Old 11-28-2008, 09:40   #1 (permalink)
gayansuranga's Avatar
Member: 230004
Thanks Meter: 174
can't find pin finder
Initializing Pin-Finder Adapter...
searching adapter at COM1...
too many retries
can't find adapter
too many retries
can't find adapter
searching adapter at COM2...
too many retries
can't find adapter
searching adapter at COM76...
too many retries
can't find adapter
can't register the pin finder .. removed the diode and made a jumper too.. but no luck.. got a dual out put infinity box. please help me out just bought the pin finder..
Old 11-28-2008, 09:55   #2 (permalink)
gsmbac's Avatar
Member: 44229
Sonork: 1592530
Thanks Meter: 366
connect pinfinder to infinity box's rj45 socket(named USB) , using given cable,
try again, if not success
check rj45 to rj45 adaptor cable by multi meter.
br
Old 11-28-2008, 10:13   #3 (permalink)
Member: 230004
Thanks Meter: 174
yes problem solved it was the cable which was defective .. now everything is fine..
Old 12-08-2008, 13:48   #4 (permalink)
Member: 138583
Thanks Meter: 120
I have same problem.... Can u tell me exactly with pins I should check with multimeter?
Old 12-08-2008, 14:26   #5 (permalink)
gsmbac's Avatar
Member: 44229
Sonork: 1592530
Thanks Meter: 366
check connectivity of every pin of,
infinity to pin finder connecting cable.
br.
Old 12-08-2008, 14:41   #6 (permalink)
Member: 130995
Thanks Meter: 35,227
Hello,
At first check voltage at your Infinity-Box pin-1.
Then see page-20 in PinFinder manual: http://www.infinity-box.biz/download..._PinFinder.pdf
Installed USB pin finder pcb. but can't find piouts. ..::GSM329::.. SpiderMan 2 06-03-2008 07:39
GC668 can't find pin 2 Shing SpiderMan 4 04-29-2008 16:51
cect q380 can't find pin outs with pin finder kiran Infinity-Box 4 04-09-2008 09:12
where can i find pin finder software melgsm Infinity-Box 8 03-12-2008 19:20
Page generated in 0.21734 seconds with 9 queries
