 18726 Status: Offline Thanks Meter: 26 | cannot repair imei on LG Gb190a LG-GB190a_A7213_07A_PCB01_GPRS_MT6223_S00.GB190AOL-01-V10A-724-06-SEP-11-2009__ffs_20100710-122502 i am try to method 1 , method 2 and method 3 and never successfull... see the screen : Action: "repair imei" Modelo: LG-GB190a Verificando Dados. Aguarde... O Telefone Deverá Estar LIGADO! Conectando. Aguarde... baud set to: 115200 Telefone Encontrado. Aguarde... Método de Escrita do IMEI: Modo-1 new imei-1: 01201700728xxxx Verification failed, what to do: 1. Power-Off phone 2. Press software "Escrever" button 3. Power-On phone Falha Na Operação! Finalizado. Tempo Gasto: 1 min 18 sec Remova/Recoloque a Bateria! |
07-10-2010, 13:04 | #3 (permalink) | |
15th digit should be calculated automatically from first 14 digits. You can find 15th digit calculation specification in google. | |
07-10-2010, 22:34 | #4 (permalink) |
Member: 18726 Status: Offline Thanks Meter: 26 | the problem is not calculation of 15 digits,the problem is the digit number 15 cannot write !!! write 14 digits, example > 352535458754843 > the digit 3 in phone is 0 but the correct is 3, but phone cannot write this,insists on digit 0,its a bug from Mmodule 3.49 from 07/07/2010. |
07-11-2010, 17:48 | #5 (permalink) | |
07-02-2011, 16:14 | #6 (permalink) |
Freak Poster Join Date: Feb 2005 Location: Pampas Gaúcho tchê Age: 48
Member: 116335 Status: Offline Thanks Meter: 17 | I have had problem to write the imei too. But now. my phone is dead after complet format and I can't write backup. I have got flash write error always. Could You help me with that? ---------------------------------------------------------------------------- COM178 [VCP0] selected module v3.96 Device: LG-GB190a Checking data, wait... advanced flash detection enabled Action: write flash "smart write" active "format ffs" active write: Firmware GB190b_A7213_07A_PCB01_GPRS_MT6223_S00.GB190BOL-01-V10A-724-05-MAR-18-2010_En_Es_Pt.B0M.bin skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6223:8A05:8A00]... CPU: MT6223 high speed boot On chip: 0011:B5A7:000C status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 89890100040089:89890100000000 flash: Intel ST [def 0080x040000] 32Mb otp offset: 00000000 number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 921600 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: [standard] type (04) TCL-ID is absent ==================== New firmware found (v.3.96, database date: 21.06.2011): A7213_07A_PCB01_GPRS_MT6223_S00.GB190BOL-01-V10A-724-05-MAR-18-2010.BIN This firmware is missing in support area. If this phone is good and working: - download latest software from support area and try again, probably this firmware already supported in latest software - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to RapidShare AG, Cham, Switzerland or http://4shared.com - include in your e-mail full text from phone back label (phone name etc.) ==================== rom info detection finished rom info ver: 04 sw version: A7213_07A_PCB01_GPRS_MT6223_S00.GB190BOL-01-V10A-724-05-MAR-18-2010.BIN project-id: GB190bOL-01-V10a-724-05-MAR-18-2010, 00000000 code offset: 00000000 ffs offset/size [01]: 01400000/00C00000 rom info structure: [standard] type (04) TCL-ID is absent ffs/eeprom address assigned: 01400000 sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... sec info (fast) detection... searching sec info#1... . search sec info#1 finished usb bootloader (file) is absent startup code area #1 check... done Area: Firmware flash: 89890100040089:89890100000000 Write: Firmware error: no any expected answer error: flash write error: 00C00000:00002000 error: error# 000000FF error: flash write error: 00C00000:00002000 error: no any expected answer error: flash write error: 00C00000:00002000 error: write operation failed Write Fail Finished, time used: 10 min 51 sec Remove/Install battery now ! |
07-04-2011, 15:35 | #8 (permalink) | |
Member: 116335 Status: Offline Thanks Meter: 17 | Quote:
I put 8 x zero after I had made format, then I went to restore imei, but it did not change. then i made format again and phone have not powered anymore. I changed the interface, now the software finish the procedure but phone still does not power on.also with backup from phone made while phone working well. I sent the full backup to Your email | |
6110 power does not stay on | sc~micro | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 6 | 08-30-2014 08:14 |
what prog changes imei on 6110 and how do i do it? | Ravetrancer | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 07-31-2012 20:09 |
Nokia 51xx/61xx imei changer ver. 1.10?????? | Ravetrancer | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 04-06-2012 16:22 |
6110 imei changer !!!!!! | Ravetrancer | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 5 | 11-21-2011 01:44 |
