05-19-2008, 14:06 | #1 (permalink) |
No Life Poster Join Date: Sep 2002 Location: Türkiye Age: 48
Member: 15880 Status: Offline Sonork: 100.1612155 Thanks Meter: 452 | cant find second cpu with pinfinder ... i have two phone and cant find second cpu with pinfinder ... first cpu is MT6225a second cpu is MT6223aa fist find bud not second phone is firmanware from 6225 backup_flash[E880_KDI1DMCF4_E880_GPRS_MT6225_S00.01_4.BIN]_20080519-144330.B0M.bin phone name front anycool back label anycool T818 PLS HELP FİND SECOND PİN FROM THİS PHONE SEOND PHONE İS PHONE FRONT LABEL NOKİA N72 back label nokia n72 rm-180 b.r senkron24 |
The Following User Says Thank You to senkron24 For This Useful Post: |
05-19-2008, 16:07 | #5 (permalink) |
Member: 15880 Status: Offline Sonork: 100.1612155 Thanks Meter: 452 | i have found this is coreckt thakns bud have problem with second cpu imei 123456789012345 ffs format COM6 [VCP0] selected Action: imei imei write method: mode-2 new imei: 353989000477080 Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing[6223:8A04]... CPU: MT6223 high speed boot enabled chip: 0011:6237:000C Connecting, wait... Release Power button now ! Phone detected, wait... Hardware: MT6223,E04 Date: 2000.00.00 Version: 1.0 Version: E558AGENT_V60_F1.01.1 Version: EVEN6223_07A_HW detecting structure #2... 0done 44 byte(s) read imei: 1357********* connection Ok detecting structure #2... 0done 44 byte(s) read verification... verification done: 3539******x Finished, time used: 31 sec Remove/Install battery now ! when i show with insterte sim with this code *#33778# imei is 1234567966465464 pls help coreckt my phone with imei b.r senkron24 |
05-20-2008, 07:42 | #9 (permalink) |
Member: 15880 Status: Offline Sonork: 100.1612155 Thanks Meter: 452 | MOD-1 -------------------------- NOT WORK MOD-2 ---------------------------------------------- COM6 [VCP0] selected Action: imei imei write method: mode-2 new imei: 3539********* Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing[6223:8A04]... CPU: MT6223 high speed boot enabled chip: 0011:6237:000C Connecting, wait... Release Power button now ! Phone detected, wait... Hardware: MT6223,E04 Date: 2000.00.00 Version: 1.0 Version: E558AGENT_V60_F1.01.1 Version: EVEN6223_07A_HW detecting structure #2... 0done 44 byte(s) read imei: 3504*********XX warning: wrong packet cs connection Ok detecting structure #2... 0done 44 byte(s) read verification... verification done: 3539******XX Finished, time used: 17 sec Remove/Install battery now ! MOD-3 ----------------------------------------------- COM6 [VCP0] selected Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled eeprom backup enabled, it may takes several minutes ! Action: imei imei write method: mode-3 new imei: 353 ********* Boot... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing[6223:8A04]... CPU: MT6223 high speed boot enabled chip: 0011:6237:000C boot step size: 0400 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... flash: EC257E25032501:2AEA0000000000 flash: AMD/Fujitsu std [D 0008x002000 003Ex010000 0008x002000] 4Mb detecting chip #01 in region #00... flash: EC257E25032501:2AEA0000000000 flash: AMD/Fujitsu std [D 0008x002000 003Ex010000 0008x002000] 4Mb detecting chip #02 in region #00... flash: EC257E25032501:2AEA0000000000 flash: AMD/Fujitsu std [D 0008x002000 003Ex010000 0008x002000] 4Mb detecting chip #03 in region #00... flash: EC257E25032501:2AEA0000000000 flash: AMD/Fujitsu std [D 0008x002000 003Ex010000 0008x002000] 4Mb detecting chip #04 in region #00... flash: EC257E25032501:2AEA0000000000 flash: AMD/Fujitsu std [D 0008x002000 003Ex010000 0008x002000] 4Mb detecting chip #05 in region #00... flash: EC257E25032501:2AEA0000000000 flash: AMD/Fujitsu std [D 0008x002000 003Ex010000 0008x002000] 4Mb detecting chip #06 in region #00... flash: EC257E25032501:2AEA0000000000 flash: AMD/Fujitsu std [D 0008x002000 003Ex010000 0008x002000] 4Mb detecting chip #07 in region #00... flash: EC257E25032501:2AEA0000000000 flash: AMD/Fujitsu std [D 0008x002000 003Ex010000 0008x002000] 4Mb number of flash chip/regions detected: 08/01 Initialize Done Set baud... 460800 Set baud Done Initialize bootcode... Initialize bootcode Done Check firmware integrity... device parameters autodetection in progress.. detecting