cannot unlock alkatel OT- E221 COM3 [VCP0] selected Device: Alcatel E221 "advanced chip detection" active Action: unlock Checking data, wait... Boot... Phone should be Switched OFF ! Press Power button now ! rom version: 0502 Connecting... booting... finalizing... Boot fail Finished, time used: 56 sec Remove/Install battery now ! |
tell me product suporter whats problem................................ |
hello! must hold power button very long time |
dear masudtel plz check your cable |
Yes it is 100%100 cable problem. |
use tx rx but no responce from phone................cable ok |
hello! cable is OK, as you can see rom version was readed: 0502 i still insist to hold power button very long, about 1 minute, until software asks to release it |
hahhaaaaaaaaaaa cable wrong with detected rom version hahaaaaaaaaaaa just use low baudrate w/o holding power bouton for a long time COM6 [VCP0] selected Device: Alcatel E221 "advanced chip detection" active Action: unlock Checking data, wait... Boot... Phone should be Switched OFF ! Press Power button now ! rom version: 0502 Connecting... booting... finalizing... Boot done Check connection... Check connection done Set baud... 115200 Set baud done Check hardware... flash: 012A7E2A242A00:54000000000000 flash: AMD/Fujitsu std [T 003Fx010000 0004x004000] 4Mb Check hardware done Read data... reading Alcatel E221_eeprom_calibration-1... file saved: C:\Program Files\InfinityBox\HModule\backup_Alcatel E221_eeprom_calibration-1_20080421-203617.80E.bin Read data done Check data... Check data done Writing... .......... .......... .. flash: 012A7E2A242A00:54000000000000 Write: simlock Writing done Finished, time used: 85 sec Remove/Install battery now ! |
To succeed in this release, you should hold the pwr the beginning until the end of the process.;) |
thx 4 d tip off ..working 4 me ..br |
work for me too hold the power button to the end thanks infinty team. COM5 [VCP0] selected Device: Alcatel E221 "advanced chip detection" active Action: unlock Checking data, wait... Boot... Phone should be Switched OFF ! Press Power button now ! rom version: 0502 Connecting... booting... finalizing... Boot done Check connection... Check connection done Set baud... 115200 Set baud done Check hardware... flash: 012A7E2A242A00:54000000000000 flash: AMD/Fujitsu std [T 003Fx010000 0004x004000] 4Mb Check hardware done Read data... reading Alcatel E221_eeprom_calibration-1... file saved: C:\Program Files\InfinityBox\HModule\backup_Alcatel E221_eeprom_calibration-1_20080517-161942.80E.bin Read data done Check data... Check data done Writing... .......... .......... .. flash: 012A7E2A242A00:54000000000000 Write: simlock Writing done Finished, time used: 87 sec Remove/Install battery now ! |
