07-25-2011, 10:17 | #1 (permalink) |
Freak Poster Join Date: Sep 2008 Location: In The World
Member: 861211 Status: Offline Sonork: 000000 Thanks Meter: 127 | Cannot support CPU: 6253:8A02:8A00 module v3.31 Device: Autodetect 6228-6268 NAND Checking data, wait... Action: read firmware NAND interface: BROM_DLL_v3.1016.00 Connect... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting... Booting... Release Power button now ! bootcode current/expected: 3.2/3.2 CPU: 6253:8A02:8A00 status: FF bbchip bl ver: FE NOR flash chip: not installed NAND flash chip: not installed internal RAM size: 00020000 external RAM: absent done Set baudrate (115200)... done error: no any detected/known flash chip found: 0BC0:S_DA_DEVICE_NOT_FOUND error: last error: 0BC0:S_DA_DEVICE_NOT_FOUND Disconnect... done Finished, time used: 41 sec Remove/Install battery now ! |
07-25-2011, 11:02 | #3 (permalink) | |
Member: 861211 Status: Offline Sonork: 000000 Thanks Meter: 127 | Quote: CPU: 6253:8A02:8A00. Sir yellow Please Fix This is Trouble with CPU: 6253:8A02:8A00. | |
08-11-2011, 22:34 | #6 (permalink) |
Freak Poster Join Date: Dec 2006
Member: 410795 Status: Offline Thanks Meter: 31 | Blu Q200 dead! when i try to flash it just get error, here is the log: COM2 [VCP0] selected module v3.96 Device: _Autodetect MT6253 NOR Checking data, wait... Action: write flash write: Firmware Blu-Q200_HEXING53_09A_GEMINI_PCB01_GPRS_MT6253_S00.X22 1_6G_DB_VV_V001_110512.BIN_FLNPF38F4050M0Y3DE_2011-05-13_En_Nl_Fr.B0M.bin skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs No licensed to produce fix... warning: firmware do not have this kind of fault nor area detection... "format ffs" active interface: BROM_DLL_v3.1016.00 Connect... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting... Booting... Release Power button now ! bootcode current/expected: 3.2/3.2 CPU: 6253:8A02:8A00 status: FF bbchip bl ver: FE NOR flash id[00C2]: 00EC:220800000000 [SAMSUNG] K5N5666ATB chip size: 32Mb otp status/size: S_DA_NOR_OTP_NOT_SUPPORT/00000000 NAND flash chip: not installed internal RAM size: 00020000 external RAM: absent done Set baudrate (115200)... done ram test... testing 32bit... 32bit ram test passed testing 16bit... 16bit ram test passed ram test passed ===> detect existing firmware structure... detect ffs... detect sec ro... detect custom parameters... detect project-id... detect NOR info... number of areas/bytes to read: 1:00050000 reading (HW_STORAGE_NOR)... warning: ffs can not be detected TCL-ID detection... TCL-ID detection done startup code area #1 detection... startup code area #1 detection done code offset: 00000000 ===> done ==================== New firmware found (v.3.96, database date: 21.06.2011): This firmware is missing in support area. If this phone is good and working: - download latest software from support area and try again, probably this firmware already supported in latest software - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to RapidShare – Secure Data Logistics or 4shared.com - free file sharing and storage - include in your e-mail full text from phone back label (phone name etc.) ==================== startup code area #1 check... done number of cores: 1 loading files... number of areas: 1 done write... write core... error: can not write flash (0): 0FA8:S_FT_DOWNLOAD_FAIL error: last error: 0FA8:S_FT_DOWNLOAD_FAIL Disconnect... done Finished, time used: 1 min 44 sec Remove/Install battery now ! |
08-26-2011, 16:46 | #8 (permalink) |
Freak Poster Join Date: Jan 2005 Location: santo domingo Age: 45
Member: 103844 Status: Offline Thanks Meter: 21 | Q200 dead, try with model Q200 and 6253NOR COM1 [VCP0] selected module v4.01 Device: _Autodetect MT6253 NOR Checking data, wait... Action: write flash write: Firmware Blu-Q200_HEXING53_09A_GEMINI_PCB01_GPRS_MT6253_S00.X22 1_6E_DB_VV_V001_110402.BIN_FLNS71VS128RC0AHK4L0_20 11-04-02_En_Nl_Fr.B0M.bin skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs nor area detection... interface: BROM_DLL_v3.1016.00 Connect... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting... Booting... Release Power button now ! bootcode current/expected: 3.2/3.2 CPU: 6253:8A02:8A00 status: FF bbchip bl ver: FE NOR flash id[00C2]: 00EC:220800000000 [SAMSUNG] K5N5666ATB chip size: 32Mb otp status/size: S_DA_NOR_OTP_NOT_SUPPORT/00000000 NAND flash chip: not installed internal RAM size: 00020000 external RAM: absent done Set baudrate (921600)... done ram test... testing 32bit... 32bit ram test passed testing 16bit... 16bit ram test passed ram test passed ===> detect existing firmware structure... detect ffs... detect sec ro... detect custom parameters... detect project-id... detect NOR info... number of areas/bytes to read: 1:00050000 reading (HW_STORAGE_NOR)... warning: ffs can not be detected TCL-ID detection... TCL-ID detection done startup code area #1 detection... startup code area #1 detection done code offset: 00000000 ===> done startup code area #1 check... done number of cores: 1 loading files... number of areas: 1 done write... write core... error: can not write flash (0): 0FA8:S_FT_DOWNLOAD_FAIL error: last error: 0FA8:S_FT_DOWNLOAD_FAIL Disconnect... done Finished, time used: 1 min 10 sec Remove/Install battery now ! |