chip #00 in region #00... flash: EC257E25032501:2AEA0000000000 flash: AMD/Fujitsu std [D 0008x002000 003Ex010000 0008x002000] 4Mb detecting chip #01 in region #00... flash: EC257E25032501:2AEA0000000000 flash: AMD/Fujitsu std [D 0008x002000 003Ex010000 0008x002000] 4Mb it's time to stop: 2A0000EA18F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 00400000 detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [standard] generation identification#1 protocol ver: 04 ver. sw1: E558AGENT_V60_F1_MT6223S00.01_2_20080205.BIN ver. sw2: E558AGENT_V60_F1.01.2, 00000000 ffs offset/size: 00380000/00080000 detect device identification#2... detection phase #1... . warning: optional information not found, if phone works well just ignore this warning detect device identification#2 finished detecting eeprom/ffs area in 1 chip(s)... standard eeprom/ffs offset detected: 00380000 flash: EC257E25032501:2AEA0000000000 checking area[00000000]: 00000000-003FFFFF... eeprom/ffs found near: 00380000 detecting eeprom/ffs size... eeprom/ffs size: 00080000 ffs chip: 00 eeprom/ffs area: 00000000:00380000-003FFFFF Check firmware integrity Done Check firmware content... Check firmware content Done Backup required data... reading [eeprom[E558AGENT_V60_F1_MT6223S00.01_2_20080205.BIN]]... file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_eeprom[E558AGENT_V60_F1_MT6223S00.01_2_20080205.BIN]_20080520-093821.B0E.bin flash: EC257E25032501:2AEA0000000000 Backup required data Done Patch required data... 6 step(s) required to finalize Patch required data Done Special operation... Special operation Done Write... flash: EC257E25032501:2AEA0000000000 Write: eeprom Write Done Finalization... Finalization Done Finished, time used: 80 sec Remove/Install battery now ! BEST REGARTS SENKRON24 |
05-20-2008, 09:44 | #10 (permalink) |
Member: 15880 Status: Offline Sonork: 100.1612155 Thanks Meter: 452 | i have same problem with other phone phone n72 rm-180 second cpu is mt6205 iimei demaged cannot repair pls help second flash backup_flash[E558AGENT_F1_E558_GSM_MT6205B_DN.01_5.BIN]_20080520-110149.B0M.bin eeprom backup_eeprom[E558AGENT_F1_E558_GSM_MT6205B_DN.01_5.BIN]_20080520-104833.B0E.bin i have formated and write in MOD-1 AND MOD-3 BUD CANT WRİTE İN MOD-2 pls sulotion with code *#33778# 1234567898776464 best regarts senkron24 |
05-21-2008, 09:53 | #12 (permalink) |
Member: 15880 Status: Offline Sonork: 100.1612155 Thanks Meter: 452 | PROBLEM SLOVED WİTH TWO PHONE.... İ CAN ONLY ONE SAY YOU NOT SHOW FOR *#33778# WHEN COM 1234567912345 THİS İS NOT İMEİ İ DONT NOW WHAT İS THİS BUD İ HAVE SLOVED WİTH OTHER METHOD ALL OK PHONE WORK GRET WİTH ALL NETWORK WHEN İ SHOW *#33778# İS SAME BEVOR AND AFTER 1234567912345 B.R SENKRON24 Big thanks on TGT BOX FROM TـU-R-K-İ-Y-E Last edited by senkron24; 05-21-2008 at 10:00. |
05-21-2008, 20:44 | #13 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello mr. senkron24! glad to know that you solved your problem. Can you share with us your experience? Which IMEI writing Mode did job and in what sequence |
05-22-2008, 08:27 | #14 (permalink) | |
Member: 15880 Status: Offline Sonork: 100.1612155 Thanks Meter: 452 | Quote:
and team working corecktly i will help for infity team and infinity user first problem i cant find pin with pinfinder i have desambley my phone bud i cannot see any point for rx tx or gnd i have found on/off 1 and see other point on/off 2 i have on/off2 short with gnd from pin finder gnd to batary and i see viola find secont cpu then i have with spical flash file flashed for 6223 cpu and great work all ok i can see with *#06# my imei then i have chane my imei all ok this is storry with 6223 second cpu... b.r senkron24 ps: i dont now wht is this *#33778# this is **** infop with second imie after repair i have show with code same result 1234567912345 bud my phone worked with all nework | |
How can we find 2nd cpu pinout by pinfinder | Maiwand khan | Infinity-Box | 1 | 06-06-2008 11:00 |
how can I find second cpu pinouts | bigstarfirst | Infinity-Box | 1 | 03-23-2008 14:11 |
how to find the pinout of first and second cpu of dual cpu phones | maximas007 | Infinity-Box | 3 | 03-20-2008 05:38 |
INCREIBLE!!!!! cant find flash Z300i with spanish | Raulperez53 | Sony Ericsson | 0 | 03-21-2007 15:32 |
