01-12-2006, 08:50 | #1 (permalink) |
No Life Poster Join Date: Aug 2004 Age: 47
Member: 76522 Status: Offline Thanks Meter: 30 | cant flash vs3! very urgent Boot answer: 02 Boot Done Set Baud... Set Baud Done Connecting... FLASH ID: 0089:880D Connecting Done Check free space... Flash chip supported In progress[EEP01]... In progress[EEP02]... Check free space Done Write... Reset... Err: set erase range Err: Reset failed Err: set erase range Err: erase not confirmed Write Failed Finished Remove/Install battery now ! Time used: 53238 sec may be problem is on speed or usb2com adapter? should i use ordinary com1 cable? |
01-12-2006, 13:32 | #3 (permalink) |
Member: 76522 Status: Offline Thanks Meter: 30 | yes u r right whis unchecked reset box work perfect. by the way x400 also gives error whis checked reset box. thx 4 help! can u describe what r ffs2 and ffs1 and is it important what is chosen? |
01-12-2006, 13:58 | #4 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,229 | Hi, Thanks for test. we will double-check "reset" option. FFS1/FFS2: it's parts of phone file system with internal pictures, melodies, pre-defined settings etc. You can skip these 2 parts. |
01-12-2006, 16:36 | #6 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,229 | It's better to flash always all parts together (like for any other phone model). But if you want to leave pictures etc you can flash only Main+LP or even LP only. But after flashing only one flash part it will be not bad idea to test phone functionality. |
01-14-2006, 11:57 | #13 (permalink) | |
Member: 130995 Status: Offline Thanks Meter: 35,229 | Quote:
01-14-2006, 17:49 | #14 (permalink) | |
Product Supporter Join Date: Sep 2004 Location: *In the right way*
Member: 84268 Status: Offline Sonork: 100.114149 Thanks Meter: 2,569 | Quote:
but it unlocked with an operateur & other still locked & wich cable i can used in flash with this model thx & regards | |
01-14-2006, 18:52 | #15 (permalink) | |
Please, ALWAYS read instructions in software Log window and make EXACTLY STEP-BY-STEP as was written. If you really have problem with VS3 unlock send me to mail Log file and we will check what can be wrong but I am sure that if you will repeat unlock procedure and you will make EXACTLY STEP-BY-STEP AS WE WROTE in final instruction it will be no any problems with unlock in your situation. Cables: pls, check infinity-box support area "Cables/Pinouts" section. | |
flash e250, VERY URGENT!!!! | ToP DawG | UST Pro II | 3 | 01-29-2007 12:45 |
PLS Need C139 french LP flash file very Urgent!!!! | ReyTech | Motorola ODM | 7 | 11-02-2006 17:02 |
E630C full flash need, very urgent! | qwerthj | Twisterflasher | 10 | 03-07-2006 19:58 |
cant flash vs3! very urgent | CLIFFORD25502 | Infinity-Box | 3 | 01-12-2006 10:23 |
3310 flash problem very urgent | lanvicky | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 6 | 06-07-2003 13:47 |