09-12-2011, 18:56 | #11 (permalink) |
Member: 103844 Status: Offline Thanks Meter: 21 | battery full charge or using external power same error : COM1 [VCP0] selected module v4.01 Device: Blu-Q200 Checking data, wait... Action: write flash write: Firmware Blu-Q200_HEXING53_09A_GEMINI_PCB01_GPRS_MT6253_S00.X22 1_6E_DB_VV_V001_110402.BIN_FLNS71VS128RC0AHK4L0_20 11-04-02_En_Nl_Fr.B0M.bin skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs nor area detection... interface: BROM_DLL_v3.1016.00 Connect... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting... Booting... Release Power button now ! bootcode current/expected: 3.2/3.2 CPU: 6253:8A02:8A00 status: FF bbchip bl ver: FE NOR flash id[00C2]: 00EC:220800000000 [SAMSUNG] K5N5666ATB chip size: 32Mb otp status/size: S_DA_NOR_OTP_NOT_SUPPORT/00000000 NAND flash chip: not installed internal RAM size: 00020000 external RAM: absent done Set baudrate (921600)... done ram test... testing 32bit... 32bit ram test passed testing 16bit... 16bit ram test passed ram test passed ===> detect existing firmware structure... detect ffs... detect sec ro... detect custom parameters... detect project-id... detect NOR info... number of areas/bytes to read: 1:00050000 reading (HW_STORAGE_NOR)... warning: ffs can not be detected TCL-ID detection... TCL-ID detection done startup code area #1 detection... startup code area #1 detection done code offset: 00000000 ===> done startup code area #1 check... done number of cores: 1 loading files... number of areas: 1 done write... write core... error: can not write flash (0): 0FA8:S_FT_DOWNLOAD_FAIL error: last error: 0FA8:S_FT_DOWNLOAD_FAIL Disconnect... done Finished, time used: 1 min 27 sec Remove/Install battery now ! |
09-13-2011, 08:47 | #12 (permalink) |
No Life Poster Join Date: Feb 2003 Location: TelServisHalo,Loznica, Serbia Age: 53
Member: 21365 Status: Offline Thanks Meter: 92 | And than NO ANSWER or SUGGESTION from InfTeam? Ccccc...It sounds familiarly to me http://forum.gsmhosting.com/vbb/f425...write-1338709/ |
09-23-2011, 18:11 | #14 (permalink) |
Freak Poster Join Date: Aug 2010 Location: Honduras Central America
Member: 1371251 Status: Offline Thanks Meter: 15 | please support this model UTstarcom 1261 COM11 [VCP0] selected module v4.01 Action: "sp-unlock" unlock method: smart fast Model: _Autodetect MT6253 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6253:8A02:8A00]... CPU: MT6253 high speed boot On chip: 0000:0000:000F status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6253,E02 Date: 2000.00.00 Version: 1.0 Version: C5031_03.08_650108_70401_SAM_018_003 Version: CELLONSZ53_12832_09B_HW ==================== New firmware found (v.4.01, database date: 19.08.2011): C5031_03.08_650108_70401_SAM_018_003 This firmware is missing in support area. If this phone is good and working: - download latest software from support area and try again, probably this firmware already supported in latest software - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to RapidShare – Secure Data Logistics or 4shared.com - free file sharing and storage - include in your e-mail full text from phone back label (phone name etc.) ==================== detecting structure #2... error: detection failed (0 tries), read flash and send to support connection Ok detecting structure #1... 36error: detection failed (1 tries), read flash and send to support error: can't read required data error: operation failed ! Finished, time used: 11 sec Remove/Install battery now ! |
Good prices at www.gsm-support.net | gsmsupport | GSM Mobile Links | 0 | 12-15-2001 01:06 |
Who have Bartek's 2.0 SOFTWARE support all 25&35Siemens? | Baza | GSM Mobile Links | 0 | 04-05-2001 20:07 |
cannot read flash from this 3210 | Dark Lemming | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 16 | 02-10-2001 16:53 |
3210 i cannot unlock | pizza man | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 08-12-2000 16:02 |
