09-29-2009, 08:24 | #1 (permalink) |
No Life Poster Join Date: Jul 2006 Location: JSR, BD
Member: 310155 Status: Offline Thanks Meter: 1,313 | cant flash LG KP-215 Code: COM15 [VCP0] selected module v1.38 Device: LG-KP215 Checking data, wait... advanced flash detection enabled Action: flash write Write: Firmware (code) Skip: File system Write: Alchemy data Skip: Eeprom "smart write" active "keep calibration" active Boot ... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting, wait... Release Power button now ! flash: 20880EFFFFFFFF:20880E00000000 flash: ST Intel/Sharp ext [def 0004x008000 00FFx020000] 32Mb id: 00005283 Boot Done Set baud ... 115200 Set baud Done Check flash ... current eeprom imei: 359955014163283 file saved: C:\Program Files\InfinityBox\LGA\eeprom_359955014163283_LG-KP215_20090929-141128.B1E.bin ..... Check flash Done Check space ... Check space Done Check parameters ... Check parameters Done Erase ... Erase Done Write ... Write: Firmware (code) calibration area skipped flash: 20880EFFFFFFFF:20880E00000000 error: wrong answer: B1 error: flash write error: 01020000:00020000 Write Fail Finished, time used: 139 sec Remove/Install battery now ! |
11-18-2009, 17:45 | #2 (permalink) |
No Life Poster Join Date: Oct 2004 Age: 47
Member: 86579 Status: Offline Thanks Meter: 70 | kp215 flash hello infinity does not support this model for flash.unlock and format work fine but when you try to flash it always fails in the same place i thought it was phone with bad hardware.so i tried to flash a kp215 that was working fine and flashed failed in the same place and ended up with a dead. .hopefully infinity team will look into this problem.also this kp215 that i tried to flash that was working but ended up dead after flash i sent to my frined who has other box and was revived with flash no problem BR Gee4234 |
04-04-2010, 12:15 | #3 (permalink) |
No Life Poster Join Date: Apr 2006 Location: eproom memory Age: 41
Member: 264366 Status: Offline Thanks Meter: 29 | The problem is still there , Flash write error , after flash the handset with polar and back to live . Please infinity team fix it . Here is Log : COM3 [VCP0] selected module v1.39 Device: LG-KP215 Checking data, wait... advanced flash detection enabled Action: flash write Write: Firmware (code) Skip: File system Write: Alchemy data Skip: Eeprom "keep calibration" active Boot ... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting, wait... Release Power button now ! flash: 20880EFFFFFFFF:20880E00000000 flash: ST Intel/Sharp ext [def 0004x008000 00FFx020000] 32Mb id: 00005283 Boot Done Set baud ... 460800 Set baud Done Check flash ... current eeprom imei: 200XXXXXXXXXX file saved: C:\Program Files\InfinityBox\LGA\eeprom_200XXXXXXXXXX_LG-KP215_20100402-213705.B1E.bin ..... Check flash Done Check space ... Check space Done Check parameters ... Check parameters Done Erase ... Erase Done Write ... Write: Firmware (code) calibration area skipped flash: 20880EFFFFFFFF:20880E00000000 error: wrong answer: B1 error: flash write error: 01020000:00020000 Write Fail Finished, time used: 29 sec Remove/Install battery now ! |
Flashing lg kp 130 | telebox2 | LG Hardware Repair | 0 | 03-04-2010 13:03 |
how can i flash lg kp 500 with hwk | unlock_solution | HWK | 0 | 09-04-2009 11:19 |
LG KP 215 still locked even after unlock with Pinfinity | alfox | Infinity-Box | 5 | 03-01-2009 11:57 |
cant flash LG U8150. please help | Softway | LG | 0 | 03-25-2007 06:53 |
